TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. May 14, 2011 at 4:17 PM
    #421
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Does your truck have to be under warrenty to get a TSB done?
  2. May 14, 2011 at 5:12 PM
    #422
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    The short and simple answer is yes. A precious few have had luck getting TSB work done out of warranty, but they are the exception.
  3. May 16, 2011 at 9:36 AM
    #423
    Tarik
    Tarik Well-Known Member
    San Diego California
    Spidertrax wheel spacers Avid bed rack Avid sliders 285/75/16 BFG KO2 Black vent rings TRD red start button Screen protection ProComp 3.5 lift
    So it looks like my new Off Road TRD DC has 3 leafs :(
    Is it just a matter of payload, pulling capacity or is there a considerable ride quality issue. It does seem harsh but I just thought that was the nature of trucks. Also wouldn't an additional leaf make the ride more stiff?
    Is there any reason one WOULDN'T do the tsb if fully covered?
    I'll do it since I'm looking at eventually putting a camper on my truck, but was curious if this is critical or just comfort based.
  4. May 16, 2011 at 9:42 AM
    #424
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    it has to do w/ the truck not being able to support the advertised payload capacity. the 4th leaf does make the rear handling slightly stiffer, but it's nothing terrible. you can do the fix yourself w/ an AAL. you'll probably notice the sag when you add the camper.
  5. May 16, 2011 at 11:26 AM
    #425
    Tarik
    Ok thanks for confirming.
    It's a free upgrade and it'll work better with the camper so I'll call my dealer and have them schedule me in for the fix.
    Anything else I should have them do while I'm in there? (I looked through about 10 pages of these tsb's but couldn't find anything else for the 2011's...).
    Thanks!
    T
  6. May 16, 2011 at 3:42 PM
    #426
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Does your new truck exhibit any issues? If not then a specific TSB would not pertain to you. TSBs aren't recalls. Just because a TSB is issued it doesn't mean every vehicle will experience a problem associated with a specific TSB.
  7. May 16, 2011 at 7:37 PM
    #427
    Tarik
    Given that the leaf spring tsb is well regarded as a "should do", I wasn't sure if there was another tsb that's readily addressed at the same time since you've alreadygtit the truck in for work...if not I'll leave it to this one only.
  8. May 20, 2011 at 6:12 PM
    #428
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Just got my rear leafs changed does ride a little different but hell it rides like a truck why should anybody expect a truck to ride like a car? If u want a car buy a car
  9. May 21, 2011 at 7:06 AM
    #429
    Tarik
    Does it ride better or worse (harshness)?
  10. May 21, 2011 at 12:20 PM
    #430
    csjumper2003
    Savannah, GA
    It rides alot better loaded and a little stiffer with nothing in bed. the other plus is the 4x4 is a little lower than the prerunner so this changes the highth back to the prerunner:)
  11. May 23, 2011 at 12:56 PM
    #431
    bulldawg11
    bulldawg11 Active Member
    Brad
    georgia
    05 Double Cab SWB 8" Lift
    6" Tuff Country base lift. 4" tapered rear block, Toytec/Bilstein 5100 adjustable C.O's 35's mounted on 17x9 Fuel Dune rims. 8" total lift leveled to 0 degrees
    Anyone had a problem with the air bag light coming on? It came on on my 05
  12. May 23, 2011 at 12:58 PM
    #432
    The_Hodge
    SC
    there are lots of reason it could come on....most times it's either a broken clockspring in the steering wheel or a loose connection under the seat.
  13. May 23, 2011 at 1:08 PM
    #433
    Namyo
    Namyo -
    mines been on for awhile now...took a hard bounce on the beach :eek: I take it didn't deploy cause my seat belt was off :eek:
    ADD: took a hard hit this weekend on my bumper....that might have set it off so kinda glad.
  14. May 23, 2011 at 1:26 PM
    #434
    bulldawg11
    Brad
    georgia
    Could there possibly be a recall out for the problem?
  15. May 26, 2011 at 1:07 AM
    #435
    philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    - philo
    Nashville, TN
    2010 Gray Tacoma TRD
    Tom Woods Custom Driveshaft
    It rides more like a pickup truck. That's the only way to describe it.
    I'm much happier with the rear leaf TSB, both with and without a payload.
    If you don't use your truck as a truck, and want a sports car like ride, then don't do the TSB. It's a different ride.
  16. May 26, 2011 at 2:02 PM
    #436
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Unfortunately the updated TSB for the harsh ride no longer includes free Bilsteins for non-TRD models 2009 and up. But there are TWO dash rattle TSB's now! I may not get cool yellow shocks, but maybe some peace and quiet.
    T-SB-0087-10 Instrument Panel Rattle Near Glove Box
    T-SB-0106-10 Instrument Panel Rattle Below Glove Box
  17. May 26, 2011 at 5:05 PM
    #437
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    Any supporting documents? :D
  18. May 26, 2011 at 6:46 PM
    #438
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
  19. May 27, 2011 at 10:13 PM
    #439
    Tarik
    Hey guys I'm having a WTF moment... I printed the harsh ride tsb and took my 2 week old 2011 double cab 4x4 off road trd to the dealer. After presenting them with the issue they said it did not apply to my particular vehicle. It only applied to a manual transmission one...?!
    I clearly have 3 leafs and the fix, I presumed, was to have 4.
    How can a vehicle not qualify based on that? I thought it was simple enough, you got 3 leafs, you qualify...
    Enlighten me please???
  20. May 28, 2011 at 2:45 AM
    #440
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    Tarik,
    take it somewhere else! Perhaps someone here could collect all the bs responses and make a book out of it. Yours is the best one I've heard...what a crock of shit.
    I wished I was in the mood for buying a new one right now...I would be all over their ass with the tsb's. I would say that I am not buying it unless they order all the tsb's for it with proof in hand... I bet that could get them going...
    And why in hell is toyotat continuing to produce the trk with only 3 leafs??? Cost savings?
