Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 6, 2017 at 3:33 PM
    #3001
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    If the injectors don’t flow enough will that make it have less performance than just 91 octane
  2. Oct 6, 2017 at 3:35 PM
    #3002
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    It will lean it out and do some damage i imagine
  3. Oct 6, 2017 at 3:36 PM
    #3003
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Just to be clear @Jstand the biggest reason to use e85 is the detonation resistance. Most people compare it to 105 octane fuel. It also has the neat characteristic of making more torque under rich afr conditions. Meaning at WOT and 11.5:1 you will be making more torque on e85 than even 105 octane gasoline.
    JayRolla and Jstand like this.
  4. Oct 6, 2017 at 3:37 PM
    #3004
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Well if they can't flow enough, you'll get fuel-cut and lean out. Same as if you were running pump gas. When I had my Subaru, it was safe to assume by going E85 you would upgrade your fuel pump, and go up 2 injector sizes over your current size.
    But the advantage is you can run more boost, as it's pretty similar to 105 octane and responds well to running slightly rich
  5. Oct 6, 2017 at 3:39 PM
    #3005
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    And to be even more clear if you aren't running 11.5:1 afr under boost your engine will explode.
  6. Oct 6, 2017 at 3:45 PM
    #3006
    yota243
    E.J.
    north Alabama
    Is this mostly to keep temps down under boost?
  7. Oct 6, 2017 at 3:46 PM
    #3007
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    That's a big part of it.
    yota243[QUOTED] likes this.
  8. Oct 6, 2017 at 3:53 PM
    #3008
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Yes, the entire purpose to over fuel is to cool cylinder temps as the fuel evaporates and reduce detonation.
  9. Oct 6, 2017 at 3:57 PM
    #3009
    yota243
    E.J.
    north Alabama
    Doesnt e85 also cool, similar to how water/meth works?
    Jcyr likes this.
  10. Oct 6, 2017 at 4:09 PM
    #3010
    Jstand
    Irving,Tx
    OK I’ll probably try mixing it in and just keep an eye on the AFR’s but if it cools the engine and raises the octane wouldn’t it lower the AFRs
  11. Oct 6, 2017 at 4:10 PM
    #3011
    Jstand
    Irving,Tx
    I’m running the pink tops:notsure:
  12. Oct 6, 2017 at 4:12 PM
    #3012
    yota243
    E.J.
    north Alabama
    I dont really know what that means man. E85 tales about 30% more fuel than gas. If u had to had pink tops to run regular at ur current boost level i would say they wont be enough on e85 unless there is a little extra head space somewhere in there
    TacoLeeSD likes this.
  13. Oct 6, 2017 at 4:15 PM
    #3013
    Jstand
    Irving,Tx
    OK so the E85 will lean it out I guess I won’t use it Maybe I’ll get the meth water injection next kind of confusing but it did run pretty good on 112 octane racing fuel
  14. Oct 6, 2017 at 4:18 PM
    #3014
    yota243
    E.J.
    north Alabama
    U might could rig up like a 5th injector and that would be a 25% increase and might work out perfect who knows
    Jcyr and Jstand[QUOTED] like this.
  15. Oct 6, 2017 at 8:03 PM
    #3015
    Jstand
    Irving,Tx
    Mine is at 12.3 steady
  16. Oct 6, 2017 at 8:12 PM
    #3016
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    E85 requires 20-30% more fuel since it's less dense than gas. So yes you will run lean without tuning and larger fuel pump.
    Meth injection will lower chance if detonation so you can run more boost and timing. It acts as fuel so will make you run more rich lowering injector idcs so you don't need more injector or fuel pump.
    E85 is the way to go for power. My talon made 300/300 whp/tq at 17psi, 10.5 afr and 15* timing on pump gas and I was maxed out. 2-4 counts of knock on data logger.
    E85 tune made 405/430 whp/tq at 32-36psi, 12.5 AFR 22* timing. Zero detonation. Zero timing pull.
    TacoLeeSD and MadTaco461 like this.
  17. Oct 6, 2017 at 8:23 PM
    #3017
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Should I be a jerk and say that e85 has a different lambda but you have a gasoline afr gauge.
    To run e85 you want cruising to be at Your 14.7 still
    Spool up about 13.5 and wot at 12.1 to 11.5.
    This is reading with a gasoline afr gauge.
    Putting in e85 without tuning your open loop you'll see your truck go crazy lean.
    Zoom zoom boom real quick
    TacoLeeSD and JayRolla like this.
  18. Oct 6, 2017 at 11:55 PM
    #3018
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    That’s because of the simpler molecular structure (9 atoms vs dozens) as well as the higher endothermic reaction rate. Basically it turns into a gas from liquid way faster and easier than gasoline and that reaction obsorbs more energy (heat), therefore increasing the temperature differential between the vaporization phase and the combustion phase. Higher temperature differential = higher thermal efficiency = higher torque output.
    EDIT: and yes, running pure e85 on a regular gas tune at 11.5:1 AFR (open loop) will result in an AFR of 15.36:1 (on a gasoline calibrated gauge).
    Torspd and Brice like this.
  19. Oct 7, 2017 at 5:01 AM
    #3019
    Jstand
    Irving,Tx
    Ok thx everyone i just want to mix in 3gl or so with a tank every once in a while and my afrs are goodo_O
  20. Oct 7, 2017 at 6:11 AM
    #3020
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Depends on the outlet size of the turbo.
    Jcyr[QUOTED] likes this.
