Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 16, 2017 at 10:59 AM
    #3301
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Just sharing my experience here too in case it helps anybody out or gives an idea for somebody......
    Learned myself how to powdercoat in my garage. Its fairly easy and not super expensive either. Pretty cool stuff it came out good. Not a Tacoma part but it worked amazing and is SUPER tough. Wish I knew how to or did this years ago. Tow hook off my CTS-V. Next up is the calipers......
  2. Oct 16, 2017 at 11:10 AM
    #3302
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That will do much better than a manual one. GFB's manual one would even be better than the eBay junk.
    I had a Greddy Profec BII. With it I could have the boost threshold lowered in the rpm range, by keeping the wastegate closed completely until regulated boost was realized. It was a very nice component.
    Brice[QUOTED] and Jcyr like this.
  3. Oct 16, 2017 at 11:28 AM
    #3303
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    That would be a nice feature. My wastegate cracks open even before I get into boost (as indicated on boost gauge) while accelerating. The wastegate reference is at the turbo outlet, and my boost controller is referenced at the manifold though. So no suprise it's happening. At the same time it makes a nice smooth acceleration, it's doesn't just hit all at one. I feel like it may be saving driveline parts.
  4. Oct 16, 2017 at 11:30 AM
    #3304
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I've been thinking about this for a while. I've got a large Oster countertop oven I don't use anymore. I'm considering getting a and put a inline to a shop vac.
    Dalandser and j0shu4[QUOTED] like this.
  5. Oct 16, 2017 at 11:30 AM
    #3305
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    @j0shu4 that looks really good. I thought you had a fancy high dollar powdercoating oven, then I looked closer and it's just a toaster oven on it's side LOL
  6. Oct 16, 2017 at 11:38 AM
    #3306
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Didn't you lose that one to an ex or something?
  7. Oct 16, 2017 at 2:47 PM
    #3307
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  8. Oct 16, 2017 at 2:52 PM
    #3308
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    She still has it. Lol.
  9. Oct 16, 2017 at 4:23 PM
    #3309
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    6013BF30-57D4-456E-A89C-456D83B3A8DE.jpg Paintyyy paintyyyy
    05Taco4x4, Brice, MadTaco461 and 2 others like this.
  10. Oct 16, 2017 at 4:56 PM
    #3310
    j0shu4
    $35 at Costco hahaha! Lol
    Brice, Jcyr and MadTaco461 like this.
  11. Oct 16, 2017 at 7:20 PM
    #3311
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    You can install an extension pipe bit that screws into the o2 sensor bung on the exhaust pipe, then install the o2 sensor into that extension. So it basically lifts the o2 sensor a couple inches out of the exhaust pipe which allows the rear o2 to receive way delayed readings and therefore trick it into thinking that your cat is working. It’s called a spark plug defowler I think.
    Jcyr[QUOTED] likes this.
  12. Oct 16, 2017 at 8:48 PM
    #3312
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not a turbo, still boost though:
    EubeenHadd, gersus, boostedka and 2 others like this.
  13. Oct 17, 2017 at 5:25 AM
    #3313
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    For anyone who was wanting to know about the 2TR-FE turbo manifold and DP...
    After some conversations back and forth, the supplier has agreed to sell single quantities the way they did mine (residential shipping to keep costs low) for anyone else who would like the manifold and DP that OzBoost uses in their "kit".
    My cost with shipping was $370 for both the manifold and DP. Shipping will differ based on location, but it SHOULD be somewhere in the range of $275 for the products, and around $90-100 for shipping to the US. I haven't received my set just yet, but I believe it should be here sometime late this week to early next week, though I am in no rush.
    If you'd like to go further, just PM me your PayPal email and shipping information so they can invoice you. Below I've attached proof of the conversation between myself and an extremely helpful (and patient) representative from the supplier.
    If anyone has any questions, feel free to PM me or reply here! Let's get some more turbskies on 2nd gen 4-bangers!
  14. Oct 17, 2017 at 6:26 AM
    #3314
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Is it normal for AFRs to go rich when you let off the throttle ?
    Brice and Jcyr like this.
  15. Oct 17, 2017 at 6:30 AM
    #3315
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Mine, even bone stock will do that for a brief moment as soon as I let off. Then it'll lean itself out from decel fuel cut.
    Jstand[QUOTED] likes this.
  16. Oct 17, 2017 at 8:47 AM
    #3316
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Yes, for a split second.
  17. Oct 17, 2017 at 8:51 AM
    #3317
    05Taco4x4
    2TR-FE Enthusiast
    They did this already. Get them to sell individual STAINLESS kits
  18. Oct 17, 2017 at 9:22 AM
    #3318
    Jstand
    Irving,Tx
    It a little more than a split second its rich until i put the throttle again but Im still trying to figure out why Im getting random lean spikes just off idle or a little past
  19. Oct 17, 2017 at 9:24 AM
    #3319
    Jstand
    Irving,Tx
    What controls the fuel cut ? I wonder if its possible to get random fuel cut briefly.
  20. Oct 17, 2017 at 11:07 AM
    #3320
    GioGuitarDude
    Gio
    Cold air intake
    I believe the TPS controls fuel cut on decel. My truck also runs pig rich on decel, but it didn’t used to before I replaced my TPS. I replaced it with a no-name oreily’s brand sensor and I have been regretting that for a couple years now.
