TSB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sartybunch, May 4, 2021.
  1. May 4, 2021 at 8:50 PM
    sartybunch
    sartybunch [OP] Member
    2019 Tacoma Sport
    What is TSB and what does it do for my 2019 Taco?
  2. May 4, 2021 at 8:52 PM
    tcjacado
    tcjacado Well-Known Member
    Its a "technical service bulletin "
    And it fixes a issue with the truck.
    Tsb's and recalls are not the same.
    Chew, shakerhood and waltuo like this.
  3. May 4, 2021 at 8:53 PM
    JCH
    JCH Well-Known Member
    Justin
    Colorado
    2021 TRD Off-road
    A TSB is a Technical Service Bulletin. Essentially they are fixes that Toyota has put out for issues that people may have with their truck. Most likely you have heard of some of the transmission TSBs that are out for third gen Tacomas that change the shifting behavior.
  4. May 4, 2021 at 9:00 PM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
  5. May 4, 2021 at 9:10 PM
    sartybunch
    2019 Tacoma Sport
    Where can I find out if there is a TSB for my model, and do you have to pay for a dealer to perform TSB maintenance?
  6. May 7, 2021 at 8:50 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    In my case is a free clutch pedal assembly replacement (because of squeaking).
    Very useful thing, IMO. Just follow the timelines. And yes, TSB and recalls are different things.
    Good luck!
