Tsb or aal
Discussion in 'Suspension' started by my coconut, Nov 9, 2009.
  1. Nov 9, 2009 at 7:40 PM
    my coconut
    my coconut [OP] Member
    rick
    nor cal
    05 tacoma trd 4x4
    Tsb & aal what is the difference in these springs. Not sure which one to purchase. I know the tsb was being installed at toyota. But my truck is a 2005 and the warranty has expired. Could someone shed some light on this for me.
  2. Nov 9, 2009 at 7:43 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    based of what dealers charge for parts i would go with the aal.
  3. Nov 9, 2009 at 11:10 PM
    jason1kyle
    jason1kyle commander101
    JOHNSON CITY, TN
    08 double cab trd sr5
    77 series k&n 1inch throttle body spacer dual in single out catback exhaust (exhaust pros)
    u might wanna check cause from what i've read about the tsb is that its not a warrenty item its a upgrade that toyota does b/c they're toyota i spose but i havent got it done on mine yet casue i'm in iraq and trying to talk my dad through it all but i would look into it all if u can get some free springs and shocks then go with that
  4. Nov 10, 2009 at 5:26 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You have read the wrong things- It is a warranty item (just like it states on the the TSB paperwork). Some folks have had it done out of warranty as a nice customer service gesture....but that's about it.
    The TSB and an AAL are different- The TSB replaces the current 3-leaf pack with a new stronger 4-leaf pack. It is not designed to be a lift component (altho it does pick the rear end up a little bit)
    Most AALs are usually designed to lift the rear end 2-3 inches.
    So if you are looking for a lift- Give the TSB a shot and get the AAL. If you are just worried about the load capacity of your rig- Try for the TSB.
  5. Nov 10, 2009 at 6:07 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    I believe the shock upgrade is only for non TRD trucks, they are upgrading to TRD shocks. When I had the TSB done on my 09 TRD Sport thats what I was told at least.
  6. Nov 10, 2009 at 5:13 PM
    my coconut
    rick
    nor cal
    05 tacoma trd 4x4
    thanks for the info boys, i think ill just go with the aal along with the bilstein 5100 shocks.
