tune up
Discussion in 'Performance and Tuning' started by Blacktaco2042, Jun 21, 2014.
  1. Jun 21, 2014 at 2:12 PM
    Blacktaco2042
    Blacktaco2042 [OP] Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    has anyone ever had to do a tune up on a s/c tacoma?
    it looks like the s/c has to came off to get the driver side plugs out am i right?
    let me know what you think
  2. Jun 22, 2014 at 8:06 AM
    Blacktaco2042
    wisconsin
    no one?
    05+ tacoma just looking for ideas before i start ripping it apart
  3. Jun 22, 2014 at 10:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Jun 22, 2014 at 3:02 PM
    Blacktaco2042
    wisconsin
    yea thats on order but wondering how much of a pita it will be to do the plugs
  5. Jun 22, 2014 at 3:52 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I think removing the trd blower for a spark plug change is a cake walk vs changing the fuel pump... It is possible to change the driver side with 3 extensions and a 1/4 inch socket wrench though; I've done both; prefer blower removal
  6. Jun 22, 2014 at 5:51 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The TRD S/C kit includes 6 iridium-tipped spark plugs if I remember correctly. Should be good for 100k. You've put on that many miles since installing the S/C?
  7. Jun 22, 2014 at 8:32 PM
    Blacktaco2042
    wisconsin
    9700 miles i was looking at the truck and was wow its really tight in there and started wondering do i have to remove the s/c to do the plugs or can i squeak them by without removing it
  8. Jun 22, 2014 at 8:33 PM
    Blacktaco2042
    wisconsin
    how did you do it without removal? just wondering
  9. Jun 22, 2014 at 11:15 PM
    TRON
  10. Jun 23, 2014 at 3:50 AM
    Blacktaco2042
    wisconsin
    nice guess you dont have to remove it then
