Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 17, 2017 at 10:32 PM
    #3361
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    This is exactly what I was trying to say earlier.
    Awesome
    MadTaco461[QUOTED] likes this.
  2. Oct 18, 2017 at 4:36 AM
    #3362
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
  3. Oct 18, 2017 at 5:34 AM
    #3363
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Brice[QUOTED] and Jcyr like this.
  4. Oct 18, 2017 at 7:42 AM
    #3364
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Brice and MadTaco461[QUOTED] like this.
  5. Oct 18, 2017 at 8:21 AM
    #3365
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I think that thread is done for. Too bad. The fab work was good.
  6. Oct 18, 2017 at 9:43 AM
    #3366
    05Taco4x4
    2TR-FE Enthusiast
    I have so much hate for photobucket. They completely turned their back on the online community for greed. Everyone needs to transplant their pics to another site and let them go out of business, turn our back on them.
  7. Oct 18, 2017 at 10:00 AM
    #3367
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Since no one on CT want's to discuss, what are yall's thoughts on Kurt's build? He's going forged rods and pistons at 10:1 CR on e85. For some reason he thinks he can make more boost than he is now which is around 15 psi. No head work what so ever. I'm kinda scratching my head on this one.
    MadTaco461 likes this.
  8. Oct 18, 2017 at 10:01 AM
    #3368
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    doesn't the 2.7 already have those?
  9. Oct 18, 2017 at 10:02 AM
    #3369
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Don't think so, but at any rate he is upgrading them.
  10. Oct 18, 2017 at 10:25 AM
    #3370
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Pretty sure the rods and pistons would allow him to crank up the boost maybe around 20-25 assuming he upgrades his gasket? I think most of the valve train upgrades are usually to handle more aggressive cams and higher rpm no?
  11. Oct 18, 2017 at 10:45 AM
    #3371
    MadTaco461
    CA
    Kinda stock
    I need to glance at his build again. I think he going to need some valve spring upgrades for head work. He's probably testing the limits of them first.
  12. Oct 18, 2017 at 10:45 AM
    #3372
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    The amount of boost you can run is restricted to detonation or indirectly fuel octane as far as I know which is why I'm confused. There will be some small gains from the pistons themselves as I'm sure they have a nicer finish/better design to resist detonation slightly better than stock but not a huge amount. Maybe the stronger rods can just withstand a high amount of detonation and the idea is to just power through it..?
  13. Oct 18, 2017 at 10:47 AM
    #3373
    yota243
    E.J.
    north Alabama
    what kind of numbers is he currently making at 15 psi? I imagine that thing has to be a monster for what it is already right?
  14. Oct 18, 2017 at 10:51 AM
    #3374
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    From what I understand rods fail primarily to high engine speed and secondarily to detonation. So if you upgrade rods you should upgrade engine speed as well. It seems like he's upgrading rods just because. I suppose it would increase the safety margin when you're pushing against the knock limit.
    He's claiming near 350 whp on e85.
    Jcyr and yota243[QUOTED] like this.
  15. Oct 18, 2017 at 10:51 AM
    #3375
    Jcyr
    Jack
    North east
    3rz rods aren’t forged from factory so he’s definitely improving I think the other thing is him running e85 which significantly lowers chance for detonation
  16. Oct 18, 2017 at 10:56 AM
    #3376
    yota243
    E.J.
    north Alabama
    op of @MrCrowntown build page
    [​IMG] [​IMG]
    As you can tell from the thick 'parting line' on the stock crank and stock rods, they are forged. They will get put back to use with a set of +.020 hyper-eutectic pistons from LCE
    sooo stock rods are forged on the 2tr??? which is what kurt has which is why I asked what I asked earlier... I'm missing something right?
  17. Oct 18, 2017 at 10:57 AM
    #3377
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I just think he's leaving shit tons of power on the table by not increasing rpms, especially because I know he won't be able to add more boost since he is most certainly at the knock limit now at 15 psi and 9.5 CR on e85.
  18. Oct 18, 2017 at 11:00 AM
    #3378
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    The term 'forged' can be applied to anything that is squished into shape, regardless of what material is being used.
    The rods are forged in the 3rz, but are made up of a shitty alloy and will bend before touching 400. The crank is also forged, but is made up of a much stronger alloy and is capable of well over 1k HP.
    The pistons are hypereutectic and should be replaced immediately if you want reliable power up to 400.
    Torspd and Brice like this.
  19. Oct 18, 2017 at 11:00 AM
    #3379
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Forged maybe but they still look a little paltry. I think the one's Kurt upgraded to are H-beam. Do you know if he is upgrading to arp rod bolts?
  20. Oct 18, 2017 at 11:01 AM
    #3380
    MrCrowntown
    Alyn
    Ky
    Yup, drop forged. But, still a shitty alloy. Seen pics from my thai friend of rods sticking out the side of a block when approaching 400
