Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 12, 2017 at 4:13 PM
    #2541
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Well looks like my phone sucks for typing. You are making my point. The higher the load, the more stress on the spark. He's saying it is good at WOT, but has an initial hickup. If it was the spark, it would get worse, not better, as boost builds. Sounds like an issue in closed loop that is no longer an issue in open loop but hard to say.
  2. Sep 12, 2017 at 6:28 PM
    #2542
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Sep 12, 2017 at 6:40 PM
    #2543
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Watched that earlier!
    Dalandser likes this.
  4. Sep 12, 2017 at 8:35 PM
    #2544
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Whaaatttttt ttthhhee......!!!!!!!
  5. Sep 13, 2017 at 6:55 AM
    #2545
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Sick truck
  6. Sep 13, 2017 at 11:26 AM
    #2546
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Well that's the thing... the bad coil gave a misfire at WOT (full boost) but then it just started working 2 or 3 seconds into the WOT pull. It got progressively worse (took longer to start sparking the fuel) until finally I had a constant misfire while in boost.
  7. Sep 14, 2017 at 9:04 AM
    #2547
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Been wondering when we'd see high pressure fuel systems injecting on compression stroke in gasoline engines. Very cool stuff. If this goes right we might see work trucks transition from diesel to gasoline, lol.
    @Jstand What is your spark plug gap? Could you catch me up on your build?
    MadTaco461[QUOTED] likes this.
  8. Sep 14, 2017 at 12:54 PM
    #2548
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Spark plug gap is .028 from .041 new fuel pump is 255lph with pink injectors. Intercooler is in and running 8-9psi :D It doesn't happen all the time but when the throttle is half or full either one it seems like it's being held back then takes off.
  9. Sep 14, 2017 at 12:57 PM
    #2549
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Diesel is such a pain to meet US emissions. The world may be able to keep engines a bit longer.
  10. Sep 14, 2017 at 2:38 PM
    #2550
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like a vacuum leak to me. Possibly with the PCV routing or venting.
    Where is the needle on the boost gauge, when it happens? Take note next time
    Jstand[QUOTED] and MadTaco461 like this.
  11. Sep 14, 2017 at 2:59 PM
    #2551
    MadTaco461
    CA
    Kinda stock
    Almost sounds like the normal part spool lean out until the truck kicks into open loop. Feels like a switch clicks and the truck acts normal again. Probably does it below 3k rpms.
    Jstand likes this.
  12. Sep 14, 2017 at 3:29 PM
    #2552
    Jstand
    Irving,Tx
    That's possible I'll take note of these thing
  13. Sep 14, 2017 at 4:21 PM
    #2553
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And get a wideband installed!!! :goingcrazy:
    Jcyr, Clay_916[OP] and MadTaco461 like this.
  14. Sep 14, 2017 at 5:24 PM
    #2554
    Jstand
    Irving,Tx
    Yea I've been avoiding it because I have to install the sensor without taking off the down pipe
  15. Sep 14, 2017 at 6:02 PM
    #2555
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It doesn't have to be in the downpipe. It can be post downpipe as well.
  16. Sep 14, 2017 at 9:04 PM
    #2556
    Jstand
    Irving,Tx
    My downpipe bolts to the catalytic converter unless it can be after the converter or I could relocate the converter
  17. Sep 14, 2017 at 9:14 PM
    #2557
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I just love missing 30 pages of stuff.
    Thanks Tacomaworld notifications.
  18. Sep 15, 2017 at 5:38 AM
    #2558
    Jstand
    Irving,Tx
    So I've been avoiding installing the wide-band sensor because i have to do it under the truck is 9 or 3 o'clock as far as angle or does it have to be 10-2 its going to be difficult but i may just try
  19. Sep 15, 2017 at 6:24 AM
    #2559
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tacoma World loves you.
    Try to get it as close to the degree the instructions say.
  20. Sep 15, 2017 at 6:29 AM
    #2560
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Wbo2 is most important thing to install after adding boost. I've got burnt valves that say so.
