TSB udate
Discussion in '3rd Gen. Tacomas (2016+)' started by Beshaw1221, Mar 6, 2021.
  1. Mar 6, 2021 at 2:24 AM
    Beshaw1221
    Beshaw1221 [OP] Well-Known Member
    Bruce
    2019 Tacoma TRDOR DCLB cement
    So I am going to attempt the 04B31 to 04B33 flash today. I think I. Have everything. Needed to proceed except a battery support unit. I’m sure there are many out there who have done this on their own so what exactly should I get without spending a grand. Ive heard once you start flashing it can really drop your volts.
  2. Mar 6, 2021 at 2:25 AM
    Beshaw1221
    Bruce
    Is it even worth trying my toyo dealer first to see if they will do it?
  3. Mar 6, 2021 at 4:26 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR Super White M/T
    OVTuned, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper
    If you have the Tactrix cable and Techstream it should take 5-10 minutes. Turn off ALL aux power (headlight, dome lights, radio, etc). Double click your .cuw file and follow the instructions. Super easy.
    If you're nervous, ask your dealer to do it.
    tonered likes this.
  4. Mar 6, 2021 at 4:39 AM
    Beshaw1221
    Bruce
    I have the new open port 2 cable I got with my VF tune kit from OV.
  5. Mar 6, 2021 at 4:40 AM
    Beshaw1221
    Bruce
    I assume that’s the new tactic cable
  6. Mar 6, 2021 at 4:41 AM
    Beshaw1221
    Bruce
    I am nervous but also don’t want to mess around with the dealer. From everything I’ve read it’s hit or miss on whether they will do the update
  7. Mar 6, 2021 at 4:44 AM
    Dank Donkeh Luvver
    Eric
    Maryland
    Yes thats the right cable.
    tonered likes this.
  8. Mar 6, 2021 at 5:08 AM
    Beshaw1221
    Bruce
    So you did yours without a battery saver?
  9. Mar 6, 2021 at 5:22 AM
    gForceDude
    gForceDude High Miles & Big Smiles
    Dude
    Kitsap Penninsula, Washington State
    2020 TRD OR AC V6/AT
    ECU Update 04B81 265/75/R16C Shoes Happy & Content
    https://www.amazon.com/NOCO-GENIUS10-Fully-Automatic-Temperature-Compensation/dp/B07W3QT226
    This one has a "12 Volt Supply" Mode specifically for holding a battery at the proper 13.8 vdc during a flash.
    Made in America, built like a tank, works beautifully.
    VB25, tonered and RustyGreen like this.
  10. Mar 6, 2021 at 5:24 AM
    Beshaw1221
    Bruce
    You used it for flashing?
  11. Mar 6, 2021 at 5:30 AM
    gForceDude
    Dude
    Yes, that is specifically what I got it for.
  12. Mar 6, 2021 at 5:40 AM
    Beshaw1221
    Bruce
    Cool. Thanks for the info
    gForceDude likes this.
  13. Mar 6, 2021 at 5:53 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Paint Protection, Borla S-Type Catback Exhaust ME-SO Customs Gasshole ME-SO Customs Total Tails Stage 1 ME-SO Customs Ultimate LED Turn Signals V4 HELLA Supertones OVTuned 2.0 2LO Mod 16x8 0mm Enkei RPT1 Wheels in Titanium Gold Diode Dynamics SS3 Pro Foglights HPS Intake Hose
    Don't worry about your battery. You should be fine. Just make sure your hood is open.
    AND... turn off ALL accessories. Lights, radio, HVAC, BSD, Park Assist, Heated Seats, etc.
    And make sure your hood is open.
    Skydvrr and tonered like this.
  14. Mar 6, 2021 at 6:45 AM
    Beshaw1221
    Bruce
    Sounds good. Thank you
  15. Mar 6, 2021 at 6:45 AM
    Dank Donkeh Luvver
    Eric
    Maryland
    Ive done TSBs on 6 or 7 trucks without using a battery maintainer and never had an issue. Im pretty sure thats the case for most guys on here as well.
    I always check the battery with my multimeter first and make sure its 12V+ before doing anything else.
    If youre really worried you can use a maintainer or hook your truck up to a running car via jumpers.
    tonered likes this.
  16. Mar 6, 2021 at 6:47 AM
    Beshaw1221
    Bruce
    Sounds good. Just learning the ropes
  17. Mar 6, 2021 at 6:49 AM
    ktbell444
    ktbell444 As lost as a lieutenant during land nav
    Karl
    GA / FL
    2020 Tacoma TRD Pro - Army Green
    That's the exact one I use. Works like a charm!
  18. Mar 6, 2021 at 6:50 AM
    Beshaw1221
    Bruce
    Perfect
  19. Mar 6, 2021 at 7:07 AM
    gForceDude
    Dude
    The Official Toyota Instructions for an ECU Update/Flash require a battery maintainer, for good reason.
    https://www.tacomaworld.com/attachments/tsb-0134-16-ecu-flash-instructions-pdf.4048047/
    "Battery voltage MUST NOT FALL BELOW 11.8V during reprogramming."
    "The DCA-8000 battery diagnostic tool MUST be used in Power Supply Mode to maintain battery voltage at 13.5V while flash reprogramming the vehicle."
    If the battery voltage falls below 11.8vdc during a flash, the update will fail, and you may 'brick' your ECU as a result.
    Most never even read the above Official Toyota Instructions before doing their first flash - ignorance is bliss, at least until the battery does indeed fall below 11.8vdc, and the ECU is rendered useless and the truck won't even start (this happened here just recently). Do you feel lucky?
    I wear a seatbelt when I drive, just in case; and I use a battery maintainer when I flash, just in case.
    It is also a very good tool to have, for lots of uses besides just flashing.
    ktbell444 likes this.
  20. Mar 6, 2021 at 7:49 AM
    Beshaw1221
    Bruce
    Thanks so much
