tsb rear leafs
Discussion in 'Suspension' started by JAMM, Dec 15, 2011.
  1. Dec 15, 2011 at 4:30 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    5100 bisteins front & rear ome885 front coils rear aal wheelers
    i am having the tsb rear leafs done on my 2010 tacoma . i already have a 2" aal on the rear and 885's ome on the front . will this added lift cause me any problems? also do i just shim up the front end to level out? again do you see any problems comming my way?
    jim
  2. Dec 15, 2011 at 5:00 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    You probably won't be as high as the stockers + 2" AAL.
    I would want my AAL's back from Toyota. They will want to keep the old springs.
    Usually the 2" AAL for stock is longer than the 1-1/2" AAL for TSB.
    You may be able to modify your AAL's for the TSB springs or sell them and get the AAL's designed for the TSB packs.
    I'm at 22" with the TSB's and a fiberglas canopy. You might get to 23" naked, with the TSB's for reference.
  3. Dec 16, 2011 at 2:54 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    JFLAN thanks for your input . With the 885's i have 3" of lift in the front end and with the 2" aal in the rear i have 23/4" lift. so if i gain 1" of lift with the tsb rear leafs . do you think i'll have any problems
  4. Dec 16, 2011 at 3:03 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    you wont get a full inch from the TSB pack. maybe 3/4 after it settles
  5. Dec 16, 2011 at 3:06 PM
    jandrews
    '09 FourDubDee TRD OR
    Most people get 1.5 to 2".
  6. Dec 16, 2011 at 3:21 PM
    pudge151
    Sean
    Connecticut
    i got just about 1" but it has settled.
  7. Dec 16, 2011 at 3:45 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    For about a month
  8. Dec 17, 2011 at 5:47 AM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    Thanks all for your input, so if i leave the 2" aal on plus the TSB leafs , resulting in 23/4 + 1" + or _ = 33/4 lift in the rear do you think i'll have problems ?
    Again thanks for your help I realize I'm asking the same question over
  9. Dec 17, 2011 at 5:52 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Did you photo or write down the part number of your rear leaf spring before the TSB?
    I have a 2010 DC, and the springs don't allow the truck to bottom. I am just curious if there is a difference between ones that do and mine. Did your truck bottom with a load before asking for the TSB? My 2005 DC did, so I know the feeling of one that needs spring help!
  10. Dec 17, 2011 at 6:00 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I did a set of tsb leafs for another member here at my shop, swapped over his 2" aal's, no problem in terms of lift issues, but the 2" aal's didnt want to fit the new leafs cause there are 2 extra brackets on the new leafs that i had to cut off to insatll the aals.
    On my truck i have the tsb leafs with the 1.5 toytec aal, it went right in with no cutting and i now sit 3" taller than stock in the rear.
    Edit: i see K9cop in here, his is the truck i installed the 2" on!!!
  11. Dec 17, 2011 at 6:01 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    I have the pro comp 3" lift. I had the rear tsb done about a month ago. They had to dismantle the tsb leaf pack to get the aal to fit. If not it would have hit the rivits holding those steel wraps around the pack, We did not put those back on either. When all was settled i got about 1/4 inch of lift from the new tsb pack. But then again they took it apart. A toyota master tech here on the site did it for me at his dealership. I love them!! That guy there^^^^^^^^^^^
  12. Dec 17, 2011 at 6:03 AM
    Toyota Tech31
    Debary, Florida
    :cool: :D :wave: :rofl:
  13. Dec 17, 2011 at 6:03 AM
    k9cop
    Farva
    Hogwarts
    LOL!!! Jinx
  14. Dec 17, 2011 at 6:04 AM
    k9cop
    Farva
    Hogwarts
    :eek::eek::eek:
  15. Dec 17, 2011 at 6:04 AM
    Toyota Tech31
    Debary, Florida
    thats freakin hilarious!
  16. Dec 17, 2011 at 10:03 AM
    Tacoma Mike
    Southern Maine
    Yea Jason told me this story. Was quite involved.
    He's had his quota of compliments for the year now. :cheers:
    Good job..........
  17. Dec 17, 2011 at 10:44 AM
    jflan
    Vancouver, WA
    OP, good data right here.
    1. Get the TSB and recover your old AAL's (or not)
    2. You will probably be at 22" + after the TSB and will need more to match (or exceed) your 23" (guessing) in the front.
    3. I would get the TSB AAL's from Toytec. They're 28" long and will bolt right in. *Long end to the rear.
    Your old AAL's could probably be cut down to fit the TSB packs, but I'd probably just sell them off.
    For reference there is 33" between the leaf retainers on the TSB, that is why the ToyTec (Deaver) TSB is 28"
    The stock spring must have had more space between retainers because the AAL for stock seems to be reported at 32".
    32" into the 33" space would be too tight. You could cut it down but it would be trial and error as far as the resulting spring rate.
  18. Dec 18, 2011 at 5:45 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    Good input thanks, My truck was bottoming out that's why i added the 2" aal and the 885 OME coils in the front
    So I'll get my 2" aal's back if they don't fit and either cut them or by the 11/2" AAL'S
    GOOD DEAL
    Did anyone have any problems with 3" or 4" of lift ? , as far as drive train or front A arm travel with 3" of lift
  19. Dec 18, 2011 at 6:12 PM
    jflan
    Vancouver, WA
    Your front half shaft angles start getting steep as you approach 3".
    CV joints, CV boots and bearings can get unhappy....YMMV.
