TSB Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jgunccrugby, Nov 9, 2007.
  1. Nov 9, 2007 at 3:59 PM
    jgunccrugby
    jgunccrugby [OP] Well-Known Member
    Mount Holly, NC
    13 PreRunner SR5 DBL Cab
    Tacoma Seat Covers, Tacoma Kick Guards, Nerf Bars, Front window tint. To come: Bull Bar
    First I apologize for not completing a sucessful search of the issue. For some reason the search doesn't work right when I try to use it.
    Anyway,
    Can someone explain what this TSB is?
    I ask because I hauled 900-1000 lbs of materials this evening (about to add on to my patio) and it did some "odd" things but the only thing I really noticed was the feeling of it bottoming out from time to time and occasional rocking of the back end. However, I probably didn't exceed 50 mph. The truck did sit exceptionally lower in the back which didn't surprise me.
    Anyway, just wanted to get clarification on what exactly I was supposed to be looking for.
    Cheers
  2. Nov 9, 2007 at 4:08 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    TSB you are refering to is the rough ride when hauling stuff like you did it causing sagging in the back and it just doesnt feel right if you search some more you can find a pdf file on this print it out take it to your dealership and tell them exactly what happened. i did and they didnt find anything wrong with mine, which is bull
    heres the link i found http://mysite.verizon.net/vze2ndpp/photos/TSB-SU006-07.pdf
  3. Nov 9, 2007 at 5:58 PM
    bbarian333
    bbarian333 Well-Known Member
    SoCal
    06, Accesss Cab, TRD Sport
    TRD exh, K&N drop in,TRD seat cvrs,tsb springs
    Hey Socalman,What dealer did you take yours to? My dealers says there's nothing wrong with mine too. I'm in Moreno Valley. Your right it is BS . The TSB is based on a customers complaint , not their test drive.I have a meeting with the service rep from my dealer this week. I'm gonna raise hell. Whatever your dealer says Toyota will pay for the work . Its a TSB. If a dealer doesnt do it, its just because they dont want to. If mine doesnt get done here it will get done somewhere. Some dealers are ordering the parts with just a phone call.
  4. Nov 9, 2007 at 6:15 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    toyota san diego but i know for a fact they did not drive it on the freeway inside my truck vibrates alot and they just drove it on the street
  5. Nov 9, 2007 at 6:21 PM
    bbarian333
    SoCal
    The TSB says that your truck will have a rough ride over bumps and bad pavement with a load. I had a guy on here tell me that he took his to Carlsbad and they did the TSB for him. You might try them.
  6. Nov 9, 2007 at 6:23 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    yeah might have to go over to them
  7. Nov 9, 2007 at 9:26 PM
    nomowheelies
    nomowheelies Member
    Oceanside, California
    07 prerunner sr5
    fiberglass shell, thule racks, k&n drop-in, TSB suspension upgrade, sirius radio, 2.5" front coil-over spacer.
    thats correct, i took mine to toyota carlsbad, they ordered the parts and im now good to go....and just today, i had a 2.5" front coil spacer installed and it looks and rides sweet... night and day
    toyota carlsbad upgraded me with 4 bilsteins, swapped out my 3 leaf for a 4 leaf pack, and alligment......im happy
    let me know if you need any assistance on what to tell them...you have to play hardball...they test drove mine and said they found nothing wrong. But then told me they put no load in the truck.....so at this point, i got loud and they just gave up. good luck
  8. Nov 9, 2007 at 9:27 PM
    nomowheelies
    nomowheelies Member
    07 prerunner sr5
    i will update my photo with my new lifted truck.............its worth the hassle to get the upgrade
  9. Nov 10, 2007 at 11:55 AM
    bbarian333
    SoCal
    Just went to Home Depot bought 12 , 30 lb bags of gravel.My bed sank low . if i bounce on the bumber it bottoms , with less than 400lbs in it. What if i want to tow something? I did pay extra for the tow package. I'm taking it in on thurs. for them to evaluate whether or not i need the TSB. I'm taking it in with the load. Now im really mad since they told me nothing was wrong. I loaded it and found out there IS an issue. I bet they're gonna be supprised to see me drive in with my bed way down in the pavement.
  10. Nov 10, 2007 at 10:11 PM
    nomowheelies
    nomowheelies Member
    07 prerunner sr5
    you should wait until it gets dark, and throw sparks while driving thru the parking lot...........aw bad idea, dont want to start another California wild fire...............good luck, but you shouldnt have to do that. Dont let them pull your leg, they know about the TSB....................:mad:
  11. Nov 11, 2007 at 6:48 PM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    Also it may help to take a copy of the TSB in with you and point out that it's based on your complaint AND covered by your warranty, per toyota. Tell them if they won't take care of it then you'll call up Toyota yourself and see what they think about the dealer being unwilling to do warranty work. Toyota dealers CANNOT take complaints, they get reprimanded harshly for them. If they say they won't do it, just tell them you're filing a complaint about the dealer with Toyota and see what they say. It should definately work then!
  12. Nov 12, 2007 at 5:06 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    It doesn't make any sense. Toyota pays dealerships to do these TSBs. My dealership was eager to get this TSB done. :confused:
  13. Nov 12, 2007 at 7:04 AM
    jgunccrugby
    Mount Holly, NC
    Thanks for everyones feedback and input.
    I have to go in tomorrow to get them to claybar some areas where they oversprayed when it was in getting body work. I think I am going to wait a few months to get the TSB done so that I can time my alignment up with 1 year out.
    I bottomed out 5-6 times on Friday in the 5 miles between Lowes & my house.
    How long does it take them to do the update/upgrade after you request and they get the parts in?
  14. Nov 12, 2007 at 9:49 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I just got the call - my parts are in.
    They told me that it will take about 6-8 hours of work. They are giving me a loaner car for the day since they are also replacing my front rotors. I will know more tomorrow afternoon. :D
  15. Nov 12, 2007 at 10:39 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Congrats 007! i know you have been waiting for this forever! Glad to hear you're finally getting your suspension!
  16. Nov 12, 2007 at 4:39 PM
    bbarian333
    SoCal
    Hey, TuRDTACO. Iv'e already done just that, (filed a complaint with Toyota). after they denied me the TSB in the first place.They set up this meeting, with me, and the service manager. I wont be denied this time.I'm going in with an 800lbs load. the truck is supposed to handle 1380lbs. Its bottoming out all over the place. I have the TSB in hand with my model hightlighted on the paperwork. .
  17. Nov 12, 2007 at 7:52 PM
    TuRDTACO
    joliet, il
    i wouldnt wait at all if you keep bottoming out the suspension, is saving $100 for an alignment worth a couple grand in broken stuff if the dealer still wont do it?
  18. Nov 12, 2007 at 7:54 PM
    TuRDTACO
    joliet, il
    good to hear, and if the dealer still wont do it, threaten them with a visit from The Alliance, and let them know we'll be very pissed for having to drive to SoCal because they need to be yelled at
  19. Nov 13, 2007 at 2:33 PM
    jgunccrugby
    Mount Holly, NC
    I don't do that much hauling.
    I just tend to do heavy loads when I do.
  20. Nov 15, 2007 at 3:40 PM
    bbarian333
    SoCal
    Here's my update on round 2 with the dealer. Brought my truck in with a 760 lbs load. Had it bottom out on me in the dealers driveway. Now they had told me a toyota service rep was supposed to evaluate my truck. I left it there and when i came back they told me that i didnt need the TSB . They couldnt duplicate the bottoming out. I asked to speak with this rep . They told me i wasnt allowed to. BS. I lit into the customer relations mgr. It was bottoming out on me and im not even near the limit . I ask if i just needed to go buy more rocks till it does botttom for him. I'll be calling Toyota direct again. I let them know that i will be making lots of calls . Now this dealer previously had changed my address on my paperwork to prevent me from getting a cust review. Now i believe they told me my truck was being evaluated by a Toyota rep that i was not allowed to speak to (im sure that he doesnt exist). Saturday I'm taking it to the dealer where i bought it. Anybody in the SOCAL area. NEVER TAKE YOUR TRUCK TO MOSS BROS TOYOTA . THEY ARE SHADY.
