Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 15, 2017 at 7:22 PM
    #3281
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    You can see the seat on the female flange to the left, and you'll see the one on the right has no seat
    EDIT: Female
    MadTaco461[QUOTED] likes this.
  2. Oct 15, 2017 at 7:25 PM
    #3282
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Well learned something new today, lol. Or just my turbo is really ghetto.
  3. Oct 15, 2017 at 7:26 PM
    #3283
    Brice
    Brice Turbo Member
    Brice
    Texas
    Something new I can use next time. Lol all my stuff is welded and non leaky so I'm gonna keep it that way
  4. Oct 15, 2017 at 7:29 PM
    #3284
    MadTaco461
    CA
    Kinda stock
    It doesn't leak if I hook it up nicely. Next time I'll do it correctly. Makes sense having an interlock.
    Brice[QUOTED] likes this.
  5. Oct 15, 2017 at 8:07 PM
    #3285
    MadTaco461
    CA
    Kinda stock
  6. Oct 15, 2017 at 8:13 PM
    #3286
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Vibrant Performance v-band flanges, or www.stainlessheaders.com
    Unless they don't carry a size that you need. Burns stainless and Reidwashbon also carry them.
    Jcyr[QUOTED] likes this.
  7. Oct 15, 2017 at 8:14 PM
    #3287
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Vibrant sell flat machined flanges and male/female flanges.
    MadTaco461 likes this.
  8. Oct 15, 2017 at 8:16 PM
    #3288
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If the flanges are slip through for the tube, then you slide one flange back a little to make a male, and the other forward, to make a female.
    MadTaco461, RedLantern and Brice like this.
  9. Oct 15, 2017 at 8:18 PM
    #3289
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    Sounds great!!
  10. Oct 15, 2017 at 8:22 PM
    #3290
    MadTaco461
    CA
    Kinda stock
    I haven't heard that sound for a while. Even some low boost with a bit of bov makes the day better.
    yota243 likes this.
  11. Oct 16, 2017 at 5:08 AM
    #3291
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  12. Oct 16, 2017 at 6:54 AM
    #3292
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    yota243[QUOTED] likes this.
  13. Oct 16, 2017 at 6:54 AM
    #3293
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I don't like being teased too long. Better get a good pull in soon!
  14. Oct 16, 2017 at 6:58 AM
    #3294
    yota243
    E.J.
    north Alabama
    it still has a little leak, clamps should be in today or tomorrow but it pulls pretty good, and I didn't even break 4k rpms. when I get all the kinks worked out this thing should scream
  15. Oct 16, 2017 at 6:59 AM
    #3295
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'll be happily surprised at its performance, once you get those last kinks ironed out.
    Jcyr and yota243[QUOTED] like this.
  16. Oct 16, 2017 at 8:04 AM
    #3296
    yota243
    E.J.
    north Alabama
    has DD got his ls rollin yet?
    Jcyr likes this.
  17. Oct 16, 2017 at 9:35 AM
    #3297
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    The next thing will be to eliminate the catalytic converter. After several months of leaded racing fuel and 225000 miles im thinking it might be clogged. No cel because the sensor is modded. I think ill just tack out the cat cut the flanges off and weld them on to a straight pipe so it will bolt in.
  18. Oct 16, 2017 at 9:39 AM
    #3298
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Eventually I plan on having an emissions pipe with a cat and 02 and a catless pipe for every other time of the year. Just not sure what I'll do to delete the rear o2 and not get codes
  19. Oct 16, 2017 at 10:39 AM
    #3299
    MadTaco461
    CA
    Kinda stock
    I'll make something better next week. Maybe something on dirt. Going to get the tundra tail lights wired up this week so I don't get pulled over.
  20. Oct 16, 2017 at 10:41 AM
    #3300
    Brice
    Brice Turbo Member
    Brice
    Texas
    Torspd likes this.
