TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. Jun 16, 2011 at 8:08 AM
    #481
    bgigacz
    bgigacz Member
    Bill
    Burton, NB Canada
    PreRunner 4X2
    Another option is to take it to a place that does spring. I took my 05 Tacoma Prerunner in this morning to City Spring and they added a leaf spring to both sides. This raised my back end by about an inch and a half to two inch's. It took all the load of of my overload spring. All said and done 160 buck. Drives better to.
  2. Jun 16, 2011 at 4:54 PM
    #482
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    It does matter what you call it, because it is two separate issues.
    The slip joint noise is heard/felt on gravel roads through the steering wheel.
    What DestroyerFan is desribing in his question is the lunge felt when the AC compressor kicks in when you come to a stop.
    So two separate symptoms.
  3. Jun 17, 2011 at 5:45 AM
    #483
    TacoMO
    TacoMO Well-Known Member
    Jeff
    fly over zone
    09 dbl cab 4x4 TRD Off Road
    Shell
    I quite honestly don't see the need for this fix. I'll have to look and see if the overload spring is under tension now, but I have hauled motorcycles, pulled my 19' travel trailer, both for 1000s of miles without problems. The rear end seems pretty high already. Maybe it was done by the dealer before I bought it.
    I've got 107K on it now, it had 19 on it when I bought it 2&1/2 yrs ago..
    I went in to have them look at it after I read earlier threads about the fix, I was thinking I better get it done..
    I'm a believer in if it ain't broke, don't fix it..:cool:
  4. Jun 20, 2011 at 8:14 PM
    #484
    DestroyerFan
    DestroyerFan Well-Known Member
    SoCal
    09 MagGray PreRunner SR5 Sport
    Actually, the "lung" is felt when I release the brake after coming to a stop. Is the AC compressor always running? Because the lung happens with the AC off.
  5. Jun 21, 2011 at 5:13 AM
    #485
    jivewalker
    Jack MeHoff
    Chucktown
    If you search "lurch" and "lunge" on the forums there is a ton of info and ideas, most agree it is the AC compressor. All Tacomas do it. I will have to agree with your questioning of it though if it is happening with the compressor off. I got used to it pretty quickly. When I first got the truck, I posted the same question as you, and the overwhelming response was AC, however, I think there was also mention of the ABS system, something to do with not being able to brake and accelerate at the same time as a safety measure. Once I got used to it, I stopped wondering.
  6. Jun 21, 2011 at 5:15 AM
    #486
    tsub345
    tsub345 Well-Known Member
    Travis
    Near Pittsburgh, PA
    '17 Super White TRD OR
    Solid Fold 2.0, Cali Raised LED Stealth mount bar, Tint, Wet Okole Covers, Tailgate/Glove Box Letters
    OK, so i went to my dealership on my last oil change and asked the guy in the service department about my truck suspension being "mushy" (his term not mine) when under load. He said no problem and would order the parts after warning me the truck will be rouhger when unloaded, I said that doesn't bother me it is a truck.
    Fast forward three weeks, I call the service department to see if the parts came in to to have the rear TSB done, the women in the service department had no idea what i was talking about and says she needs to do some research and asks to call me back the next day.
    Next day, she calls me and I am expecting good news . . . wrong! She tells that the parts are on back order because of the tsunami that hit Japan! WTF!
    I need guidance is she BSing me or should I go to another dealership to have this done?
    I have also gotten the excuse that because my truck is a 2011 the parts could be on hold since it is so new.
  7. Jun 21, 2011 at 6:45 AM
    #487
    Gigi515
    Gigi515 Active Member
    Western MA
    2008 Tacoma 4x4
    What you need to do is call Toyota and explain what your truck is doing and get a case number.
    Then you have to have the dealer inspect it to see if it's defective and needs any work. Get an estimate in writing. Then call Toyota back. Being a new truck, I'm not sure if you even need to go through Toyota, but based on what you wrote, I would work with another salesperson at the dealership.
  8. Jun 21, 2011 at 8:38 AM
    #488
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Therefore it was what I said its the drive shaft moving in and out I hear the clunk when u stop abruptly bc usually it moves in and out slowly but when u stop quick it doesn't have time to travel foeward slowly
  9. Jun 24, 2011 at 2:43 PM
    #489
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Finally got my new rear springs, rides better all around! I played it safe and got a case number and had Customer Care give me the TSB before taking the truck in -- told Customer Care that I had taken it in before and they were clueless on several issues (I had taken it in for radio replacement and fixing rattles before in case they looked -- radio broke within 3 weeks and rattle was still there driving it off the lot).
  10. Jul 1, 2011 at 4:54 PM
    #490
    Shetto24
    Shetto24 Well-Known Member
    Lake Tapps, WA
    Rookie question: I bought my used 2005 TRD Off Road about a month ago. I read through some of the TSB and am not sure if the previous owner ever got the work done. The truck has 59.9K miles on it. Am I able to get some TSB's done at no cost? Will they be covered under any type of warranty? Most notably, I'd like to get the 6spd clutch chirp done.
  11. Jul 1, 2011 at 4:58 PM
    #491
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Typically they go under the 3yr 36k mark .. for a tranny issue that might be under the drive train warranty if you have that.
  12. Jul 5, 2011 at 9:12 AM
    #492
    tacomahq
    tacomahq Active Member
    Denver, CO
    Last week Toyota sent a TSB to dealers regarding a clutch defect on 2005-2011 Tacoma with the 4cylinder, 5 speed manual.
    Basically, the TSB says that if your 2005+ 4cyl 5spd doesn't engage in all gears, there's a good chance that it was a result of defective clutch friction material.
    You can read the whole story here: http://www.tacomahq.com/758/tacoma-tsb-5-speed-manual-clutch-disk-defect/
  13. Jul 5, 2011 at 7:01 PM
    #493
    needataco
    needataco Well-Known Member
    Wow, that's crazy. I have this combo (08) and haven't experience this problem after nearly 50k miles. However, this will come in handy if it does start happening. Thanks!
  14. Jul 6, 2011 at 1:09 PM
    #494
    tacomahq
    Denver, CO
    You bet.
  15. Jul 7, 2011 at 9:39 PM
    #495
    Gigi515
    Western MA
    2008 Tacoma 4x4
    ive been complaining about my clutch since I got my truck. can't get it into gear at times.
    where is the actual TSB? I'd like to have it when I go to the dealer/call Toyota.
    T-SB-0066-11
    I've been to the TacomaHQ site but that's just a summary of the TSB.
  16. Jul 7, 2011 at 11:26 PM
    #496
    rdp5008
    rdp5008 Well-Known Member
    Russell
    Missouri
    2001 Tundra
    ARE Camper Shell
    My dealer blew me off with the rear leaf pack. Hauling a light load and bottoming.
    My throwout bearing sounds bad at 10k. "crunchy" is the term I'd use. Maybe the clutch tsb?
    Do dealers get paid to turn down tsb repairs?
  17. Jul 8, 2011 at 4:24 AM
    #497
    Gigi515
    Western MA
    2008 Tacoma 4x4
    you need to call Toyota first and get a case number.
  18. Jul 8, 2011 at 4:31 AM
    #498
    TacoMO
    Jeff
    fly over zone
    Shell
    I'm not 100% sure, but I think the dealers come out ok on TSBs.
    I believe they get a fixed amount based on estimated time it should take. (similar to a recall) if they can get it done in less time than the estimate, then it's even more profitable.. I could be wrong..
    Jeff
  19. Jul 8, 2011 at 11:16 AM
    #499
    rdp5008
    Russell
    Missouri
    2001 Tundra
    ARE Camper Shell
    Thanks for the tip! I had no idea.
  20. Jul 8, 2011 at 5:01 PM
    #500
    Gigi515
    Western MA
    2008 Tacoma 4x4
    dealer has to look at it and diagnose if you have a case number from Toyota. I just had the leaf springs done. Unfortunately I believe my clutch is affected now :(
    I have not been thrilled with the new clutch assembly (I previously had a '97 with ) on the 2008 and it is not smooth. It tends to not go into gear at times, particularly 3rd and the dealer has noted it since I bought the truck new.
