Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 12, 2017 at 8:05 PM
    #3221
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    No this is great info. The Toyota stock fpr seems to be great. Must be based off the Supra FPR.
    Brice[QUOTED] likes this.
  2. Oct 13, 2017 at 1:06 AM
    #3222
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    If I got a MAP-ECU3 and the MAP-ECU AFR Module, would iMAPCAL output the AFR or would I still need to get another wideband?
  3. Oct 13, 2017 at 2:53 AM
    #3223
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You need a separate wideband because you're altering the stock sensor signal to trick the ECU. The MAP-ECU3 software will only show AFR if you feed it the output signal from your wideband. It doesn't use that info for anything except datalogging.
  4. Oct 13, 2017 at 4:39 AM
    #3224
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    that car moves!
    if i could have found a decent gsx i would have gone that route
  5. Oct 13, 2017 at 9:23 AM
    #3225
    05Taco4x4
    2TR-FE Enthusiast
    This just doesn’t make sense to me. I’m assuming, by your description, that the AFR output wire is cut and becomes an input to the MAP-ECU; the MAP-ECU then sends out a laundered signal to the ECU. If true, I would think the MAP-ECU would display the actual input. Or if there is a separate input wire for AFR display, why couldn’t someone just connect this wire to the AFR output wire too?
  6. Oct 13, 2017 at 9:35 AM
    #3226
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    the way I understand it is, the ecu needs to read afrs from the factory wideband, if u adjust those numbers the ecu then makes adjustments based on that. however if that is also what you are using to read afrs, the numbers you read will now be incorrect because you have tricked the ecu into thinkin the afrs are not what the factory widebands reading and you will get a false read because of this. so tuning from this point on would become a shot in the dark because you would have no idea what the actual afrs are. and seems like the stock wide bands are voltage and not resistance or something something something
    JayRolla, MadTaco461 and Jstand like this.
  7. Oct 13, 2017 at 9:46 AM
    #3227
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    That makes sense
  8. Oct 13, 2017 at 9:52 AM
    #3228
    yota243
    E.J.
    north Alabama
    I have my moments
    Brice, MadTaco461 and Jstand[QUOTED] like this.
  9. Oct 13, 2017 at 9:52 AM
    #3229
    05Taco4x4
    2TR-FE Enthusiast
    I need to look at the MAP-ECU schematic
  10. Oct 13, 2017 at 10:06 AM
    #3230
    05Taco4x4
    2TR-FE Enthusiast
    I can’t find a pinout. This is the idea..
    What my understanding is of how people are doing it:
    My idea, connect both inputs to the AFR output
  11. Oct 13, 2017 at 10:15 AM
    #3231
    05Taco4x4
    2TR-FE Enthusiast
    2AC9CE10-7867-47B0-8947-3C1F66B54213.jpg This is how I would have assumed it would work, unless I was trying to sell you another AFR too :rolleyes:
  12. Oct 13, 2017 at 10:35 AM
    #3232
    yota243
    E.J.
    north Alabama
    well just got off the phone with CXracing and got my clamps ordered. I had a half dozen $25 prepaid cards and multiple tenders are not very internet friendly so had to phone one in, but I think it saved my about $10 on shipping somehow so I'm ok with that
  13. Oct 13, 2017 at 10:40 AM
    #3233
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With a 9180???? What other secrets are you keeping? :spy: You building this for TX2K, or something similar?
  14. Oct 13, 2017 at 10:51 AM
    #3234
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    True taking the unmodified signal would work. Just easier to have a standalone afr gauge with wideband because you'll need to come up with a separate gauge on your dash.
    05Taco4x4[QUOTED] likes this.
  15. Oct 13, 2017 at 10:57 AM
    #3235
    05Taco4x4
    2TR-FE Enthusiast
    I was wanting to display the AFR with the iMAPCAL app
    MadTaco461[QUOTED] likes this.
  16. Oct 13, 2017 at 11:03 AM
    #3236
    MadTaco461
    CA
    Kinda stock
    Sweet. I don't have the wifi module or an iPhone so it was cheaper to do a wideband.
    You might need to give them a 0-5v table for your wideband if one doesn't exist yet.
  17. Oct 13, 2017 at 11:07 AM
    #3237
    05Taco4x4
    2TR-FE Enthusiast
    I'm new to all this, I don't know how to capture that. I don't even have a MAP-ECU3 yet- just trying to educate myself before a purchase, to know exactly what I'm getting myself into.
  18. Oct 13, 2017 at 11:09 AM
    #3238
    Sacrifice
    KS
    DCSB OR 4X4 LT
    the 8374 is rated 700 crank which may be possible to get to the wheel with a some push. :notsure: havent done the maths. just dreaming until the car is up and running first.
    no but that would be fun to go to. been wanting a high hp car and figure this should do it just fine, haha. wipe a few grins off some newer cars
    Torspd[QUOTED] likes this.
  19. Oct 13, 2017 at 11:30 AM
    #3239
    MadTaco461
    CA
    Kinda stock
    You can download all the software and manuals for free off their website to play with.
    Jcyr and 05Taco4x4[QUOTED] like this.
  20. Oct 13, 2017 at 1:57 PM
    #3240
    yota243
    E.J.
    north Alabama
    05Taco4x4 likes this.
