Tundra brake kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoreysIRTaco, Nov 1, 2019.
  1. Nov 1, 2019 at 11:15 PM
    CoreysIRTaco
    CoreysIRTaco [OP] Well-Known Member
    Corey
    2004 Tacoma DC TRD
    None
    Anyone got links to some? Also, will they fit fine or am I going to have to tinker with them to make them fit...?
  2. Nov 2, 2019 at 8:33 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    CoreysIRTaco[OP] likes this.
  3. Nov 2, 2019 at 8:43 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    There are a couple ways to go with this upgrade - you can do a kit, but IMO you get better results (braking) by going with OEM (or OEM reman) components. You can read about my experience in the links below... "tinkering" is going to depend on the quality of parts you get, so is a bit unpredictable.
    I should say that I first installed 13WLs with no problem using Wheelers banjos and they worked great for a year. That's this post:
    New-to-me Tires and a Tundra Brake Upgrade (and here's a good argument/data about going with quality components)
    On a trip this year, when I was running the Lolo Motorway, I had a caliper seize up on me. I had to replace it on the trail. That's here:
    IDBDR Pt. 7 - The Curse of the Lolo Motorway
    After the trip, I thought a bit about my repair experience (above), and how I got into the situation in the first place. That is this Rig Review:
    Rig Review: Idaho July 2019 - What worked and what didn't?
    Finally, I decided to go a different route than the Wheelers banjo lines. I decided that doing the job "right" (or maybe, "completely"?) was the best approach. Here:
    Making It Right: Tacoma-to-Tundra Brake Upgrade
    Shoot if you have questions. Reach out if you want a hardline kit for way less than LCE.
  4. Nov 2, 2019 at 3:37 PM
    CoreysIRTaco
    Corey
    2004 Tacoma DC TRD
    None
    opteron[QUOTED] likes this.
  5. Nov 3, 2019 at 3:37 AM
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    No you would need rotors, brake lines, and brake fluid
  6. Nov 4, 2019 at 6:14 PM
    CoreysIRTaco
    Corey
    2004 Tacoma DC TRD
    None
    Off a tundra as well?
  7. Nov 4, 2019 at 6:28 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
  8. Nov 4, 2019 at 6:53 PM
    rj15tacoma
    rj15tacoma Well-Known Member
    You don't need brake lines. I just did the upgrade 2 months ago. Use a 1/4" bit and drill into the banjo bolt a little. use OEM tundra 13wl calipers off of a donor truck and buy a rebuild kit for 15 bucks. Trust me, I did this all oem and have had zero problems.
  9. Nov 4, 2019 at 8:22 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I get the sense that you didn't click on any of my links above that go into great detail about this mod, with part numbers. I'll try one more time, but I still recommend reading the links since they have instructions as well.
  10. Nov 4, 2019 at 11:00 PM
    CoreysIRTaco
    Corey
    2004 Tacoma DC TRD
    None
    Your Jedi senses are correct. I previously just wanted a straight forward response.
  11. Nov 5, 2019 at 6:27 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Caliper rebuilding is very easy!!!
  12. Nov 5, 2019 at 6:30 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I concur, I drilled out my banjo boots 2 years ago. Zero issues since.
  13. Nov 5, 2019 at 7:24 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
