TSB Oil Leak Timing cover being fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fjm0008, Jun 8, 2010.
  1. Dec 10, 2013 at 3:58 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    ^^^ Dean.....
    I dont remember if this was covered after your warranty was up or not cause I got my fixed a couple years ago on my 2006 TRD Sport but I believe I was under the warranty miles but I'm not positive? I'll see if I can find the work invoice for it. I'm sure its pretty pricey out of pocket cause I know they have to lift the engine to fix the problem and the dealership had my car for about 4-5 days if I'm not mistaken. Your right though and since its a manufacturer defect they should fix it.
  2. Dec 10, 2013 at 11:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If your engine blows from a minor oil leak, would it not be your negligence?
  3. Dec 11, 2013 at 2:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You are either
    trolling, extremely nieve or stupid. Gaskets and seals do dry and shrink over time, no matter how well you take care of your vehicle.
    There may have every well been some issues with the factory sealing in this area. However if it did not occur until 121 K miles ( twice the warranty period ) you need to grow the fuck up and get it repaired.
    Please go buy a Dodge!
  4. Dec 11, 2013 at 2:42 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    To get your attention. See it works.
    Why do you not use your head Squatcher? Gaskets and seals do not last forever.
  5. Dec 11, 2013 at 3:41 PM
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    Since I was way out of the warranty requirements I ended up doing this repair myself. If anyone needs some insight on repairing it. I am more than happy to help. All the parts cost around $250 and the repair time was about 12 hours. It takes a bit of patience and a lot of elbow grease but it was totally worth it.
    bluspectre, LGOPs504 and Fizzy like this.
  6. Dec 11, 2013 at 4:58 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    How about doing a "how to" post on it? A common issue, it would be valuable insight for TW.
  7. Dec 11, 2013 at 5:00 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Why are you still going on about this troll. First i said it before and ill say it again hoping that you will go away and disappear. You had 60,000 miles to address this issue to apparantley you did not because either it wasnt a problem then or you were to ignorant to check your truck for issues before. Yes an oil leak is very obvious if you either look under your truck or check the block when you say CHECK YOUR OIL! You have 132000 miles now, you are either dumb or naive to not understand at the mileage your truck is at that things like your timing chain seal could be worn out by chance...its mechanical in nature!!! Things wear out. Please stop whining about this issue, either follow the guidance other have given you and fix it yourself or pay the dealer to fix it and stop blaming Toyota for your ignorance and for gods sake quit trolling !!
  8. Dec 11, 2013 at 5:06 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    and the problem is caused by the power steering pump being to wide and prying on the timing cover and messing the seal up. so just doing the TSB will not permanantly fix the problem
  9. Dec 11, 2013 at 5:54 PM
    steviestyles
    Colorado Springs
    Bone Stock
    Mines fixed and has been for 40,000 miles. No leaks. When I'd did leak while viably noticeable it wasn't noticeable on the dipstick
  10. Dec 11, 2013 at 6:07 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    thats cool, but the power steering pump is partly the cause. hell, after i replaced my engine, i couldnt even get the old PS pump into the post it goes on the new engine at all. if i did, the timing cover would have been pushed forward. i ended up takin a dremel to the mountin point on the top bolt of the PS pump and removed a little bit of metal (i hardly had to grind any down at all) and it slid right into the spot no problems what so ever
  11. Dec 11, 2013 at 7:11 PM
    steviestyles
    Colorado Springs
    Bone Stock
    The TSB calls for replacing the gasket. When I took mine to the dealer they pulled the engine and the Service Advisor told me that the cover was reengineer hence the reason for needing my truck a whole day. Don't know if this is true or not, all I know is no more leak, no loss of oil.
  12. Dec 11, 2013 at 7:36 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    i know its to replace the gasket, but tell me this, why does it only leak in that one spot? its becuase the PS pump is a very very tight fit in there and pries on the timing cover
    thats a good post about the problem
    http://www.xr-underground.com/forum/showpost.php?p=666644&postcount=15
    and this one
    http://www.xr-underground.com/forum/showpost.php?p=927662&postcount=35
  13. Dec 11, 2013 at 7:46 PM
    steviestyles
    Colorado Springs
    Bone Stock
    Not disagreeing with you in any way, just saying its possible Toyota modded the gasket/cover to accommodate the gap...or is the ps pump different on earlier/later years. If the condition remained the same why wouldn't I have another leak? Also wouldn't the tech realize the pump didn't fit properly when reassembling the cover?
  14. Mar 1, 2014 at 12:22 PM
    mc3404
    mc3404 Well-Known Member
    Concord ,NC
    03 v6 tacoma
    What type of oil are you guys running? Synthetic?
  15. Mar 2, 2014 at 5:29 AM
    #35
    qnyla
    NM
    So is the answer to why newer Tacomas do not have this issue (1) a modified PS pump mount? (2) a re-engineered TC cover? or ??
    Does anybody have a photo showing the PS pump mod where material is ground off the mount point for the top bolt on the PS pump? Not understanding what is described.
    Mine is barely weeping oil at that location on the TC , and I have been watching it.
  16. Mar 2, 2014 at 6:19 AM
    #36
    tony2018
    tony2018 Well-Known Member
    Yes this would be interesting to learn that the cover was redesigned, which would mean it was indeed a design flaw.
  17. Aug 26, 2017 at 9:56 PM
    #37
    Shams
    Shams New Member
    Shams
    05 tacoma
    Is their a video on how to fix the oil leak on the timing cover on a 05 tacoma 4.0?
  18. Sep 5, 2017 at 5:54 AM
    #38
    Shams
    Shams New Member
    Shams
    05 tacoma
    Hey I got a 2005 tacoma 4.0 and it's got a leak. Does the timing cover have a gasket or do the sprocket leak. What is a tsb? Thank you. I tried looking for videos on how to fix the leak but no luck
  19. Sep 5, 2017 at 7:16 AM
    #39
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Mine will get resealed when I pay to have the head gaskets changed.
