Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 11, 2017 at 7:19 PM
    #2521
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I replaced the FPR and that seems to have resolved the issue plus yet another vacuum line was off so I made sure to tie strap all of them plus pressure is back to normal at 47psi.
  2. Sep 11, 2017 at 7:33 PM
    #2522
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    :thumbsup: Heck yes :thumbsup:
    Nice diagnosis @Torspd
    Jstand[QUOTED] and Torspd like this.
  3. Sep 11, 2017 at 7:45 PM
    #2523
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Woooo good job jstand
    Jstand likes this.
  4. Sep 11, 2017 at 8:13 PM
    #2524
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is great to hear!
  5. Sep 11, 2017 at 8:25 PM
    #2525
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I think that might be what's making me run so lean.
    I replaced the MAF and the fuel filter with little to no change.
    That's the last thing I can think of since my WOT AFR's are perfect and every sensor related to air and fueling has been replaced... ugh!
    I would test it, but being how irritating and time consuming it would be to test the fuel rail pressure on the 3.4, I might as well just throw a new FPR in there.
  6. Sep 11, 2017 at 9:13 PM
    #2526
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    FPR's for everybody!!!
    Jstand and MadTaco461 like this.
  7. Sep 11, 2017 at 9:33 PM
    #2527
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Torspd likes this.
  8. Sep 11, 2017 at 9:53 PM
    #2528
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    MadTaco461[QUOTED] likes this.
  9. Sep 11, 2017 at 10:01 PM
    #2529
    MadTaco461
    CA
    Kinda stock
    It's something else if that motor comes out as they say.
  10. Sep 12, 2017 at 6:36 AM
    #2530
    Jstand
    Irving,Tx
    I still seem to have an intermittent hesitation at WOT like something is holding it back and then lets go but i think the FPR was bad too because the fuel pressure is normal now. Everything is new now except the Ignition coils and the catalytic converter so :notsure: and it is intermittent because i keep thinking its fixed:facepalm:
  11. Sep 12, 2017 at 7:44 AM
    #2531
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Maybe another vacuum leak, hidding out of sight?
    Jstand likes this.
  12. Sep 12, 2017 at 8:22 AM
    #2532
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I have a pump for you for free if you want. 255 iirc.
  13. Sep 12, 2017 at 8:25 AM
    #2533
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    How old is you O2 sensor? The only thing I can think is its not running well in closed loop and pulls hard in open loop.
    Maybe your boosting too hard in closed loop causing slight ping and timing retard? I get well onto the 12s and 11s in open loop and don't boost too hard in closed so I havent bother with tuning yet. You might want to get a tuner to fix your closed loop boost.
    Torspd and Jstand[QUOTED] like this.
  14. Sep 12, 2017 at 8:26 AM
    #2534
    Jstand
    Irving,Tx
    Its a new sensor im going to check the coils i think next
  15. Sep 12, 2017 at 8:32 AM
    #2535
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Generally coils a either good and you get spark, or bad and you don't. The fact that it runs well means you are getting good spark. The hick up, I believe, is die to something with your computer.
    It it's a mechanical issue, generally it will run bad the entire time. A bad spark will only get worse as boost builds.
    Jstand[QUOTED] likes this.
  16. Sep 12, 2017 at 11:07 AM
    #2536
    GioGuitarDude
    Gio
    Cold air intake
    Not necessarily. I had a bad coil that when in WOT would make the truck shudder and shake, then take off strong just a couple seconds later. It ended up shuddering all the time in WOT as it further wore out, but started doing it intermittently. An easy and cheap way to tell if it's the coil (in my experience) is to take your plugs and gap them down ridiculously small (like.018 to .020"), throw them back in and hit the highway.
    Gaps that small should make idle run like hell but WOT boost smooth with no hesitation.
    If you get no more WOT hesitation, then you know that your coils are weak and need replacing.
    Also Jstand, have you checked your pending codes? You may have a timing related sensor on its last leg (knock, cam, crank etc....)
    Jstand likes this.
  17. Sep 12, 2017 at 11:19 AM
    #2537
    Jstand
    Irving,Tx
    I'll check this thx
  18. Sep 12, 2017 at 1:02 PM
    #2538
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Does anyone know if the nuts for the bed mounts are accessible from inside the bed? Started to work on replacing my fuel pump. First bolt just spins from underneath. Tried another one and same things happened...
  19. Sep 12, 2017 at 2:55 PM
    #2539
    Jstand
    Irving,Tx
    There are 6 all together all on the bottom one on each side are nuts then two bolts on each side towards the cab. The nuts have metal plates on the other end that lock them in place when tight so if you've loosened them and push up they might spin. The way I did it was take off the nut and bolts on the driver side and just loosen the ones on the passenger side. Lift the driver side enough to reach the pump comfortable and make sure it's secure so it won't drop on you. Watch out for the wire harnesses you may have to disconnect some of them
  20. Sep 12, 2017 at 3:02 PM
    #2540
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Yeah I'm pretty sure the nuts or whatever that are inside that crewmember are bent or something. I used an impact and the bolts just spin. Won't loosen or tighten. Fml.
