TSB's and recalls - can we get a sticky with links to them?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Feb 22, 2008.
  1. Feb 22, 2008 at 6:42 AM
    cycledrum
    cycledrum [OP] Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    Can we get a sticky thread here with links to all the TSB's and recalls (if any) for all Gen 2 Tacomas ?
  2. Feb 22, 2008 at 7:58 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    id
    su002-05 Rear Suspension Spring Noise
    Pd038-04 Pre-delivery Service (pds) 2004-09-10
    Pd039-04 Initial Calibration Of Compass 2004-08-10
    Tc006-03r Introduction Of New Automatic Transmission Fluid - Revised 2004-12-03
    Pd008-05 Power System Initialization During Pds And After Battery Disconnect 2005-01-27
    Eg045-04r Entering Vin During Ecm (pcm) Replacement And/or Dtc P0630 - Revised 2005-01-24
    Bo003-05 Overfender Refinish Process 2005-03-09
    Bo004-05 Front Cowl Water Leak Repair Procedure 2005-03-17
    Eg014-05 Radiator Cap Inspection 2005-03-28
    Pg002-05 Tire Positioning Before New Vehicle Delivery 2005-03-02
    Ss001-05 Failure To Initialize Can Interface Module 2005-03-11
    Bo004-05r Front Cowl Water Leak Repair Procedure - Revised 2005-04-25
    Pd036-04 Front And Rear License Plate Installation 2004-08-30
    Bg045-04r Entering Vin During Ecm (pcm) Replacement And/or Dtc P0630 - Revised 2005-06-03
    Ss001-05r Tools - Failure To Initialize Can Interface Module - Revised 2005-06-23
    Ax004-05 Skid Plate Vibration 2005-07-20 Nv007-05 Cab Mount Noise Improvement 2005-06-28
    Pg017-02r Battery Maintenance For In-stock Vehicles & Pre-delivery - Revised 2005-06-28
    Au001-05r Parasitic Draw From Jbl Amplifier - Revised 2005-08-19
    Au001-05 Parasitic Draw From Jbl Amplifier 2005-08-02
    Eg034-05 Excessive Sulfur Dioxide Odor 2005-08-22
    Ss003-02r Diagnostic Tester Immobilizer Tester Functions - Revised 2005-08-26
    Eg037-05r Mil On Dtc P0456 Or P0455, And P0441 - Revised 2005-09-16
    Eg037-05 Mil On Dtc P0456 Or P0455, And P0441 2005-09-01
    Eg043-05 No Start In Sub-freezing Ambient Air Temperatures - Possible Dtc P0300, P0171, P0174 2005-09-28
    Pg005-03r Spare Tire Carrier Operation - Revised 2005-09-27
    Bo004-07 Bent Tailgate Fix
  3. Feb 22, 2008 at 8:00 AM
    surfsupl
    Gregg
    WestCoast
  4. Feb 22, 2008 at 11:37 AM
    wrxed96
    wrxed96 Well-Known Member
