Tundra brake upgrade- banjo bolt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Jan 1, 2014.
  1. Jan 1, 2014 at 10:45 AM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    So I am familiar with the upgrade via all the commonly used links and have read them all. I am about to do the swap to 231mm WL calipers when the parts come. I was wondering what exactly needs to be done in order to modify the banjo bolt. I am still not clear as to what should be drilled out and by how much.
  2. Jan 1, 2014 at 1:48 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Banjo connection below. As opposed to a standard compression fitting (not shown)
    Another Banjo connection
  3. Jan 1, 2014 at 2:32 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im not sure what needs to be done for the stock brake line but I highly suggest you get the steel lines to prevent squishy brakes.
  4. Jan 1, 2014 at 3:18 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Standard double flare! Compression fittings are for sinks, not brake lines
    cruiserguy likes this.
  5. Jan 1, 2014 at 4:56 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
  6. Jan 1, 2014 at 7:43 PM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    If you just buy new brake lines from a place like then you don't have to anything but swap the lines out since they bolt right up and no drilling required.
  7. Jan 2, 2014 at 4:24 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  8. Jan 2, 2014 at 9:58 AM
    RattleTractor
    Harry
    VT
    Thanks for the help. Those stainless lines from Wheeler's are nice I'll probably have to get those if the shipping time isn't too long. I'm on a tight schedule to finish the brakes before next Friday.
  9. Jan 2, 2014 at 10:41 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    If is unable to meet your timeline, you might consider one of the other vendors from whom quality Goodridge G-Stop Brake Lines are available. (FWIW, mine came from THMotorsports.)
  10. Jan 2, 2014 at 10:51 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i have the 13WL calipers on my tacoma and tried to modify the stock banjo bolts, but could only get one side to seal correctly. ended up purchasing the wheeler's stainless lines and they bolted up with zero modifications and zero problems. i highly recommend going that route.
  11. Jun 21, 2019 at 5:18 AM
    Radhames
    Radhames New Member
    Radhames
    2002 Tacoma
    None
    For what vehicle do you buy the ss lines, tundra or tacoma and what year?
    Thanks
  12. Jun 21, 2019 at 5:33 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
  13. Jun 21, 2019 at 5:58 AM
    Radhames
    Radhames New Member
    Radhames
    2002 Tacoma
    None
    Thanks. I’m new here, let me see if I can find it.
  14. Jun 21, 2019 at 8:32 AM
    tacotime1
    tacotime1 Well-Known Member
    Why not just use the stock hardline into the caliper? Don’t the Tacoma’s come with hardline flares into the caliper?
  15. Jun 21, 2019 at 8:48 AM
    Radhames
    Radhames New Member
    Radhames
    2002 Tacoma
    None
    I’ll go with stock lines and do mods to the banjo bolt. I did the install and had to take it off again. The one of the calipers what locked, I’m thinking because I used the stock banjo bolt with no mods. I’ll try it again with the bolt drilled. Thank you.
  16. Jun 21, 2019 at 1:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Tacomas do not have stock hardlines. The Tacoma has a soft line and a banjo bolt setup.
  17. Jun 21, 2019 at 1:36 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Drill the center of the bolt to match the shape of the compression flare in the caliper.
  18. Jun 21, 2019 at 1:39 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  19. Jun 21, 2019 at 1:41 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Did mine this way 2 years ago, no leaks or problems
  20. Jun 21, 2019 at 1:42 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    cruiserguy and Wsidr1 like this.
