TSS Recall -- New document from Toyota regarding trucks with "Pro" grills or lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Arrieta578, May 7, 2019.
  1. May 10, 2019 at 3:17 PM
    #121
    OR4x4
    OR4x4 Well-Known Member
    Portland, OR
    2018 DCLB 4x4 TRD-OR Super White
    Yeah I know that when you rear end someone, the overwhelming majority of times it is your fault. But there are some instances when it can be equal liability or liability of the braking driver if there was no reason to brake. At speed, even if you are not tailgating, you can hit someone in the back if they emergency brake. That instance is rare.
    You are absolutely right, your case is the more likely scenario. Either way, I'm not going to put my liability on the table unless I have to. And getting this Toyota fix seems like an easy task without many downsides (I don't want a Pro grill anyway).
  2. May 10, 2019 at 4:07 PM
    #122
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    That is what I'd like to know too. It seems to me that if they can turn it off, then one should be able to turn it back on! Look at my profile pic, and you can see that I have a TRD Sport with the TRD Pro grill that I switched out. The only thing I have noticed since swapping it, was every once in a while, the PCS light will come on in the dash, saying the PCS system is off. It stays lit until I turn off the ignition and turn it back on again. this has happened about half a dozen times or so since i swapped grills. I am assuming it is something that will take care of itself with the sensor system "learning" about the different sensor cover that is on the TRD grill. In any case, "Robmotive" on Youtube, just posted a great video about this very thing, a couple of days ago. The guy does a great job with his videos, so I highly recommend you check it out, as it will be very helpful. Here it is:
    https://www.youtube.com/watch?v=8FhZ9_mE984
    KY_Rob and OR4x4 like this.
  3. May 10, 2019 at 5:05 PM
    #123
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    I asked my dealer this morning how much a bug deflector was when I was in grabbing a touch up pen. He said because mine is a 2018 they don’t make a bug deflector for it because of the sensor..... meanwhile there were 3 new ones on the lot with bug deflectors.
    taco_boy and OR4x4 like this.
  4. May 11, 2019 at 2:21 AM
    #124
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    I dont see how a bug deflector has a ythi g to do with the tss sensor.
    cowsquatch67 and mgmdclb like this.
  5. May 11, 2019 at 2:56 AM
    #125
    mgmdclb
    2018 MGM DCLB Sport
    It doesn’t, I just kind of said hmm and left.
  6. May 11, 2019 at 4:51 AM
    #126
    oogielaflick
    Keith
    I don't know if you were referring to a bug deflector or a hood protector, but I am guessing a bug deflector. In that case, I put one on my new 2019 Tacoma TRD Sport. It will fit on the 2018 as well. It was incredibly easy to install, in less than 5 minutes, and I just think it looks insanely cool! Check out my profile pic and you will see it. But here is the direct link to order one for yourself!
    Hood deflector
    https://www.amazon.com/gp/product/B018AIGTGC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  7. May 11, 2019 at 4:53 AM
    #127
    Vanderjdm
    Vanderjdm Well-Known Member
    2018 Off Road
    5% Tint, ARE V-Series w/ Yack Rack, Ebay Grill, Emblem Black Out Kit, Bumpershellz, Predator Tube Steps, Radioknobs by Tacowiede, Kicker Speaker Upgrade
    Any impact on mpg?
  8. May 11, 2019 at 4:59 AM
    #128
    oogielaflick
    Keith
    If so, it is negligible. It barely sticks up, and pretty much hugs the curves of the hood. It is not like some of those out there for other makes, that actually "stick up" in the air, in which case, I could definitely see an effect on mpg on a trip. around town though, certainly nothing would be noticeable.
  9. May 11, 2019 at 8:08 AM
    #129
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Everyone keeps talking about the fix and weather they like it on not.
    Where is this big ass sticker that supposedly goes on the dash? That’s what I wanna see.
  10. May 11, 2019 at 8:20 AM
    #130
    hazey
    hazey Active Member
    2019 DCOR MGM
    They make recommend you do, but II can't imagine they would make you put a sticker on your dash. It's all documented on the back end anyways. If it wasn't and Toyota was that stupid, someone could easily take the sticker off and then say the dealer is liable because they did it.
    I think a big question is if you put the recall patch on, does this make your grill not modifiable moving forward?
    Hafaday likes this.
  11. May 12, 2019 at 5:34 AM
    #131
    Jdottav2259
    Jdottav2259 Well-Known Member
    Josh
    Ellwood City, Pennsylvania
    2018 TRD Off Road DCSB
    •2”/1” Rough Country Level •265/75 MT Baja ATZ •Running Board removal •Tailgate Letter Inlays •Window Tint •Tonneau Cover •Debadged •TRD Pro Grille swap •MBRP S5340 Exhaust
    I just had this recall completed Friday on my 2018 in New Castle, PA. After lifting the truck last summer, the TSS malfunction message was on consistently. Dealer claimed it was my fault and there was nothing I could do other than remove my lift and tires...go figure . So obviously I said screw it and dealt with it for almost a year.
    After the recall service Friday, the light/message has been off ever since. Not sure what they did but it’s not on any more. I did however have to sign the “waiver” from Toyota stating my truck is modified and the sensor has been permanently disabled. The Tech was courteous and put the sticker in my manual rather than on my dash.
    Hafaday likes this.
  12. May 12, 2019 at 7:04 AM
    #132
    taco_boy
    taco_boy Antiplastidipper
    California/Land of the Fee
    2018 Tacoma TRD On Road MT
    Noob Taco owner
    So it's just a sticker on the back side of the sensor? As for documentation, I like how every "inspection" that's done is pencil whipped. I've been running a little larger MT tire with more psi but they've been writing what's posted on the door sill. This tells me how much I should trust the techs.
    Hafaday likes this.
  13. May 14, 2019 at 10:00 AM
    #133
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    I got my 2018 OR back Friday. I was told "your truck is a bit of a special case, but it's all done. They sealed the sensor and flashed the computer." When I pressed the service manager about it, she had no clue what was re-flashed, then retreated to "re-calibrated." It looks like the dealer never took the sensor off my truck, so I can't tell what was sealed up. No foam or anything was put over the back of the sensor, and I didn't have to sign anything.
    I see some had a piece installed behind the sensor, others have the pen lashing. For those with a Pro, what did your update include?
  14. May 14, 2019 at 10:53 AM
    #134
    jrcuevasv
    jrcuevasv Well-Known Member
    2018 TRD Off-Road
    They had me sign that waiver after performing the TSB. Whichbwas nothing more then some foam/plastic on the back of the sensor to prevent water intrusion
  15. May 14, 2019 at 7:36 PM
    #135
    deebs17
    deebs17 Well-Known Member
    2018 White Tacoma TRD Sport DCLB
    I hope this helps someone here. I live in Salt Lake City, UT and took my truck in for service a few weeks ago. I was informed of the SSC on my truck and was told they would order the parts. I scheduled my appointment and then saw this thread on TW. I was interested because I have changed my grille to the pro style grille. I took it in today and the SSC was done. They didn’t require any waiver to be signed. So if you are worried about signing a waiver and are in the Salt Lake area, check out Karl Malone Toyota in Draper. Same band-aid fix, but no questions asked or waivers signed.
  16. May 14, 2019 at 7:53 PM
    #136
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    I think the issue is specific to pro style grills AND a lift both present. Either a lift OR a pro grill has not been an issue
    deebs17[QUOTED] likes this.
  17. May 14, 2019 at 8:18 PM
    #137
    deebs17
    Good to know. I just saw some posts saying that the dealer used their grille as the excuse not to perform the SSC. It didn’t specify whether or not they had a lift. My dealer didn’t even mention it, so they might be more lenient for other issues OP mentioned.
  18. May 14, 2019 at 8:37 PM
    #138
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Do you also get the dash stickers that say 'don't put your carpet on top of your gas pedal' and 'don't push the gas pedal when your intention is to push the brake pedal'?
    Really??? They're going to apply a dash sticker to try and cover themselves and release their liability?
  19. May 14, 2019 at 8:39 PM
    #139
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    I think a dash sticker that says "don't drive like an asshole" would get better results. :crazy:
    TimC likes this.
  20. May 14, 2019 at 8:59 PM
    #140
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    I have a pro knockoff grill and no lift. Toyota Escondido balked at doing mine, but couldn't tell that the grill wasn't oem.
    deebs17 likes this.
