TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. Apr 10, 2014 at 9:30 AM
    #901
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Yeah , it's complete bullshit . Got the runaround from the dealer when I bought my extremely low-mileage bs "Certified Used Warranty" and now nothing is covered . Shame on these idiots for acting like GM and other corporations for treating customers like toilet paper .
    Sarge
  2. Apr 11, 2014 at 3:15 PM
    #902
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Just speaking from experience and the experiences of others if toy plan in actually using your truck to haul you will or would be disappointed by the TSB leaf pack. Mine had already sagged quite a bit before I added an AAL.
  3. Apr 17, 2014 at 7:37 AM
    #903
    mchipser
    mchipser Member
    I bought my taco (used) about 6 months ago and have recently have had several of the TSBs listed for this vehicle. 2005 Prerunner.. Is there anyone in the central Texas area that can recommend a fair and competent repair shop that has experience with these issues?
    T-SB-0132-08 Driveline Vibration Between 15 - 25 MPH
    T-SB-0250-12 2WD Rear Propeller Shaft ClunkThunk Noise
    T-SB-0008-14_1-10 Driveline Vibration Part 1
    T-SB-0008-14_11-20 Driveline Vibration Part 2
    I also had the windsheild wind noise, but it seems I have fixed the issue..
    Thanks.
  4. Apr 17, 2014 at 7:39 AM
    #904
    dexterdog
    Oly WA
    2012 F150
    Do you have all those issues?
  5. Apr 17, 2014 at 7:59 AM
    #905
    mchipser
    mchipser Member
    From reading the TSBs T-SB-0132-08, T-SB-0008-14_1-10, and T-SB-0008-14_11-20 I do.. I have tons of vibration. I also have a clunking metal on metal that sounds like something hitting when spinning, on each revolution I think this is T-SB-0250-12 (This is way more prevalent when hauling something) .. I had the windshield noise issue, but applied to 3M sealer last night, it seems to have been fixed..
    I called the local Toyota dealer and they said they could check to see which problems I have, for $115, for a driving test. I thought this was pretty ridiculous..
  6. Apr 17, 2014 at 8:12 AM
    #906
    dexterdog
    Oly WA
    2012 F150
    I don't think he was thinking a dealer eras going to do the work for free since he had asked about a competent repair shop.
  7. Apr 17, 2014 at 8:25 AM
    #907
    mchipser
    mchipser Member
    I don't think nor do I expect the items done for free, hence the repair shop.. I was asking for recommendations in my area so I could take the truck to get fixed.. The dealer in my area seems to be a dick and don't want to just do the work. I obviously know I have the issues, as my truck is severely OOW and that I will need to pay for the fixes.
  8. Apr 17, 2014 at 9:59 AM
    #908
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That clunk may just mean you need a new carrier bearing. Your truck is 9 years old, the rubber may have dry-rotted by now.
    Your vibration problems could be anything or a combination of multiple things. Tires, tire balance, wheels, bearings, etc. Things do wear out. You would have to eliminate all those possibilities before looking at the TSB procedure.
  9. Apr 24, 2014 at 7:14 PM
    #909
    mchipser
    mchipser Member
    I tried to make a video of the truck, and the first one looks better.. but i forgot to put in a SD card and have no idea where the cable to my camera is.. by the time i got home to do another video it was really dark outside..
    so here is my video... really dark.. but on a side note you can hear some of the issues.. around the 9 min mark is where they are starting to show..
    http://youtu.be/PHgjJhfbePM
    I have someone going to replace the carrier bearing and the u-joints for a fairly decent price.. I'm hoping the vibs go away..
  10. Apr 25, 2014 at 4:30 AM
    #910
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Hard to say for sure without being able to inspect it in person, but I think this should fix it. It probably needs to be done anyway. That is an annoying sound!
  11. Apr 25, 2014 at 2:34 PM
    #911
    mchipser
    mchipser Member
    The mechanic replaced the u-joints and told me the carrier bearing was still good.. Haven't had any vibs all day and the awful sound is also gone.... Thanks for the help everyone.. The truck feels like a completely different truck with the vibrations gone..
    Now that the vibrations are gone, I feel the "bump from behind sensation" when stopping.. :(
  12. Apr 26, 2014 at 5:49 PM
    #912
    ttubb
    ttubb Member
    Terry
    Tucson/Crested Butte
    Tacoma TRD Off Road 4WD
    Just had this TSB done. 2013 DCSB OffRoad. Vibes are gone and it is smooth as can be. Redisign worked. :D
  13. Apr 30, 2014 at 5:56 AM
    #913
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    My tranny shift points seem like they off. If I am at a low rpm, right around 1500, it will drop down and almost big before it will down shift. It has been doing this for a little while but it hasn't always done it. I can recall after buying this truck how on point the transmission was. At about 102k I cleaned my throttle body and MAF sensor, but it didn't really seem to help the shifting issue. I remember hearing about an ecu flash for a similar transmission issue on 2009 tacos but I don't recall if there was anything like it for 2006. Any help would be much appreciated
  14. Apr 30, 2014 at 7:11 AM
    #914
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    can confirm
    2013 TRD OR AC. T-SB-0008-14.
    1 year of bad 15-25 mph vibes completely eliminated, now smooth everywhere.
  15. May 1, 2014 at 12:07 AM
    #915
    bueller
    bueller Well-Known Member
    AZ
    Did you guys both get new leafs? I'm taking mine in Monday to have the TSB done. Hopefully I'll get the new leafs. I've got a bad vibe on acceleration.
  16. May 1, 2014 at 6:54 AM
    #916
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    I did
    from 3 to 4 and the 4 has a wedge [fat end facing front]
  17. May 10, 2014 at 5:38 PM
    #917
    kalaukia37
    kalaukia37 Member
    Bob
    Hawaii
    SR5 3.4L 5 SPEED
    ALARM, BEDLINER, OPEN AIRBOX, WHITE LETTER TIRES, RUSTPROOF,STAINLESS WHEEL GUARDS, HOOR AND WINDOW SHIELDS, ETC.
    Hey, This Is Kaluukia37, Aloha To All Of You Tacoma Owners. I just was Reading About Your Spring Problems. Well i Have a 1998 SR5 3.4L V6 Extra Cab. Loaded With Extras And Up Graded In a Few Places.. I Have Loaded My Truck With Cement Bags That were 1200Pounds, A Number of Times with No Problems At All. It is Built Like an S Runner. 5 Speed, Plus the Front looks Like it is Dropped Just A Little. I Have only 86K on it so far, Looks like Brand New, Plus It Runs Like New. It Gets 25MPG With the Air on, Here in Hawaii. I Did Change My Shocks At 80K, and One Rear Shock Was Blown. That is All the Problems that I have Had Concerning Springs. My Truck Rides REAL NICE. The 3.4L V6, Is Almost Bullet Proof!
    Well That is my TWO CENTS
    Aloha Too You All!
    Love and Blessings
    Kalaukia37
  18. May 17, 2014 at 5:20 PM
    #918
    ttubb
    ttubb Member
    Terry
    Yes, a complete new spring pack with the wedge to adjust drive angle.
  19. May 30, 2014 at 2:45 PM
    #919
    oldsoldier
    oldsoldier New Member
    I had T-SB-0008-14 applied to my 2013 Tacoma Sport Long Bed today. It completely eliminated all of the vibration problems. I never realized before just how bad it was. The truck is much smoother now. They replaced the engine motor mount, installed the steering wheel damper, and replaced the rear springs. I had 4 leaf springs before and have 4 leaf springs now but they are a different part number and obviously brand new. The shipping and part number stickers are still on them. I'm trying to decide if the truck might be a little shorter in the rear now but since I didn't measure it before taking it in I can't tell for sure. Either way it drives much better and so I'm satisfied.
  20. Jun 12, 2014 at 12:02 AM
    #920
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    is there a tsb similar to the TC004-06 clutch sqeak issue for 2012 6spd tacomas? my clutch squeeks in hot weather.
