Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 20, 2017 at 3:19 PM
    #3521
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    It’s every 3 days for me but I drive everyday :D
  2. Oct 20, 2017 at 4:00 PM
    #3522
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    What catch cans are you running? Does it have a breather as well?
  3. Oct 20, 2017 at 4:02 PM
    #3523
    Jcyr
    Jack
    North east
  4. Oct 20, 2017 at 4:04 PM
    #3524
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Most gasoline in the US has 10% ethanol already. No commercial gasoline is stored in anything but airtight regulated containers... it’s not like the gas is sitting in open horse troughs for months absorbing tons and tons of water. I get that ethanol is hydroscopic (I’ve mentioned and addressed that here in TW for years). If we don’t store ethanol rich gas for long periods of time, it’s relatively safe. I’ve replaced fuel injectors and pumps many times, and honestly that’s a risk I’m willing to take for a knock-less engine. I’ve been using e85 AND pure denatured ethanol alcohol (to pass emissions) for years, and I’m relatively comfortable using 3-4 gallons of it in every tank. I add marvels mystery oil to my small carb/motorcycle engines (that I keep gas in all winter long) and Lucas fuel stabilizer to my truck every tank and I never have fuel quality related problems.
  5. Oct 20, 2017 at 4:24 PM
    #3525
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    All my small stuff I put fuel stabilizer in it. Works great.
    Though I live in dry socal.
  6. Oct 20, 2017 at 6:26 PM
    #3526
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    More material on the way. Just need some 347 rod, and a band saw.
    Been looking at what is needed to cut titanium. Unless you guys can find a shorter blade that fits a hand held portable band saw, looks like I'll have to get a stationary bandsaw with a 7' blade.
    MrCrowntown and MadTaco461 like this.
  7. Oct 20, 2017 at 6:31 PM
    #3527
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Would a plasma cutter work for you? I mean your gonna need one for something eventually anyway right?
  8. Oct 20, 2017 at 6:54 PM
    #3528
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Wth. I just realized, Is hawaii the only place with 92 octane?
  9. Oct 20, 2017 at 7:00 PM
    #3529
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    How short of a blade are you looking for? One option would be to take a longer blade and have it cut and rewelded to the length that you need. A lot of larger, older vertical bandsaws have built in blade welders, so you might be able to find a machine shop with one that could do it for you. Shouldn't take more than a few minutes of their time.
  10. Oct 20, 2017 at 8:26 PM
    #3530
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Been running it for over 10 years brah.
    Torspd likes this.
  11. Oct 20, 2017 at 8:27 PM
    #3531
    JayRolla
    Colorado Springs
    It's like running race gas from the pump. Mpg don't matter when making mad boost brah.
    MadTaco461 likes this.
  12. Oct 20, 2017 at 8:41 PM
    #3532
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    36" length for a porta band.
  13. Oct 20, 2017 at 8:42 PM
    #3533
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Naw. Lol. Not for cutting the tubing.
    yota243[QUOTED] likes this.
  14. Oct 21, 2017 at 4:55 AM
    #3534
    Jstand
    Irving,Tx
    Why does my truck act like it has a 5th gear. When its going through the gears once it goes into overdrive the rpms go down just a little bit more right after like another gear
  15. Oct 21, 2017 at 6:13 AM
    #3535
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    tc lockup
  16. Oct 21, 2017 at 6:20 AM
    #3536
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    What's the min/max blade size that will fit? Home Depot has a 35-3/8" 24TPI blade.
    Torspd[QUOTED] likes this.
  17. Oct 21, 2017 at 6:35 AM
    #3537
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got to be a carbide tipped blade.
    Jcyr likes this.
  18. Oct 21, 2017 at 7:16 AM
    #3538
    MadTaco461
    CA
    Kinda stock
    I go on McMaster carr website for band saw blades.
    TacoLeeSD likes this.
  19. Oct 21, 2017 at 7:25 AM
    #3539
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    You shouldn't need carbide to cut titanium tubing. A carbide blade will just last longer and cost you more. What's the wall thickness of your titanium tubing? If we knew that it would be more efficient trying to help you find a blade. Also, what width and thickness of blade does your saw take?
    Everything that McMaster recommends for cutting Ti is a carbon steel blade that is just TiAlN coated, not carbide.
  20. Oct 21, 2017 at 7:37 AM
    #3540
    MadTaco461
    CA
    Kinda stock
    Never had to work with titanium before. Wouldn't know off hand.
