TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. Dec 6, 2008 at 12:18 AM
    #121
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    No, TSB states it must be under factory warranty.
    But....Some people have been successful in getting it performed, they usually had to demonstrate a severe problem by putting weight (under payload) in the bed and it bottoming out easily. Depends on the dealer and the extent of your issue, they don't have to do it and would have to get approval for it out of warranty.
    see above
    TRD models get new 4 leaf packs, Non-TRD models get 4 Bilstein shocks and 4 leaf pack. Don't know what they would charge, but I'd guess you would be better off going will something aftermarket. Check out the suspension section of the forum.
    TSB states Access Cab and Double Cab body styles only. Not much the dealer can do to help you out, so if you are concerned and having a problem then contact Toyota Corporate and see if they are willing to help. I think they are basing it on regular cabs having a lower payload/towing capacity and they weigh less overall.
  2. Dec 6, 2008 at 7:42 AM
    #122
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    On my reciept, the dealership is charging Toyota $1500 and change. And that's without shocks.
  3. Dec 6, 2008 at 4:33 PM
    #123
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Ok thanks for clearing it up for me.. I might get the parts for it and do it my self or ( what ill probably do) just get aftermarket suspension parts
  4. Dec 12, 2008 at 4:30 AM
    #124
    doublejdog
    doublejdog New Member
    I have a 2008 single cab 4x4 4-cyl tacoma and they did the TSB for me. My old springs would rattle over bumps before. The TRD shocks are awesome. The truck sits a bit higher with the new springs. The cost to Toyota was $1995.00. No wonder the big 3 are in DC begging for $$$. Toyota's service is top notch.
  5. Dec 12, 2008 at 4:42 AM
    #125
    FoxySandChick
    Kristin
    Henderson, NV
    Could you provide more info on your process to get it done? There are some reg cab people wanting to get it done and the TSB both old and new clearly state they are not covered.
    Did you make a complaint due to the rattle?
    Did you present the TSB to the dealer yourself?
  6. Dec 12, 2008 at 4:52 AM
    #126
    doublejdog
    I did. They tried a couple of times to fix it. I stayed on them. I printed out the TSB from the link provided in this thread and brought it to them. They didn't hesitate and ordered the kit right away. I guess I'm lucky because it seems some dealerships are giving customers a tough time about it.
  7. Dec 20, 2008 at 6:07 PM
    #127
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    anyone have the Harsh ride TSB for Canada?
  8. Dec 21, 2008 at 8:30 PM
    #128
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    Yes I am, I currently have a 2008 Double Cab 6M/ sport, towing.
    Mine sits low and bottoms out often, I do have the extra weight of an A.R.E cap.
    I already have 4 springs, and the upgraded sport shocks. Will Toyota do anything else to it?
  9. Dec 22, 2008 at 6:08 AM
    #129
    07nctaco
    07nctaco Active Member
    nc
    07-DC prerunner
    I have the driveline vibrations at lower speeds and I do have a spacer lift and aal. Does the driveline TSB fix this or is the lift the cause? Should I remove lift before going to dealer? I also have only the 3leaf pack, does the aal fix the bottoming out issue? Thanks!!
  10. Dec 22, 2008 at 10:34 AM
    #130
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    On the 05+ models, that isn't a bed liner - it is the acutal bed. I had a problem with rattling on my 2007, but there was no TSB out for it. My 2008 doesn't have any problems with bed rattle, and it gets much more use/abuse. Have you checked all the bolts and the "bins" above the wheel wells?
  11. Jan 6, 2009 at 5:38 PM
    #131
    roggs01
    roggs01 Roggs01
    Surprise, AZ
    16 TRD Sport
    Predator steps,Method NVs, 285-70-17 KO2s
  12. Jan 6, 2009 at 9:45 PM
    #132
    colvilletacoma
    colvilletacoma Well-Known Member
    Central Washington
    Toyota Tacoma
    OME 886 Coils, Bilstein 5100's in Front, Tuff Country in Rear, Custom Racks with winch built in
    Basically Toyotas service is the worse their is when it comes to things like this. You could almost get a Complete Long Travel Kit for 2 grand! My frame swap they wanted to do was $10,000....enough said. Fix is gonna be done tomorrow. I do need the Tailgate TSB but i have the extended warranty and im not sure if its covered
  13. Jan 7, 2009 at 1:58 PM
    #133
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I'd rather fight with Toyota than step foot in Pontiac.
    Also, service changes based on your dealership.
  14. Jan 28, 2009 at 12:02 PM
    #134
    Anthony999
    Anthony999 Well-Known Member
    Glendale, AZ
    05 Tacoma
    MB Seven X Wheels, Hankook Optima Tires, Billet Grille, Blacked out headlights tailights and third brake light, LEER 700 Series tonneau cover, Blacked out emblems, Wolo air horn, Sony Xplod stereo, 8" Bazooka subwoofer, painted to match bumpers, leather arm rests.
    Ive got the windsheild noise and clutch squeak
  15. Feb 2, 2009 at 3:19 PM
    #135
    Teahupoo
    Teahupoo Big Island
    Teahupoo
    Big Island, Hawaii
    07 tacoma TRD
    I have a 07 trd tacoma dcab that has 32,000 miles on it. Recently I noitced that the rear end was sagging and the brakes would sqeak. When I took it to the dealership the found the TSB on both of them and then one more and are fixxing it under warrenty. I would highly recommend Big Island toyota Hilo Hawaii
  16. Feb 2, 2009 at 3:36 PM
    #136
    Lentsnh
    Glad you got that/those TSBs done.... AND WELCOME TO YOUR NEWEST ADDICTION
  17. Feb 25, 2009 at 3:38 PM
    #137
    JTech
    JTech Well-Known Member
    Phoenix, Arizona
    Silver 09 Double Cab 4x4 Sr5 Off-Road
    Locking Bed Boxes, built in air compressor, Husky Liners(not really a mod but I love them)
    So i called toyota to see if the TSB will carry over to the 09 models. They said that as of now the tsb does not carry over but they are contacting my local dealer to look at my truck. i had noticed the rough ride while loaded but assumed it was just how it was until i read this thread. I have an appointment to get someother work done March 5th so I will post back with what they say about the tsb on the 09's
  18. Feb 25, 2009 at 4:39 PM
    #138
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    Does anyone have a site or cantact for Canadian TSB's?
  19. Feb 25, 2009 at 4:41 PM
    #139
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Well I had the Vibration TSB done. I think it helped a little, but that may just be my imagination, it was still there. Took it in again since then and they said I needed a new driveshaft. Just got back from the dealership from getting that replaced to no avail. I'm really perturbed. If this issue has no long term effects on the truck, then I can live with it (although I shouldn't have to). I plan on keeping this thing for atleast 8 years and I don't want this to be the cause of something major down the road after all warranties are up.
  20. Feb 26, 2009 at 9:38 PM
    #140
    Teahupoo
    Teahupoo Big Island
    Teahupoo
    Big Island, Hawaii
    07 tacoma TRD
    try infotrax online they can give you all the info for the tsbs for your truck for about $10
