Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 3, 2017 at 4:10 PM
    #2881
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Just wonder if a ls1 will be as reliable as a boosted 3rz.
  2. Oct 3, 2017 at 5:05 PM
    #2882
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  3. Oct 3, 2017 at 5:18 PM
    #2883
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    If I were to LS swap I would go
    5.3
    truck wiring harness
    99-04 silverado ecu
    3 bar map sensor
    4l80e trans w/shift kit
    Decap stock injectors
    Denmah turbo kit
    And I would bet that that setup would be more reliable than a boosted 5vz, a 3rz? I'm not sure, haven't researched those too much.
    Jcyr likes this.
  4. Oct 3, 2017 at 5:27 PM
    #2884
    yota243
    E.J.
    north Alabama
    Well i can build a lil boost goin down the road so there is hope after all
  5. Oct 3, 2017 at 5:28 PM
    #2885
    Brice
    Brice Turbo Member
    Brice
    Texas
    What do you think it is? Blown turbo?
  6. Oct 3, 2017 at 5:45 PM
    #2886
    yota243
    E.J.
    north Alabama
    Na i think its just cheap v bands and not havin a decent tune past cruise. Anyone got a link to the best price on some vibrant v band? Summit racing gonna be my best bet?
  7. Oct 3, 2017 at 5:45 PM
    #2887
    GreeGunc
    Jacob
    North GA
    I have the 5.7 with 06 silverado harness and ecu with the 4l80 trans plug
    But I want a 5spd
    Brice[QUOTED] likes this.
  8. Oct 3, 2017 at 5:50 PM
    #2888
    Brice
    Brice Turbo Member
    Brice
    Texas
    You might want to stay away from a drive by wire box, they can be a ton of trouble. 99-04 silverado ECU's have most GM firmware from the time which makes them very tune-friendly. And if you want boost an auto is usually better in times due to the fact that it keeps boost between shifts, but if you're not on the track it doesn't really matter :D
    Also if you want it to handle alot of hp you can upgrade to gen IV rods and easily handle 600whp
  9. Oct 3, 2017 at 5:54 PM
    #2889
    Brice
    Brice Turbo Member
    Brice
    Texas
    To be honest the CXracing Vbands are more beefy than the Vibrant ones :D Hard to believe I know but they have thicker threads than the vibrant ones...I actually haven't had any problems with either in several thousand miles. Basically I wouldn't mind buying the cheaper CX ones over the expensive vibrant ones.
    Also are anyone else's injectors really loud? All of the ones I've used so far have been loud, Stock, chinese or the osidetiger ones. All of them clicky and loud. I guess it's not an issue just an observation.
    yota243[QUOTED] likes this.
  10. Oct 3, 2017 at 6:17 PM
    #2890
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You should hear the Injector Dymanics injectors. Sounds like a bunch of mouse traps slapping closed. Lol.
    TacoLeeSD and MadTaco461 like this.
  11. Oct 3, 2017 at 6:21 PM
    #2891
    Brice
    Brice Turbo Member
    Brice
    Texas
    Ive consider making little insulators to keep the sound down, like little jackets for them :D
  12. Oct 3, 2017 at 6:25 PM
    #2892
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pff. Be proud.
    MadTaco461, Brice and Jcyr like this.
  13. Oct 3, 2017 at 6:37 PM
    #2893
    yota243
    E.J.
    north Alabama
    Just mash that skinny pedal harder and you shouldnt hear the injectors
    Brice likes this.
  14. Oct 3, 2017 at 6:44 PM
    #2894
    yota243
    E.J.
    north Alabama
    Just threw 2 cxvband 2.25 and a 2.5 in my ebay cart to the tune of ~$65 i guess since friday is payday i can wait... I mean i have waited a year so whats another couple days
    Torspd and Brice like this.
  15. Oct 3, 2017 at 6:49 PM
    #2895
    yota243
    E.J.
    north Alabama
    Woops quanity didnt update so i mean ~$100 oh well
  16. Oct 3, 2017 at 7:25 PM
    #2896
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    The oside 550's I'm using are quiet. I don't ever hear them.
  17. Oct 3, 2017 at 7:28 PM
    #2897
    Brice
    Brice Turbo Member
    Brice
    Texas
    Do you have your hood insulator still? I don't and I think that may be why they are so loud... You also have 2 fewer than I do lol, im not sure if it would make a difference though.
  18. Oct 3, 2017 at 7:36 PM
    #2898
    boostedka
    James
    NM
    I don't have an insulator. 2 more is 50% more. Maybe that much more noise makes it easier to hear. Lol.
  19. Oct 3, 2017 at 7:40 PM
    #2899
    Brice
    Brice Turbo Member
    Brice
    Texas
    I dunnnnnnnnnnno man they just tick alot lol maybe ill get a video of it for fun
  20. Oct 3, 2017 at 7:44 PM
    #2900
    boostedka
    James
    NM
    That'd be interesting to hear
