Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 5, 2017 at 1:56 PM
    #2401
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Honestly couldn't be happier with the service he's provided so far. Paradise will have my business for a long time if Luis and team handle everything the way he did my order this weekend/today I'm a turbo noob and he had no problem breaking every aspect down for me which was a lot more than LCE did. I'm not questioning LCE's quality or expertise I just had a bad experience with their technical support when trying to figure out a setup. To each their own
  2. Sep 5, 2017 at 2:45 PM
    #2402
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Well, as someone who literally spends recreational time with those guys, they deal with a lot of tire kickers. They do know what they are talking about, but as you will probably never get the engine tuner they have on the phone to explain everything about the parts you may purchase, they can only divulge so much to you.
    Luis is a different story. He is an engine builder/tuner so he can spew out GOBS of info on request. He just so happens to have had a lot of early success, and built a nice clientele as well as a reputation enough to have a store and be able to be a successful vendor.
    Neither company, to me, holds more weight than the other. Both have 1800hp 3rz motors that they have built and are racing currently. Just differs on the size of the company, and the ability to talk directly to the builders themselves.
    boostedka likes this.
  3. Sep 5, 2017 at 2:56 PM
    #2403
    Jcyr
    Jack
    North east
    I understand LCE is quality and honestly I still bought my clutch off of them but it's a shame to have a resource as knowledgeable as them shutting people down because they don't fork over the CC info after less than 5 minutes of questions.
    A lot can go wrong boosting we all hear that so a novice is gonna need a good amount of advice to justify the many thousands spent and risked when making that first purchase.
    I'd never question their experience or expertise on taco motors just their patience... lol
    For a seasoned vet with less questions yes I bet they are awesome but for a first time booster I had a different experience that's all.
  4. Sep 5, 2017 at 3:06 PM
    #2404
    Jcyr
    Jack
    North east
    @MrCrowntown no bad blood or anything just "bs" about my first boost purchase. I likely was just flagged as a "tire kicker" like you said just unfortunate that that wasn't the case.
  5. Sep 5, 2017 at 3:13 PM
    #2405
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ditto. I believe the 1GR is .044". My iridiums are around .028-.030.
    Jcyr likes this.
  6. Sep 5, 2017 at 3:16 PM
    #2406
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As @boostedka touched on, once you pull your plugs, you'll have an idea what the current gap is.
  7. Sep 5, 2017 at 3:16 PM
    #2407
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This guy is ready for a boost build!
    Jcyr[QUOTED] likes this.
  8. Sep 5, 2017 at 3:23 PM
    #2408
    MrCrowntown
    Alyn
    Ky
    There's no bad blood, just had to be sure you understood their position.
    I had to come at them with a full block, turbo, ecu, and ancillary parts for them to be willing to tackle the job. They decided to make a production turbo kit for the 2tr since I bugged them for ten years straight, and was providing them with a block too :laugh:
    Torspd likes this.
  9. Sep 5, 2017 at 3:34 PM
    #2409
    Jcyr
    Jack
    North east
    The benefits of being friends with the big dogs I guess lol :rofl:
  10. Sep 5, 2017 at 4:51 PM
    #2410
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Okay, i did some searching when i got home.
    Just post this:
    http://www.fourwheeler.com/how-to/t...129-0207-toyota-transfer-case-rebuild-upgrade
    And this....cant believe its on a ford forum:eek:
    http://www.f150hub.com/drivetrain/toyota-rf-vf.html
    And this....
    https://www.marlincrawler.com/tech/transmission/transmission-gear-ratio-chart
    My notes:
    r151f only on 85-87 22rte
    23 spline
    1st 4.313:1- 2nd 2.330:1- 3rd 1.436:1- 4th 1.000:1- 5th 0.838:1- Reverse 4.843:1
    R150f v6 tacoma (readily available)
    23 spline
    w59 3rz
    23 spline
    3rz and 5vz auto/ 5vz manual(r150f)
    23 spline
    Same transfer case bolt up per LCE gear drive t case adapter
    Therefore, my w59 transfer case will not bolt up with a r150f or r151f...
    Torspd and MrCrowntown like this.
  11. Sep 5, 2017 at 6:11 PM
    #2411
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    2RZ and 3RZ are 0.031" factory gap. 5VZ is 0.043" factory gap. Per the 98 Tacoma Owners Manual.
  12. Sep 5, 2017 at 6:29 PM
    #2412
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank you.
    No need to widen it then. This must be why I remember something about @MadTaco461 saying his was around .028"?
  13. Sep 5, 2017 at 6:36 PM
    #2413
    GreeGunc
    Jacob
    North GA
    So guys....motor should be here Thursday or Friday. Now to decide if I want the hard to find r151f with the 4.31 first gear or say screw it and go r150f so I can maybe get it done quicker....
  14. Sep 5, 2017 at 6:44 PM
    #2414
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I gapped mine tighter for 10psi plus. I never had a blow out issue with the factory gap. It's pretty violent when you don't have a proper gapped plug. In general you want that gap open as you can afford.
    TacoLeeSD and Torspd[QUOTED] like this.
  15. Sep 5, 2017 at 6:47 PM
    #2415
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    You could also look into the new R156F that is in 3rd gen 4 bangers. It has the same gear ratios for 1st through 4th as the R151F with a 0.79 5th gear (per Wikipedia).
  16. Sep 5, 2017 at 7:01 PM
    #2416
    gearcruncher
    Canadain bumper technician
    will the R156F fit ? . I beleive the bellhousing is different ??
    Jcyr likes this.
  17. Sep 5, 2017 at 7:23 PM
    #2417
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I have no idea. I was just putting it out there as it has the gear ratios that he is looking for with a better 5th gear for freeway cruising. It is mated to the Dual VVT 2TR-FE in the 16-17 Tacomas, so I would imagine that it would fit the 05-15 trucks. I can't speak for older trucks though.
  18. Sep 5, 2017 at 7:24 PM
    #2418
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    2TR short block and 3rz short blocks are identical. Strong possibility of them fitting each other.
    buyobuyo likes this.
  19. Sep 5, 2017 at 7:37 PM
    #2419
    MrCrowntown
    Alyn
    Ky
    Only difference in the rear of the 2tr block from a 3rz, is the sub pan. I believe @MadTaco461 has gotten pretty far with his swap, although summer has hindered things lol
    Torspd likes this.
  20. Sep 5, 2017 at 9:41 PM
    #2420
    MadTaco461
    CA
    Kinda stock
    Office life has made me soft. So far the r155 is full bolt on. Only issue is for the transfer case if you go 4x. Transfer case is electronic switch. Just gotta make a standalone selector.
    MrCrowntown[QUOTED] likes this.
