Tube Steps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phil217, Jul 29, 2011.
  1. Jul 29, 2011 at 9:23 AM
    phil217
    phil217 [OP] Well-Known Member
    Phil
    Seattle
    09 DC LB Silver Tacoma
    Anyone know where I can get some Tube Steps for a 2009 DC LB Tacoma? The genuine Toyota ones?
  2. Jul 29, 2011 at 9:37 AM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    Dealer wanted to charge about $450 for a set of DBL Cab LB genuine toyota black tube steps. I took a print out of this to the dealer and asked them to price match it. They did with no problem They even honored a coupe I had from them to take an additional 10% off purchases over $100....so I got the steps for about $345 (no shipping cost).
    http://www.toyotaparts4u.com/scripts/prodView.asp?idproduct=329812
    Hope this helps!
  3. Jul 29, 2011 at 9:52 AM
    phil217
    Phil
    Seattle
    Say it only fits an 11...I gonna check and see if it will work on an 09...cant imagine it wont!
  4. Jul 29, 2011 at 10:01 AM
    AbqTRD2010
    Michael
    Rio Rancho, NM
    They fit perfect on the 05+ long beds. Just unscrew out the plastic tabs below the truck and screw in the steps. Very easy install and perfect line up to the original holes. Those are the exact ones I used for my 2010. They no longer make the greyish colored ones, only selling the black. The black tubes are original for 2011 but fit all models, just make sure you order the long bed so that you get the extended length at the end.
    I agree the N-fab are cheeper in price but I liked the look of the OEM Tubes better. I perfered how close they fit against the truck (minimal gap) and the tucked in look compare to the step hanging down... just a preference of mine.
    The black tubes are powder coated so they shouldnt have the same chipping issue that I saw on many of the grayish OEM tube steps after a few years.
  5. Jul 29, 2011 at 10:29 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    i bought 4" oval westin platinum(black) from Autoanything.com for $190.00. took less than an hour to install.
  6. Jul 29, 2011 at 10:40 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you should check out avidoffroad.com
    great products, they look sweet too!
  7. Jul 29, 2011 at 10:43 AM
    phil217
    Phil
    Seattle
    Thanks everyone! I just ordered them and my local dealer did a price match! Thanks for the great tips!
