Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 7, 2017 at 1:06 PM
    #3041
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I have the mapecu3 and the afr module so i can add fuel in the fuel table based on rpm and vacuum/boost
  2. Oct 7, 2017 at 1:08 PM
    #3042
    yota243
    E.J.
    north Alabama
    Brice and Jcyr like this.
  3. Oct 7, 2017 at 2:04 PM
    #3043
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    On the 2nd Gen, open loop is activated by a few variables. Rpm, load, or TPS. It transitions into open loop pretty quickly or easily on ours. N/A open loop is in the 10's. OEM ecu calibration.
    Clay_916[QUOTED][OP] likes this.
  4. Oct 7, 2017 at 2:07 PM
    #3044
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Too rich and or a vacuum issue will cause the stumble. Good to see that you have boost again. That exhaust leak was all fixered uppered good?
    yota243[QUOTED] likes this.
  5. Oct 7, 2017 at 2:09 PM
    #3045
    yota243
    E.J.
    north Alabama
    It still has an exhaust leak i should have the new clamps in by next weekend and hope to spool 1000 rpms sooner:burnrubber:
  6. Oct 7, 2017 at 2:11 PM
    #3046
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Going to have to reweld them on?
    yota243 likes this.
  7. Oct 7, 2017 at 2:22 PM
    #3047
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    834351CE-E84C-4A14-B673-0FCA7E100D6E.jpg Here goes I put 3gl
    yota243 and Brice like this.
  8. Oct 7, 2017 at 2:23 PM
    #3048
    yota243
    E.J.
    north Alabama
    I dont think so. They are pretty close (like closer than 1/8") and i think i decent clamp will close that up where the ones i have are bending
  9. Oct 7, 2017 at 2:25 PM
    #3049
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    So I just got back from doing some tuning. Open loop is pretty solid now at 11.1-11.8 and I ended up clamping my MAF at 3.9 volts to get stable AFR's that aren't crazy rich. But I have run into the issue of not being able to alter closed loop. My O2 settings are Offset and MAP based. Im not sure why I cant alter closed loop anymore, I didn't touch anything related to the closed loop values.
    Jstand and yota243 like this.
  10. Oct 7, 2017 at 2:27 PM
    #3050
    yota243
    E.J.
    north Alabama
    Just keep an eye on ur afrs and u should be fine. How is ur closed loop boost? Does the stock ecu not wanna keep u at 14.7 in closed loop?
  11. Oct 7, 2017 at 3:52 PM
    #3051
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need to bring that bad boy back over and take me for a ride along. Need to feel the torque kick of boost back in my life!
    Brice[QUOTED] likes this.
  12. Oct 7, 2017 at 3:55 PM
    #3052
    Jstand
    Irving,Tx
    RedLantern, MadTaco461 and Brice like this.
  13. Oct 7, 2017 at 3:56 PM
    #3053
    Brice
    Brice Turbo Member
    Brice
    Texas
    Im free most Fridays and Saturdays :thumbsup: Just tell me when
    (assuming my chemistry teacher stays on schedule lol)
    Jcyr likes this.
  14. Oct 7, 2017 at 3:57 PM
    #3054
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looks like it is accelerating pretty quickly, @Jstand . I'd say that you have most of the kinks ironed out.
    Jcyr and Jstand like this.
  15. Oct 7, 2017 at 3:57 PM
    #3055
    Jstand
    Irving,Tx
    Yes it’s ok it pretty much stays at 14.7
  16. Oct 7, 2017 at 3:58 PM
    #3056
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am free today. Just ordered a giant pizza too. :hungry:
  17. Oct 7, 2017 at 3:58 PM
    #3057
    yota243
    E.J.
    north Alabama
  18. Oct 7, 2017 at 4:02 PM
    #3058
    Jstand
    Irving,Tx
    I did have all the windows up
  19. Oct 7, 2017 at 4:09 PM
    #3059
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Next Friday or Saturday would be cool.
  20. Oct 7, 2017 at 4:11 PM
    #3060
    yota243
    E.J.
    north Alabama
    I wanna come... But there prolly isnt enough e85 between here and there to get me to tx also i kinda dont wanna drive 1000+ miles so I guess ill catch yall next time
