Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Aug 27, 2017 at 9:14 PM
    #2221
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Need to wrap my intake pipes too. Looks good.
    Jstand[QUOTED] and Jcyr like this.
  2. Aug 27, 2017 at 9:23 PM
    #2222
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    @j0shu4 did you pass emissions with your waste gate dumping to atmosphere? I just got that dreaded notice in the mail and I don't feel confident no one in that garage is going to raise an eyebrow when the WG is fully opened.
  3. Aug 27, 2017 at 9:29 PM
    #2223
    j0shu4
    I unhooked the charge pipe so no boost. Then I put a crap ton of denatured alcohol in the tank. I forget the ratio........ended up passing but I have no idea how. 1st time I failed with no additive in the tank. Think that alcohol helps you pass. I think @GioGuitarDude knows.
    I'm dreading it again too!
  4. Aug 28, 2017 at 2:29 AM
    #2224
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    What did the alcohol do?
  5. Aug 28, 2017 at 5:09 AM
    #2225
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Strange thing i dont have any codes but it seems like the ecu stays in closed loop until the engine is run for a little while or the afrs stay up around 14-16 even if i run it hard until i drive for awhile (warms up). If i want to drive it hard before it seems like it bogs down this just started
  6. Aug 28, 2017 at 6:03 AM
    #2226
    j0shu4
    Burns cleaner so it lowers emission readings
    Jcyr[QUOTED] likes this.
  7. Aug 28, 2017 at 8:41 AM
    #2227
    Jcyr
    Jack
    North east
    So just running startron
  8. Aug 28, 2017 at 8:45 AM
    #2228
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Alcohol has different emissions and the bad ones aren't tested so by gasoline testing standards it's very clean.
    j0shu4 and Jcyr[QUOTED] like this.
  9. Aug 28, 2017 at 9:19 AM
    #2229
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    How new are your stock narrowband sensors..?
  10. Aug 28, 2017 at 9:58 AM
    #2230
    Jstand
    Irving,Tx
    :D Original
    MrCrowntown[QUOTED] likes this.
  11. Aug 28, 2017 at 10:00 AM
    #2231
    MrCrowntown
    Alyn
    Ky
    haha!
    I would replace those when you get the chance
  12. Aug 28, 2017 at 10:02 AM
    #2232
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    MrCrowntown likes this.
  13. Aug 28, 2017 at 10:35 AM
    #2233
    Jstand
    Irving,Tx
    boostedka[QUOTED] likes this.
  14. Aug 28, 2017 at 11:39 AM
    #2234
    boostedka
    James
    NM
    Sweet. I'll get it out as soon as I can. This time of year is pretty busy for me so I'm hoping to find a little bit of time to get to the post office this week.
    Jstand[QUOTED] likes this.
  15. Aug 28, 2017 at 6:28 PM
    #2235
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    All of it. :headbang:
    yota243 and MadTaco461 like this.
  16. Aug 29, 2017 at 6:47 AM
    #2236
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    a friend of mine is just like this most of the time :anonymous:
    MrCrowntown, MadTaco461 and Jstand like this.
  17. Aug 29, 2017 at 6:51 AM
    #2237
    yota243
    E.J.
    north Alabama
    j0shu4, Jstand and MadTaco461 like this.
  18. Aug 29, 2017 at 7:12 AM
    #2238
    Jstand
    Irving,Tx
    After a bit of reading on the subject i suppose i could have messed up the o2 sensor from running leaded racing fuel.
  19. Aug 29, 2017 at 9:33 AM
    #2239
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Absolutely
  20. Aug 30, 2017 at 9:50 AM
    #2240
    yota243
    E.J.
    north Alabama
    made the sign in screen for sandflix (next year it will be in a turbo Tacoma)
    buyobuyo, Jstand and MrCrowntown like this.
