Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Aug 17, 2017 at 6:05 PM
    #2061
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    If the cold side was open to atmosphere, you would see a vacuum. IF it were a minor leak on the cold side, you may not see full boost, but you would see some. If the wastegate is not holding closed to create boost, the system will equalize as everything is allowed to spin freely
  2. Aug 17, 2017 at 6:09 PM
    #2062
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    So i have more of an issue with the wastegate than originally assumed? It only would go to 0 psi and we got up over 3k rpms. So maybe put a stiffer spring in and see if it holds it shut enough to build boost.
    MrCrowntown[QUOTED] likes this.
  3. Aug 17, 2017 at 6:29 PM
    #2063
    MrCrowntown
    Alyn
    Ky
    Yes sir. Start there to make sure you're getting spool first
    yota243[QUOTED] likes this.
  4. Aug 17, 2017 at 6:46 PM
    #2064
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No exhaust leaks pre turbo? No intake couplings off? Air filter clean? Turbo spins freely? Wastegate diaphragm not pinched?
    Vacuum hose to wastegate, attached to side/lower port? Where is that hose referenced from? Turbo compressor housing, charge pipe, or intake manifold?
    No crazy vacuum leaks on the intake?
    StAndrew and Jstand like this.
  5. Aug 17, 2017 at 6:59 PM
    #2065
    yota243
    E.J.
    north Alabama
    All off the boost references are coming from the port that the pcv was routed off the upper plenum. Pretty sure i dont have an exhaust leak other than what is bypassing at the wastegate. I think i have all the vacuum leaks taken care of since the idle is normal and for the most part i can keep my fuel trims in check. Airfilter is clean. I think the diaphram is fine but ill double check when swap springs.
    Boost line hooked to side of wastegate*
  6. Aug 17, 2017 at 7:57 PM
    #2066
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Is your WG stuck open?
  7. Aug 17, 2017 at 8:11 PM
    #2067
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That was to be my next question.
  8. Aug 18, 2017 at 5:02 AM
    #2068
    yota243
    E.J.
    north Alabama
  9. Aug 18, 2017 at 6:51 AM
    #2069
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Just with my little experience if the boost gauge only goes to 0 the all of the boost is going somewhere else besides where the boost gauge is reading. In my case it was a coupler that came off. The only other time that happened was when the first turbo seized.
  10. Aug 18, 2017 at 8:44 AM
    #2070
    RedLantern
    Honolulu, Hi
    Hard to tell without pressure building up. But its a good chance it may b stuck open. Try opening up the WG to make sure it moves freely and not binding. Could also be diaphram as torspd mentioned. Jus remembered, Did you put the fire ring on the WG?
  11. Aug 18, 2017 at 8:46 AM
    #2071
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely take it off and look at it. Take the cap off and inspect the diaphragm and valve's movement. Upon reassembly, spray the draphragm with WD-40 so that it doesn't get pinched while tightening the cap down.
    I wouldn't yet go to a larger spring, until you figure out what is going on.
    If you pull the air filter off, have the engine running, and watch how free the compressor spins when you give it gas.
    Also. Is the BOV staying open the whole time, or is it working properly? Get a video of it while idling and gassing.
  12. Aug 18, 2017 at 8:47 AM
    #2072
    yota243
    E.J.
    north Alabama
    bov was my next suspect ill see if I can line a video up this weekend and see what happens
  13. Aug 18, 2017 at 8:53 AM
    #2073
    yota243
    E.J.
    north Alabama
    yeah fire ring is in
  14. Aug 18, 2017 at 9:36 AM
    #2074
    Jstand
    Irving,Tx
    I spoke with kurt4726 from customtacos about the inline fuel pump and he said he runs an inline fuel pump along with the stock pump after he determined that after 3500 rpm the fuel pressure drops on his 3rz.
  15. Aug 18, 2017 at 9:37 AM
    #2075
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    IIRC he's gotten his stock motor up to 15psi with that set up on E85 with a Megasquirt3, 550cc primary and 220cc secondary injectors.
    Jstand[QUOTED] likes this.
  16. Aug 18, 2017 at 12:10 PM
    #2076
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Damn 15 psi.. thing must of pushed close to 300 hp
  17. Aug 18, 2017 at 12:14 PM
    #2077
    yota243
    E.J.
    north Alabama
    I bet it was more than 300 ~14 psi should basically doubles hp plus he was on e85
  18. Aug 18, 2017 at 1:01 PM
    #2078
    boostedka
    James
    NM
    He posted a vitrual dyno that i believe was around 340-350hp
    MadTaco461 and Jcyr[QUOTED] like this.
  19. Aug 18, 2017 at 4:00 PM
    #2079
    Jcyr
    Jack
    North east
    How much do those injectors cost?
  20. Aug 18, 2017 at 6:16 PM
    #2080
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    That is awesome. He is pushing that stock block to the max.
