Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 20, 2017 at 10:54 AM
    #3501
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I'll just put a bunch of rocks and logs in my driveway so my gas gets nice and shook'd up before I drive.
  2. Oct 20, 2017 at 11:02 AM
    #3502
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :eek: :bowdown:
    BassAckwards and MadTaco461 like this.
  3. Oct 20, 2017 at 11:04 AM
    #3503
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Negative. Just be aware that it isn't as "fill and forget" as gasoline is. You should always use an analyzer to be safe with E85.
    MadTaco461 and Jstand[QUOTED] like this.
  4. Oct 20, 2017 at 11:37 AM
    #3504
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    so whats the point of e10/15 when gasoline already has the ~10%?
  5. Oct 20, 2017 at 11:50 AM
    #3505
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Are you guys running catch cans? If so why and how did you set it up
  6. Oct 20, 2017 at 12:05 PM
    #3506
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Less regulation? I don't know exactly. Should that be the case, then it means the consumer gets a crappier product, and the producers get more money.
  7. Oct 20, 2017 at 12:07 PM
    #3507
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Disconnect pcv system, to remove vacuum leak potential, and route to catch can..blow by enough will put vapor mist in the can..
  8. Oct 20, 2017 at 12:17 PM
    #3508
    Sacrifice
    KS
    DCSB OR 4X4 LT
    something like this or route from the pcv to the exhaust with a slash cut or you can vta at the can instead. but vacuum does help.
  9. Oct 20, 2017 at 12:33 PM
    #3509
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Ethanol has a density of .789 g/ml
    Petrol gas has a density of .79 g/ml.
    Gas would be sinking to the bottom, not ethanol... and at a .001 difference in density, this phase change would take months or years of inactive storage to fully separate.
    Sounds like this narrative is somewhat incentivized to me
    Clay_916[OP] likes this.
  10. Oct 20, 2017 at 12:53 PM
    #3510
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Except ethanol absorbs moisture from the air which increases it's density and speeds up the separation process.
    Jcyr and Torspd like this.
  11. Oct 20, 2017 at 12:54 PM
    #3511
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The water separates quickly. Within months. Then the water moves to the bottom. Plenty of boats and garage kept performance cars have fallen vicitm to the effects of pumping said water into the engine. I have a recent memory of a Ford GT that had to have its engine replaced. Sat for 6 months. Didn't drain in fill. Owner wanted to take it out. Towed to KP Racing very shortly there after.... sad day for the car.
    I also know a person who was part of the testing, which ultimately then led to AAA giving out the PSA.
    Jcyr likes this.
  12. Oct 20, 2017 at 1:29 PM
    #3512
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Maybe I should rephrase myself. I've seen it once. It exists somewhere. Probably one of those huge truck stops.
  13. Oct 20, 2017 at 1:33 PM
    #3513
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    When I was driving through Wyoming, 4 years ago, I stopped at 4 different parts of state for gas/restroom and all the stations were 100% gas, no ethanol added.
  14. Oct 20, 2017 at 1:41 PM
    #3514
    Jcyr
    Jack
    North east
    Exactly there’s a reason boats don’t ever run without a fuel water separator ethanol and moisture even just humidity is absolutely a nightmare
  15. Oct 20, 2017 at 1:44 PM
    #3515
    05Taco4x4
    2TR-FE Enthusiast
    Didn't someone just state gas tanks don't hold air like they use to, making this a mute point? Or did I read that somewhere else?
    Edit: and this obviously wouldn't include boats, so that's a different story
  16. Oct 20, 2017 at 1:47 PM
    #3516
    05Taco4x4
    2TR-FE Enthusiast
    I can attest, if you don't empty a weed eater after EVERY use, the ethanol gas will screw your carb/jets up. Ethanol gas ruined my dad's little 15HP Johnson (he didn't know ethanol's effects) too.
    TacoLeeSD likes this.
  17. Oct 20, 2017 at 1:47 PM
    #3517
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    The tanks are just as airtight as they have been since emissions regulations were put into place. I have an EVAP code because I have a broken gas cap which comes loose after a few miles.
  18. Oct 20, 2017 at 1:48 PM
    #3518
    Jcyr
    Jack
    North east
    They don’t if you’re vehicle isnew New but still need to constantly vent air in while pumping leaving problems but for most of us with trucks older than 5yrs our fuel systems are even more susceptible
  19. Oct 20, 2017 at 1:48 PM
    #3519
    05Taco4x4
    2TR-FE Enthusiast
    I just replaced my gas cap two days ago haha
    MrCrowntown[QUOTED] likes this.
  20. Oct 20, 2017 at 1:49 PM
    #3520
    05Taco4x4
    2TR-FE Enthusiast
    I have a 2005, but I'm still going E85 when I get back to the mainland, no E85 in Hawaii.
    Edit: I never go longer than 10 days without a fill up
