TSB Question
Discussion in 'Suspension' started by ininerider, Feb 2, 2011.
  1. Feb 2, 2011 at 3:59 PM
    ininerider
    ininerider [OP] Member
    Took my truck in and got the suspension TSB. As far as I can tell they replaced shocks and struts with Billsteins and put new springs on the rear. What is required or recommended to level out the front? With this TSB did they put new springs on the rear that have an AAl? Forgive me if this is a repetative question..I want to lift my truck a couple inches but do not want to break the bank...
  2. Feb 2, 2011 at 4:04 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    The rear should have a four leaf pack. So go look and count it. Normal is three. And with the four leaf pack it would give you about 1.5 inch of lift. Now for the front there are the 5100s that are ajustable. So measure your front and then measure the rear and see what to set them at. But you have the stock Billys so you would have to buy the Billys 5100 that are ajustable.
  3. Feb 2, 2011 at 4:20 PM
    ininerider
    So I checked and do have 4 leaf's...Can you point me in the right direction where to find info about how to set the front billsteins?
    Thanks!
  4. Feb 2, 2011 at 6:54 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
