Tube Bumper Questions, ...please help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco_Rock, Sep 25, 2011.
  1. Sep 25, 2011 at 7:00 PM
    Taco_Rock
    Taco_Rock [OP] Member
    I am getting some tube bumpers built at and am wondering a few things.
    1. What type of steel is best and why. (e.g. is it worth it to use chrome moly tubing if it is not much more $$$? ...DOM, ...cold versus heart treated?
    ...Does this person know what they are talking about? see link ---> http://www.xxxoffroad.com/index.php...-name-dom-erw-hrew&catid=31:general&Itemid=46
    2. Pros and cons of bolt on versus weld on, versus bolt on with spot welds to prevent stealing and enhance strregth
    3. Pros and cons of plate versus tube bumpers
    Any other advice regarding things that are important to consider in the bumper building process would be greatly appreciated.
    Thanks
  2. Sep 25, 2011 at 7:08 PM
    jandrews
    '09 FourDubDee TRD OR
    1) "Best" depends on the properties you want from the steel. Most 1020 DOM is the best balance of price and strength for most people. The link you referenced is accurate, yes.
    2) Either works. Bolt on is more easily removable and I have no reason to believe it's any less strong if done correctly.
    3) Plates are heavier and generally provide more coverage. Tube is typically lighter and often offers the best approach angles. Usually less expensive as well.
  3. Sep 25, 2011 at 7:18 PM
    Taco_Rock
    Thanks for the reply,
    I am prob going with tube, ...and really like the look and price of the All Pro front and back bumpers (with headlight hoops and fill plates), and a long skid plate.
    From my BMX days i remember chrome moly being far superior in strength and weight to "regular steel", ...how much more $$ as a percentage would it be worth to pay for chrome moly?
    Essentially I am having a local shop build me some custom bumpers that look like the All Pro ones, and a skid plate out of aluminum instead of steel.
    ...any thoughts on the functionality and configuration of the All Pro style of bumper or skid plates??
    ...any other styles/brands worth considering? ...as a final consideration, ...what are the effects if any, on gas mileage with tube bumpers
    Thanks
  4. Sep 25, 2011 at 7:21 PM
    jandrews
    I wouldn't touch any of All-Pro's armor. Just about anyone around here can tell you why. If you're having it replicated by another fabricator that's a different story, although how legal it is I'm not sure.
    Any steel bumper, tube or not, is going to lower mileage some. Extra weight is extra weight.
  5. Sep 25, 2011 at 7:22 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    im assuming you have a 95-04 from the links though you didnt post specifically
    for other styles/ideas you can check out cbi offroad, badlands bumpers, 4xinnovations
    theres a hundred or more different companies probably that make tube bumpers for 1st gen tacomas
    as far as skids go...budbuilt and ATO make some of the most bulletproof stuff you can buy...usually at prices that you cant beat even going semi-custom fab
  6. Sep 25, 2011 at 7:22 PM
    Taco_Rock
    ...I just saw your link re: the bullet proof bumpers,
    pretty damn cool stuff,
    ...anything for 1st gens?
    IIRC the guy at All Pro said they use heat rolled, ...according to the article linked in the OP that is the worst
    ...any thoughts?
  7. Sep 25, 2011 at 7:24 PM
    Taco_Rock
    Legal??? ..please explain
  8. Sep 25, 2011 at 7:24 PM
    jandrews
    Unfortunately no, and no plans in that arena.
    Tiger is spot on - I'd look at CBI or 4xInnovations for 1st gen products.
    Doesn't surprise me.
    If All-Pro has patented the design, it may not be legal for another fabricator to duplicate it and sell it to you. Whether or not that's the case, I don't know. Regardless, it's between you three - I just post here.
  9. Sep 25, 2011 at 7:25 PM
    JimBeam
    JB
    2015 Tundra
    for what it is...all-poo does fine...they make stuff for the guy who rides dirt roads and calls it wheeling...
    if you're planning on bumping up against rocks/trees/small children and want something to withstand it...
    I'm a firm believer in over-building tho rather than just good enough and to that regard either DOM or chromoly is what you want...but i'm not sure what the price difference is for dom v. chromoly
  10. Sep 25, 2011 at 7:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Check the vendors area. Lots a tube bumpers and they will make it for you.
    I like plates better tho..IMPO
  11. Sep 25, 2011 at 7:34 PM
    Taco_Rock
    I am a firm believer in overbuilding as well, ...however,
    My rig is definitely not a rock crawling rig, nor do I plan on hitting rocks on a regular basis.
    I use it mostly for hunting trips into the deep backcountry of Oregon, Utah, and Wyoming.
    I just need some damn solid bumpers.
    ...the reason for the bumper upgrade is that the stock bumpers are flimsy and driving the point home, I recently dented my truck when my stock bumper actually slid up into my rear quarter panel on impact with a steep drop in,
    ...I think the stock bumper strategically slid out of the way to protect itself,
    ...shipping costs for two bumpers and a skid plate, and the trustworthyness of the local builder are the reason for going local
  12. Sep 25, 2011 at 7:51 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    When it comes time, I am going with a Trail-gear low-profile bumper.
    They have a good reputation and are much cheaper than AP...And they use DOM tubing.
  13. Sep 25, 2011 at 7:54 PM
    JimBeam
    JB
    2015 Tundra
    TG has a great reputation? Where?
  14. Sep 25, 2011 at 8:11 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I have had several people recommend them on TW, especially compared to AP.
    And most of the tube bumpers out there are pretty fugly IMO. Excluding Allpro and TG..
  15. Sep 25, 2011 at 8:17 PM
    JimBeam
    JB
    2015 Tundra
    If looks are everything then by all means
    My money will never go to TG...ever
  16. Sep 25, 2011 at 8:21 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I never said looks are everything...I just dont want to put a bumper that looks like ass on my truck..
    And why never TG?
  17. Sep 25, 2011 at 8:24 PM
    JimBeam
    JB
    2015 Tundra
    For a long time, TG routinely would use other peoples designs, inferior materials, and there was a big scandal involving them and improper trail use
    There are other companies out there that have never been accused or done any of that who I'll gladly support before TG...regardless of the cost difference
  18. Sep 25, 2011 at 8:27 PM
    TacoMX
    Jonathan
    Deltona, Florida
    hmm, thanks for the info. Any other recommendations for a tube bumper?
    and sorry for the threadjack
    :threadjacked:
  19. Sep 25, 2011 at 8:29 PM
    JimBeam
    JB
    2015 Tundra
    No biggie
    If you like em...fine...no skin off my back...but I wont use them
    CBI makes a fine quality product with great customer service...as does 4xinnovations
  20. Sep 25, 2011 at 8:29 PM
    JimBeam
    JB
    2015 Tundra
    Badlands Bumpers (if theyre still around) makes a helluva set of tube bumpers
