Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 18, 2017 at 10:02 AM
    #2601
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    That's a good record!
    yota243[QUOTED] likes this.
  2. Sep 18, 2017 at 10:33 AM
    #2602
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Add more good gas?
    Do you have a fuel pressure gauge?
    Jcyr likes this.
  3. Sep 18, 2017 at 2:11 PM
    #2603
    j0shu4
    Going to have to drive it off. Thing needs a retune anyway at some point. Wish I knew enough to tune it my self......
    Brice, Jstand and Jcyr like this.
  4. Sep 18, 2017 at 3:17 PM
    #2604
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    MadTaco461, j0shu4[QUOTED] and Torspd like this.
  5. Sep 18, 2017 at 9:01 PM
    #2605
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Finally get to see a video of ken blocks turbo mustang next week. Felt like that thing has been teasing me for the last year or longer. At least ol smokey helped with the anxiety.
    TacoLeeSD, Torspd and j0shu4 like this.
  6. Sep 18, 2017 at 10:27 PM
    #2606
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Have any of you guys messed around with custom intake manifolds? i know for N/A engines the runner length, plenum size and all that are important, but what about turbo motors?
  7. Sep 19, 2017 at 2:20 AM
    #2607
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    High flow cat= less conversion of pollutants to acceptable emissions. Yes 3" vband. It took me about 2 hours to cut and weld 2 identical cat assemblies (one real cat and one dummy).
    Keep in mind that boost opens up the door for more heat, more pressure and more pollutants... all of which kill cats in a hurry. I had my high-flow magnaflow cat installed for 1 year before it was basically useless. That's why I decided to have a normal oem style cat just for the sake of passing emissions.
    Clay_916[QUOTED][OP] likes this.
  8. Sep 19, 2017 at 2:29 AM
    #2608
    GioGuitarDude
    Gio
    Cold air intake
    Fat and short (or even non-existent) runners are best for extreme boost applications like 1000HP Supras and such... but for low boost and especially for pickup trucks, long and skinny is optimal.
  9. Sep 19, 2017 at 2:31 AM
    #2609
    GioGuitarDude
    Gio
    Cold air intake
    That's so weird that you and I both developed this lean running nonsense at around the same time. What are your AFR's at full boost now?
  10. Sep 19, 2017 at 6:02 AM
    #2610
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What is this about a new turbo Mustang video???
  11. Sep 19, 2017 at 7:38 AM
    #2611
    MadTaco461
    CA
    Kinda stock
    https://instagram.com/p/BZMxOLrBOM7/
    This one. They slapped 2 gtx turbos on the hood. Spool, antilag, banging off the rev limiter.
    TacoLeeSD and Brice like this.
  12. Sep 19, 2017 at 8:08 AM
    #2612
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Sep 19, 2017 at 9:11 AM
    #2613
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I've thought about it but like geo mentioned it's more for top end performance. To get the most out of it you would have to change a lot of other components on the engine since it's built for low end. It's just way too easy with a turbo to run a few extra pounds and more fuel to get some power instead of trying to maximize intake/head flow.
  14. Sep 19, 2017 at 9:59 AM
    #2614
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    MadTaco461 and yota243 like this.
  15. Sep 19, 2017 at 11:30 AM
    #2615
    MadTaco461
    CA
    Kinda stock
    I remember a few weeks ago someone was saying they had an issue with LC Engineering customer service. They weren't kidding. I got the cold shoulder just trying to order a flipping clutch. Just ordered it online thru their website instead so I don't have to talk to anyone. That was annoying. Just had a simple clutch option question. I don't know what is going on there. I'm just a guy looking to spend money on his truck.
    Jcyr and Brice like this.
  16. Sep 19, 2017 at 12:19 PM
    #2616
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    MadTaco461[QUOTED] likes this.
  17. Sep 19, 2017 at 12:56 PM
    #2617
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Engine builder working at a desk? :notsure:
    TacoLeeSD likes this.
  18. Sep 19, 2017 at 1:28 PM
    #2618
    MadTaco461
    CA
    Kinda stock
    Technical salesman is all I ask for. Just asking about if there was an option about swapping out a throw out bearing.
    It's like asking to substitute olives for pickles on a sandwich.
  19. Sep 19, 2017 at 1:38 PM
    #2619
    boostedka
    James
    NM
    When I was figuring out a clutch set up for my truck, I called to ask them about their pressure plates along with some other possible options and the guy I talked with didn't seem to give a crap to help out. So I just said thanks and figured out something else that didn't use LCE parts
  20. Sep 19, 2017 at 1:53 PM
    #2620
    MadTaco461
    CA
    Kinda stock
    Yeah I was about to do that, but didn't want to spend another 2 weeks researching different options. Nothing easy about this transmission swap, lol.
    boostedka[QUOTED] likes this.
