Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 19, 2017 at 7:30 PM
    #3461
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    How much does 105 octane gas cost because where I live e85 is $2/gal and 91 octane is $3/gal. That's a 50% increase in cost which turns the tide in favor of 85 in terms of miles per gallon alone, before you even consider the performance gains due to the increased octane.
    What is "pre detonation"?
  2. Oct 19, 2017 at 7:30 PM
    #3462
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
  3. Oct 19, 2017 at 7:34 PM
    #3463
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    They will carbon foul if you don't run your engine hot frequently. The reason all cars don't use cold plugs is because you want them to regularly operate at a temperature which burns off the carbon build up. The reason to use cold plugs at all is to eliminate the heated up spark plug as a heat source for detonation. It's a balancing act. I wouldn't change them.
  4. Oct 19, 2017 at 7:39 PM
    #3464
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I personally would never run 100% e85 in my truck with the stock fuel components for long periods of time, but I also have never seen or heard of anyone having to replace parts BECAUSE they used e85. Worst case scenario your (gas only rated) fuel pump’s life is shortened a year or two. That isn’t a big deal to many. A $200 fuel pump every 5-10 years is better than a $2000 engine replacement.
    Jstand likes this.
  5. Oct 19, 2017 at 7:41 PM
    #3465
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pre detonation is pinging or knocking. Basically if there's a lot of heat your full ignites prematurely
  6. Oct 19, 2017 at 7:42 PM
    #3466
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I recently pulled my injectors and fuel rail and they had zero traces of dissolved rubber. Only been running e58 for a year now which in the grand scheme isn't a huge amount of time but if these alleged issues had ground they would have already been showing themselves. I will agree that the pump may not be happy.
    Jstand likes this.
  7. Oct 19, 2017 at 7:45 PM
    #3467
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Sorry I was being facetious, I know what pre-ignition and detonation are, pre-detonation is not a real thing.
    Edit: Don't mind me I legit have nothing better to do at the moment.
    MadTaco461 and Torspd like this.
  8. Oct 19, 2017 at 7:50 PM
    #3468
    GioGuitarDude
    Gio
    Cold air intake
    The thing that people don’t get is that gasoline is corrosive too. The problem WAS when you leave e85 in your tank for long periods of time and the tank is not air tight, the ethanol’s hygroscopic properties allowed the fuel system to be exposed to more water. Modern vehicles are designed to replace the air in the fuel tank with pressurized gasoline vapors so that there is no oxygen to make a fire hazard. Modern e85 however has a nice concoction of corrosion inhibitors that keep that aspect of it down to a minimum. The only modern problem with e85 is its lack of lubricity, which I personally address by adding 6 ounces of Lucas fuel stabilizer (lubricant) to every tank.
    EDIT: oh and “pre detonation” is detonation before (pre) the spark plug goes off. Kind of a silly word either way since gasoline vapor deflagrates, not detonates :thumbsup:
    Torspd and Clay_916[QUOTED][OP] like this.
  9. Oct 19, 2017 at 7:54 PM
    #3469
    TireFire
    Olympic Peninsula
    What a pain in the dick doing that for every tank
  10. Oct 19, 2017 at 8:01 PM
    #3470
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I just put 3.5 gl of e85 at $1.92 mixed in with 93 at $2.68 :D
    GioGuitarDude likes this.
  11. Oct 19, 2017 at 8:03 PM
    #3471
    GioGuitarDude
    Gio
    Cold air intake
    A gallon lasts me months and I add it regardless if I fill up with straight gas or an e85 mix. It’s good stuff.
    Jstand likes this.
  12. Oct 19, 2017 at 8:05 PM
    #3472
    TireFire
    Olympic Peninsula
    What's facetious?
  13. Oct 19, 2017 at 8:10 PM
    #3473
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Definition of facetious
    1:joking or jesting often inappropriately
    2:meant to be humorous or funny :not serious
    Torspd and yota243 like this.
  14. Oct 19, 2017 at 8:12 PM
    #3474
    GioGuitarDude
    Gio
    Cold air intake
    Haha you guys are funny
    Jstand likes this.
  15. Oct 19, 2017 at 8:39 PM
    #3475
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That E10 and E15 is your problem. 91 or 93 and E85. Stay away from the other two.
    yota243[QUOTED] likes this.
  16. Oct 19, 2017 at 9:09 PM
    #3476
    GioGuitarDude
    Gio
    Cold air intake
    All pump gasoline in the US is e10 regardless of octane rating (87, 89, 91 and 93), or am I missing something?
  17. Oct 19, 2017 at 9:13 PM
    #3477
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Certain places have stuff like this.
    Torspd likes this.
  18. Oct 19, 2017 at 9:16 PM
    #3478
    GioGuitarDude
    Gio
    Cold air intake
    Oh wow... never seen that many choices in the US. Around here ALL gasoline has at least 10% ethanol unless you buy pure gas from certain hobby or racing suppliers
  19. Oct 19, 2017 at 9:21 PM
    #3479
    MadTaco461
    CA
    Kinda stock
    I've seen it on business trips. I'm like why so many options. want to say it's a Midwest thing.
  20. Oct 20, 2017 at 4:15 AM
    #3480
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Like others have said everything here is e10. I know of a handful of places that sell regular 100%gas (87) and its as much as premium so even if they did carry 93 100% they would be charging nearpy double what i can get e85 for. And like i said i was mainly doing this to see if the ethanol content was causing a blow out and crazy afr. It seems as if it was.
    So my new gap should be .028 ish for e85?
