Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 7, 2017 at 10:38 PM
    #2481
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    because it should be fine for what i want out of it. And this will be my first experience with turbos so i didn't think id go all out with a pricey fancy turbo first go. Not an a particular budget or anything but i really dont know if its worth spending so much more on a relatively low power build. Im gona be away from my truck out of province for work till the winter and wanted to start a parts list/ordering for when i get back.
  2. Sep 7, 2017 at 10:48 PM
    #2482
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well, get a smaller one.
    like so: https://www.cxracing.com/index.php?route=product/product&path=95_614&product_id=3418
    Would spool quite fast really.
  3. Sep 7, 2017 at 10:53 PM
    #2483
    Blackdawg
    Monte
    Wyoming/St. Louis
    or this guy: https://www.cxracing.com/index.php?route=product/product&path=95_614&product_id=3415
    Both would respond and flow very different and deliever very different power. second one is larger of course so..all depends on what you want.
    Edit: They have actually changed the turbo with the kit now. Its smaller then the one posted above. Not a bad match really. The first one i posted would be much faster though.
  4. Sep 8, 2017 at 4:51 AM
    #2484
    devinzz1
    devin
    2023 aclb trd or mt
    bookmarked. thanks. aem fic6 will be dealing with the fuel/ignition btw.
    Jcyr likes this.
  5. Sep 8, 2017 at 9:01 AM
    #2485
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I found this pic posted on t4r.org:
    Jcyr[QUOTED] likes this.
  6. Sep 8, 2017 at 1:52 PM
    #2486
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I have done the rear o2 sensor mod where solder a resister does that mean that i can take out the cat or do i need to replace it if its bad
  7. Sep 8, 2017 at 1:56 PM
    #2487
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You should be able to ditch the cat.
  8. Sep 8, 2017 at 1:59 PM
    #2488
    Jstand
    Irving,Tx
    Sounds good :D
  9. Sep 8, 2017 at 3:51 PM
    #2489
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    What size resistor did you use @Jstand
  10. Sep 9, 2017 at 4:27 AM
    #2490
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    What mufflers are you guys running? I have a dyomax but I don't like the sound. Sounds too much like a ricer...Looking for something more quiet.
  11. Sep 9, 2017 at 5:17 AM
    #2491
    Jstand
    Irving,Tx
    I'm running a flowmaster super 44 i like it. Its got a deep sound and actually I posted a video testing the turbo out on this thread pg. 122
  12. Sep 9, 2017 at 5:38 AM
    #2492
    Jstand
    Irving,Tx
    There is a write up i think on that but i can find it still looking or at least a couple of pics
    98tacoma3rz and Jcyr[QUOTED] like this.
  13. Sep 9, 2017 at 7:19 AM
    #2493
    boostedka
    James
    NM
    I'm using a Gibson Superflow 788500. It's pretty much the quietest straight through muffler there is. I barely notice a difference in sound from stock inside the cab. I used 2.5" mandrels for the piping. It made my truck rev much smoother
  14. Sep 9, 2017 at 9:08 AM
    #2494
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mandrel bends FTW.
    MadTaco461 likes this.
  15. Sep 9, 2017 at 9:33 AM
    #2495
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Clearly a different engine, mine versus yours. I have a vibrant ultra quiet resonator @3.5" before a 3.5" resonated Aeroturbine muffler. It literally sounds like an exotic engine/boxer engine. In part to the unequal length headers.
    @MadTaco461 can attest.
  16. Sep 9, 2017 at 11:18 AM
    #2496
    Blackdawg
    Monte
    Wyoming/St. Louis
    magnaflow!
    Blackwidow sounds good too.
    98tacoma3rz and Jcyr like this.
  17. Sep 9, 2017 at 2:47 PM
    #2497
    Jstand
    Irving,Tx
    An issue that I'm noticing now is through the range of RPM to 5000 there seems to be drops of power or hesitation hopefully not the fuel pump I'll be put the fuel gauge so that I can see through the windshield here pretty soon to check pressure if it drops but I can't think of what it could be:notsure:
  18. Sep 9, 2017 at 4:55 PM
    #2498
    Jcyr
    Jack
    North east
    I think I want to try black widow.... what did the mandrel bends do to improve rev
  19. Sep 9, 2017 at 6:14 PM
    #2499
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You have the larger fuel pump installed? If so, which size? Cannot remember.
    Do you have an AFR gauge? What is the AFR during that drop off?
  20. Sep 9, 2017 at 8:42 PM
    #2500
    Jstand
    Irving,Tx
    I got the DW200 which is 255lph and I still have the narrowband
