Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 27, 2017 at 9:31 AM
    #221
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When do we start?!
    MrCrowntown likes this.
  2. Mar 27, 2017 at 9:54 AM
    #222
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Question to @StAndrew @vasinvictor (just realized I left you out of the OP, sorry!) or anyone else who might have some insight, How much of a difference does the afr gauge make over the older style o2 sensor as far as target afr's go? Mine bounces around 14.2-14.9 at idle and similarly until target is near 12.5 when it stops oscillating. The reason I ask is I'm pondering getting a good running 4-door and swapping a manual trans, or finding a hammered 4-door and swapping my engine/trans to it. Just curious if there's a significant benefit to the newer style, thanks!
    I get 18-19 mpg mixed.
  3. Mar 27, 2017 at 10:01 AM
    #223
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    im gonna get some metal, and start some maths for my flame tube off my turbo
    MadTaco461 likes this.
  4. Mar 27, 2017 at 10:02 AM
    #224
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Mar 27, 2017 at 4:58 PM
    #225
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Not sure but iirc, the old sensor wasn't a wide band. The newer sensor and ecu were wide bands and more accurate. I can't say on a scale the difference but my 99 accord had a wide band for the cali models to meet emissions.
  6. Mar 27, 2017 at 5:16 PM
    #226
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I did a small skinny one below the AC lines. Going to get in the way of a winch I think and it's a bit small for high boost.
    When you do your intercooler pipes, as they come up to your throttle body, make sure you insulate them from the turbo heat. My IC pipes were getting way hot. I used reflective insulation tape that seems to be work well.
    Also if you run e85, don't get the FIC as you can't advance timing and take full advantage. MAP ECU 3 if you want a piggy back but I don't think you can tune injector pulse width for bigger injectors.
    boostedka likes this.
  7. Mar 27, 2017 at 5:18 PM
    #227
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'd have to move out of CA in order to make any of that stuff. My propane spud launcher was all my neighbors could handle.
  8. Mar 27, 2017 at 5:22 PM
    #228
    MrCrowntown
    Alyn
    Ky
    it's definitely an Ocotillo alarm clock
    MadTaco461[QUOTED] likes this.
  9. Apr 5, 2017 at 10:15 AM
    #229
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  10. Apr 5, 2017 at 10:45 AM
    #230
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  11. Apr 5, 2017 at 11:40 AM
    #231
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ahhhh hahahahahhaha. :laugh:
  12. Apr 5, 2017 at 11:47 AM
    #232
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    #IPayPeopleToBuildMyCar
    Brice likes this.
  13. Apr 5, 2017 at 12:07 PM
    #233
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm going to upgrade to a belt driven turbo like he has! #killinit
    Brice and yota243 like this.
  14. Apr 5, 2017 at 12:52 PM
    #234
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i mean..makes a lot of the same noises..haha
  15. Apr 5, 2017 at 1:55 PM
    #235
    Lucario Runner
    Robert
    06 Toyota 4Runner
    #beltslip
    Torspd likes this.
  16. Apr 5, 2017 at 2:01 PM
    #236
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Cause you like the VTEC powerband? Lol
  17. Apr 5, 2017 at 2:11 PM
    #237
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I don't get it.. I thought these things were pretty sweet.
  18. Apr 5, 2017 at 2:16 PM
    #238
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    If I'm not totally an idiot I believe the joke is, is that it's a supercharger.
    Lucario Runner likes this.
  19. Apr 5, 2017 at 2:18 PM
    #239
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Turbobygarrett posted about #turbolife. Yet added a picture of a centrifical supercharger.
    Brice and Lucario Runner like this.
  20. Apr 5, 2017 at 3:56 PM
    #240
    Blackdawg
    Monte
    Wyoming/St. Louis
