TSB parts ordered
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Sep 10, 2010.
  1. Sep 10, 2010 at 3:31 PM
    Larry
    Larry [OP] CARL
    CARL
    The good folks at Panama City Toyota, who I bought my truck from...
    were cool about it, and ordered me the rear spring TSB parts without even seeing my truck.
    It saves me a trip over there...approx 40 miles one way.
    They will call me when the parts are in and schedule the install. The service manager said it's about a 3 hour job...so I may wait it out...
    They also informed me the TSB includes shocks?...and bump stops?...and an alignment?
    I may grab some 5100's and have them installed up front at the same time.
    I hope to report more good words on this dealership after the TSB is done soon.
  2. Sep 10, 2010 at 3:45 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Way to go larry
    You may want to ask the dealer if they will install the billys up front while doing the TSB
    Have heard some will, some wont. but if they do its a free alignment.
    as a reference, i set my billys at .85 .
    my TSB gave me about 1 1/2 inches of lift just after the TSB was done
    but a week later when i installed the billys, the back was only 1 inch higher than stock.
    glad i did the .85 because it retained the factory look, just a inch higher
  3. Sep 11, 2010 at 6:29 AM
    Larry
    Larry [OP] CARL
    CARL
    Good info Mike
    If I can get the billys in time...and the dealer will install them up front...I'll go that route.
    And...I was on the fence (like a lot of folks here) on .85 or 1.75...but I will be using my truck as a truck, so I think the rear will settle...so I'll probably go with your suggestion to go w/ .85
    The service guy said something about new shocks anyway? I didn't think the 2010's got new ones with the TSB?
  4. Sep 11, 2010 at 6:33 AM
    Larry
    Larry [OP] CARL
    CARL
    btw...
    what's the going rate to install billys up front and an alignment, should I have to have it done later, after the TSB has already been done?
    And...
    Assuming they do...or do not, replace my shocks...
    Is there any reason to replace the rear shocks w/ billys in the rear on my new truck. Are the rear billys that much better than my brand new ones already on the truck?
    because, I'd only do the fronts to level the truck.
  5. Sep 12, 2010 at 5:38 AM
    Larry
    Larry [OP] CARL
    CARL
    Morning bump for above questions ^^^
  6. Sep 12, 2010 at 5:55 AM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    I think 08 was the last year to get new shocks. 09-11 have the new shocks and don't get springs. The srpings will really jack up the rear, 1.5" sounds about right. It took 3" up front to level it out - I used a spacer. My dealer talked about the harsh ride afterward, seems allot of folks complain about how high the rear sits and how harsh the ride is. I am like this is a truck and not a car, right? It rides fine for me.
  7. Sep 12, 2010 at 6:02 AM
    gringo77
    gringo77 Member
    Braselton Ga
    2011 DC LB TRD Sport
    i'd like to know the answer to post 4 as well...thanks!
  8. Sep 12, 2010 at 3:27 PM
    Larry
    Larry [OP] CARL
    CARL
    Ditto :)
  9. Sep 12, 2010 at 3:55 PM
    skistoy
    Western New York
    TSB REVISION NOTICE
    • January 4, 2010 Rev2:
    • Applicability has been updated to include 2009 – 2010 model year Tacoma vehicles.
    • Shock absorbers and bump stops have been updated in production for 2009 – 2010 model
    year Tacoma non-TRD Option Package Truck.
    • Updated shock absorbers and bump stops are now available for 2005 – 2008 model year
    • Measurements have been updated in the Alignment Inspection tables.
    2009 – 2010 model year Tacoma with Non-TRD & TRD Option Package Truck
    OP CODE DESCRIPTION TIME OFP T1 T2
    SU7003 Rear Spring Assembly (Both Sides) 1.4
    Combo C Alignment 1.2
    Combo D Front Toe-in 0.1
    Combo E Front Camber 0.2
    Combo F Front Caster 0.2
    48210-04550 34 14
    NOTE
    The 2009 – 2010 model year non-TRD Option Package Truck is already equipped with updated
    shock absorbers and bump stops. Do NOT replace the shock absorbers or bump stops.
    Dont believe the 2009 - 2010 get the new shocks.
    I only put the billys up front,
    the back end is so light really no need to upgrade.
    may-be after hauling some things you could deside to upgrade latter if needed.
    Unsure of the going rate to have the billys installed
    me and a buddy did them at his house,
    you will need a spring compressor, and i would remove the sway bar to make it easier.
    dont forget the alignment afterwards.
  10. Sep 13, 2010 at 6:20 AM
    Larry
    Larry [OP] CARL
    CARL
    bump
