Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 3, 2017 at 7:58 PM
    #2341
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    So realized something stupid today. I did a 2hr round trip drive yesterday and I noticed on the way home I was seeing less and less boost. Checked it out this morning and saw that the coupler next to the maf had slid off. When I went to reattach it I realized that the FPR vac line was caught in the t-bolt and clamped down o_O And the vac line may or may not have actually been attached to the FPR. I reconnected everything correctly but didn't get a chance to start it up with the lap top hooked up yet. Will do that tomorrow. But hopefully this may fix my idle issue I've been having. I think this may have happened when I pulled stuff off to install the injectors
    :rofl: Fuckin stupid :rofl:
    Torspd, MadTaco461 and MrCrowntown like this.
  2. Sep 3, 2017 at 8:26 PM
    #2342
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    That is why I will ALWAYS ask if all the vacuum signal lines are attached and good lol
    It's like the inevitable 'is the computer plugged into the wall, sir' when talking to tech support. You'd be surprised how many times they're right :laugh:
    Torspd likes this.
  3. Sep 3, 2017 at 8:36 PM
    #2343
    boostedka
    James
    NM
    Sometimes brain farts get the best of me
    MadTaco461 likes this.
  4. Sep 4, 2017 at 5:07 AM
    #2344
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Has anyone ever gotten a P0125 code ?
  5. Sep 4, 2017 at 9:02 AM
    #2345
    MrCrowntown
    Alyn
    Ky
    Hmm, that could be a number of things.
  6. Sep 4, 2017 at 9:28 AM
    #2346
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  7. Sep 4, 2017 at 10:17 AM
    #2347
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Think of it more like a fridge. It keeps the inside cool while the outside ia hot. The wrap also prevent the conduction of heat, from the engine bay, into the post intercooled charge pipe. Preventing that pipe from saturating with heat again.
  8. Sep 4, 2017 at 10:20 AM
    #2348
    MrCrowntown
    Alyn
    Ky
    Reduces Emissivity, in scientific terms
    :anonymous:
    Torspd likes this.
  9. Sep 4, 2017 at 10:25 AM
    #2349
    Jstand
    Irving,Tx
  10. Sep 4, 2017 at 10:46 AM
    #2350
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Well, the thing is the r150f is the 5vz trans but it won't bolt up to my 3rz t case.
    The r151f and r150f is pretty much the same except the low 1st gear at 4.80 something and being able to use the t case out of the 4 cylinder with the r151f.
  11. Sep 4, 2017 at 12:56 PM
    #2351
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
  12. Sep 4, 2017 at 1:05 PM
    #2352
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @MrCrowntown is on cloud 9 with the Haltech working! Or at least what the boost vine says. :gossip:
  13. Sep 4, 2017 at 1:45 PM
    #2353
    Jstand
    Irving,Tx
  14. Sep 4, 2017 at 2:11 PM
    #2354
    RedLantern
    Honolulu, Hi
    Maybe check coolant levels, thermostat etc? Did the code repeat after that first time?
  15. Sep 4, 2017 at 2:23 PM
    #2355
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How is it running today? Laptop hooked to it?
  16. Sep 4, 2017 at 2:30 PM
    #2356
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    r151 all day. W series is no where as strong as the r series.
    MadTaco461 and boostedka like this.
  17. Sep 4, 2017 at 3:17 PM
    #2357
    Jstand
    Irving,Tx
    No code again yet but I know for sure I need to change the o2 sensor
  18. Sep 4, 2017 at 5:00 PM
    #2358
    boostedka
    James
    NM
    It had been running a little inconsistent at idle and at cruising speeds and I couldn't figure out why. Today it was better but AFR's were just off...random rich or lean spots. So I messed with the idle and cruise area of the fuel map and it's much better now. A lot more consistent and responsive. The AutoTune feature in the TunerStudio software makes tuning cruising AFR's really quick and easy. I'm glad I popped off that coupler yesterday or who know when I would've found that vac line like that. It was on the underside of the IC pipe where I'd never see it.
    Jstand likes this.
  19. Sep 4, 2017 at 5:21 PM
    #2359
    GreeGunc
    Jacob
    North GA
    Gotcha
  20. Sep 4, 2017 at 5:39 PM
    #2360
    GreeGunc
    Jacob
    North GA
    Anyone know about the transfer cases toyota used.
    I have a 3rz, wanting to go with the r151f but not sure if it will fit my stock t case. The 151 will fit the older pickup gear driven t case but the r150f will not.
