Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 3, 2017 at 8:43 AM
    #2861
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    MrCrowntown and boostedka like this.
  2. Oct 3, 2017 at 8:52 AM
    #2862
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I used it on my truck since my psi per cylinder was at the lowest allowed value lol. I went from 150 per cylinder to 190-210 per cylinder. It works good. I'll post results in my build eventually
    Jcyr, yota243[QUOTED] and boostedka like this.
  3. Oct 3, 2017 at 8:53 AM
    #2863
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    The dowstream sensor has the (mod) resistor tied in to it. I replaced the upstream sensor with #234-4162 in the stock position and i did clean the maf with maf cleaner. I was thinking to re clean the TB and check the TPS
  4. Oct 3, 2017 at 10:57 AM
    #2864
    Jstand
    Irving,Tx
    After talking with the guys at LCE I found out that my TPS could be adjustable or not. Iv been reading a lot about the symptoms of a faulty TPS and the problems that I'm having seem to be the same we shall see
    boostedka likes this.
  5. Oct 3, 2017 at 11:49 AM
    #2865
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    :fingerscrossed:
    Jstand[QUOTED] likes this.
  6. Oct 3, 2017 at 11:51 AM
    #2866
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Right now, just parts wise. Without actually getting it in I've priced around 6000, not including exhaust system or electrical and ac issues
  7. Oct 3, 2017 at 11:51 AM
    #2867
    boostedka
    James
    NM
  8. Oct 3, 2017 at 1:01 PM
    #2868
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
  9. Oct 3, 2017 at 1:59 PM
    #2869
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    All this turbo talk has convinced me to buy a new oil pan and bung for my 2013 2.7l. I've contacted Waystar for their pricing for the manifold and DP, just waiting to hear back. Already have a leftover AEM Wideband gauge and sensor. Planning on slowly building everything up over the winter, as funds allow.
    Would the AEM FIC be enough piggyback if needed? It's sometimes tough to get definite answers, as some have swapped injectors while others have stayed stock. Any help would be much appreciated!
  10. Oct 3, 2017 at 2:11 PM
    #2870
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    For low boost an Aem fic will get you where you need to go.
  11. Oct 3, 2017 at 2:13 PM
    #2871
    Brice
    Brice Turbo Member
    Brice
    Texas
    For a 2.7?? 6k? I know I spent more than 3k on mine but no where near 6k. After rebuilding my CX turbo I haven't had any problems, I guess you build would have a brand name turbo?
  12. Oct 3, 2017 at 2:13 PM
    #2872
    Brice
    Brice Turbo Member
    Brice
    Texas
    The AEM is good for most things except ignition advanced or anything fancy.
  13. Oct 3, 2017 at 2:25 PM
    #2873
    GreeGunc
    Jacob
    North GA
    For the ls1, turbo I'm at around $500 right now. Not including the expensive stuff
  14. Oct 3, 2017 at 2:37 PM
    #2874
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Waystar? Haven't heard of them? They have a manifold for us?
    AEM should work fine. I have offset angles and stuff for you when you get to that point that will help you get the trigger set up. I am still working out the injectors and such but hopefully will be there soon!
  15. Oct 3, 2017 at 2:50 PM
    #2875
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I do as well so I could bust his balls on his alleged hp numbers! 354 whp?! I guess it's been a while since I looked at his build but last I recall he was running like 10 psi and stock cams. You'd need to be in the 20-25 range to be pushing 400 at the crank unless you're running one of those huge cams and you're able to spin like 6500 rpms.
    Edit: Just found one of his videos on E-70 and 17 psi, yeah he might be over 300..
    Jcyr[QUOTED] likes this.
  16. Oct 3, 2017 at 2:50 PM
    #2876
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    @MrCrowntown since I've seen your posts/build threads- you will be most valuable to me lol.
    If you remember @KirkRio did his build with the OzBoost "kit", I was able to find the supplier as Shanghai Waystar on Alibaba. I sent them communication regarding price, since they only specify 1 as minimum order- and it would HAVE to be cheaper direct from the manufacturer. The link takes you to the manifold & DP page on Alibaba.
    For right now, I'm planning on running about 6-8psi as it seems that's what would be reasonable currently. The AEM would be my way of tuning it to run safer. I seriously don't know how the OzBoost kit doesn't blow your shit up lol
  17. Oct 3, 2017 at 3:00 PM
    #2877
    Brice
    Brice Turbo Member
    Brice
    Texas
  18. Oct 3, 2017 at 3:04 PM
    #2878
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    But no motor pull... No new mountin brackets new wiring um everything... I feel like time is worth something and there will be loads more time in a turbo ls swap
    Jstand likes this.
  19. Oct 3, 2017 at 3:10 PM
    #2879
    GreeGunc
    Jacob
    North GA
    Just an ls1, not ls1 with turbo. Turbo proc rid for the 3rz
    The ls1 I have is on a standalone harness, all it Needs it fuel, power, and a gas pedal.
    Not a clue how many miles are on it though
    MrCrowntown likes this.
  20. Oct 3, 2017 at 3:29 PM
    #2880
    MrCrowntown
    Alyn
    Ky
    I also don't know how the ozboost kit doesn't wreck our motors lol but I guess its a testament to the strength of the stock internals! Also it would lend me to believe the injectors are bigger than they intended to tune the motor for. A safety buffer, if you will.
    dirtdigginjoe[QUOTED] likes this.
