Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Aug 15, 2017 at 8:26 PM
    #2021
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    No, a water meth kit is not a supplement for a maxed out fuel pump. It's for when you want to run a hot fuel with a high compression ratio. Raises the knock threshold
    j0shu4, Torspd, Jstand and 1 other person like this.
  2. Aug 16, 2017 at 8:22 AM
    #2022
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This.
    elnip, j0shu4 and Jstand like this.
  3. Aug 16, 2017 at 8:36 AM
    #2023
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    If changing the pump only takes 1 1/2 hrs then ill just do that but i suspect on mine it might take longer
  4. Aug 16, 2017 at 8:43 AM
    #2024
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I didn't pull the entire bed off, I just unbolted the driver's side, loosened the passenger side, and just lifted the drivers side enough to put a jack stand in there to hold it up ( also take off your gas cap so it doesn't break off). From there it was just remove the pump assembly, swap the pump, and reassemble. The part that takes the longest is shortening the hard line to fit the taller aftermarket pump.
    Jstand[QUOTED] likes this.
  5. Aug 16, 2017 at 10:45 AM
    #2025
    Jstand
    Irving,Tx
    That doesn't sound to bad at all thats what ill do if or when i go over 8psi
  6. Aug 16, 2017 at 1:36 PM
    #2026
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    It can be... The extra fuel is only to keep chamber temps down, it doesn't get burned. If you run water/meth, you can theoretically run higher AFR's. If you don't need the extra fuel for 11's AFR, you may be able to get away with a smaller pump and injectors.
  7. Aug 16, 2017 at 1:41 PM
    #2027
    MrCrowntown
    Alyn
    Ky
    That theory is encompassed in the Knock threshold..
  8. Aug 16, 2017 at 1:46 PM
    #2028
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Knock comes from heat. You put extra fuel into the chamber to absorb that extra heat; it doesn't burn, it just prevents knocking by keeping temps down. Its not very efficient but easy considering the options.
    Meth/water does exactly the same thing but more efficiently; water absorbs a ton more heat than fuel and is a much better knock inhibitor. You can easily run at 14.7 AFR if you have a properly tuned and capable water meth kit.
  9. Aug 16, 2017 at 1:52 PM
    #2029
    MrCrowntown
    Alyn
    Ky
    Yes. Everything you said is correct. All of those things, are considered when figuring out the Knock threshold.
  10. Aug 16, 2017 at 1:53 PM
    #2030
    boostedka
    James
    NM
    That guy on here with the half million mile has his s/c 3.4 running 9psi with meth spraying over 5psi. He said his AFR is perfect
  11. Aug 16, 2017 at 1:57 PM
    #2031
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    While I would be the last person to advise it, you CAN run increased boost that surpasses your fuel system capability (as long as you can maintain at least 14.7 AFR) if you supplement with water/meth.
    Something to keep in mind; while water/meth generally are used to allowed increased boost, advanced timing, etc... you can also use it to raise AFR's and waist less fuel. Any AFR under 14.7 means your shooting unburnt fuel out of your tail pipes.
  12. Aug 16, 2017 at 2:55 PM
    #2032
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Why run a bandaid when it can be engineered right.
    A pump is more for growth, but also nothing to have to continually monitor. Add gas, and go. Not "go" but forgot to refill the meth. Oops...
    Jstand likes this.
  13. Aug 17, 2017 at 9:54 AM
    #2033
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Meth isn't for fueling. Only to lower IATs and better AFRs
  14. Aug 17, 2017 at 10:11 AM
    #2034
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't forget reduced knock potential, so that timing can be advanced a lot more.
  15. Aug 17, 2017 at 10:37 AM
    #2035
    j0shu4
    Yeah that knock thing I hope I don't ever have to deal with. I've heard they're no fun to change on the 3.4
  16. Aug 17, 2017 at 11:07 AM
    #2036
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What's no fun to change?
  17. Aug 17, 2017 at 11:26 AM
    #2037
    MrCrowntown
    Alyn
    Ky
    The knock sensors.
    They are crammed in the Valley
  18. Aug 17, 2017 at 1:50 PM
    #2038
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    This is a pain to deal with ^ :D
    I'm not dead! Just busy @Torspd :D
  19. Aug 17, 2017 at 3:07 PM
    #2039
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol. True. But nothing to do with lowering cylinder combustive knock potential.
    MrCrowntown[QUOTED] likes this.
  20. Aug 17, 2017 at 3:24 PM
    #2040
    Jstand
    Irving,Tx
    I spent the morning doing air leak chasing and found that when I put 10psi of air through the system It leaks out through the PCV valve a lot . Is that normal :eek:
