Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 26, 2017 at 9:10 PM
    #2701
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Got some more transmission talk if anyone's interested on the r150s and t cases
  2. Sep 27, 2017 at 1:36 AM
    #2702
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Yes go on
  3. Sep 27, 2017 at 5:22 AM
    #2703
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just like everyrhing.
  4. Sep 27, 2017 at 5:51 AM
    #2704
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MadTaco461 and Brice like this.
  5. Sep 27, 2017 at 6:25 AM
    #2705
    Jcyr
    Jack
    North east
    Jstand likes this.
  6. Sep 27, 2017 at 6:38 AM
    #2706
    Jcyr
    Jack
    North east
  7. Sep 27, 2017 at 7:05 AM
    #2707
    GreeGunc
    Jacob
    North GA
    The r150 from the 3.0 has a 160mm input shaft with a passenger side drop t case.
    R150 from a 3.4 has a 190mm input with the tacoma driver side drop t case.
    The tacoma t cases bolt up together but not the pre tacomas
    So therefore I'll have a passenger side drop t case from a 3.0 with the 3.4 input swapped in...perfect for a SAS with the 3.4
  8. Sep 27, 2017 at 7:31 AM
    #2708
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I bought a couple reducers, a silicone hump, a 90º, and a straight. Being so long, they can be cut to create multiple couplings.
    I also ordered a 321 stainless U-bend with a 2.5" CLR
    MadTaco461 and Jcyr[QUOTED] like this.
  9. Sep 27, 2017 at 7:53 AM
    #2709
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  10. Sep 27, 2017 at 8:37 AM
    #2710
    Jcyr
    Jack
    North east
    What sizes should I buy?!? Advise me lol
  11. Sep 27, 2017 at 8:39 AM
    #2711
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :gossip: Pst. Need to know which sizes you need. Turbo outlet, intercooler inlet/outlet, tubing sizes.....
    GioGuitarDude likes this.
  12. Sep 27, 2017 at 8:59 AM
    #2712
    Jcyr
    Jack
    North east
    I’ll find out today any idea of how long the sale will last
  13. Sep 27, 2017 at 11:04 AM
    #2713
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I wouldn't go bigger than 2.5" if you plan on staying under 12 psi.
    You're going to need at least 8 elbows (mostly 90 deg but probably one or two 45 deg) and at least 2 straight couplers. The throttle body is 2.75" IIRC, so you'll need one reducer elbow (2.5" to 2.75"). Every year of Taco is a little different though, so you are going to have to map it all out and decide where the intercooler will be... then go from there.
  14. Sep 27, 2017 at 11:06 AM
    #2714
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Probably 2.5"-3" but it all depends on the turbo. The inlet of the 5vz-fe is 2.75" so keep that in mind
    Torspd likes this.
  15. Sep 27, 2017 at 11:10 AM
    #2715
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    FWD is supposed to be hella fun. Hold gas+ hit brake= easy oversteer.
  16. Sep 27, 2017 at 12:19 PM
    #2716
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Yeah, it's good fun and the FWD cars are significantly faster than an identically equipped RWD because of left foot braking. I've owned two of them because of that. Just not sure what my driving style suits, it might turn out that I drive RWD faster than FWD because of my driving style, or even AWD is better
  17. Sep 27, 2017 at 1:59 PM
    #2717
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    If you have a limited slip center diff AWD is going to be a lot more competitive than either.
  18. Sep 27, 2017 at 2:48 PM
    #2718
    Gaunt596
    Matthew
    Central Maryland
    On paper, sure. Depends on the stage and the rally. The 4wd cars don't do well on tigh, technical rallies, but the 2wd cars don't do well on the wide open rallies. It's a trade-off and actual real wporld speed depends on the driver as much as the car. But enough :threadjacked: from me
  19. Sep 27, 2017 at 3:06 PM
    #2719
    MadTaco461
    CA
    Kinda stock
    Just add a hoon handle
    Torspd likes this.
  20. Sep 27, 2017 at 3:29 PM
    #2720
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Yeah and Lance Armstrong on a bicycle is faster than a 6 year old in a 1000 hp sti.
