Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 21, 2017 at 8:20 AM
    #3541
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Take it out of overdrive. Should eliminate TC lockout.
  2. Oct 21, 2017 at 10:50 AM
    #3542
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    https://www.ticonindustries.com/collections/mandrel-bends
    Shouldn't be more than 1.5mm wall thickness.
    MadTaco461 likes this.
  3. Oct 21, 2017 at 11:25 AM
    #3543
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    TacoLeeSD likes this.
  4. Oct 21, 2017 at 11:28 AM
    #3544
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I love watching TFS videos. One of the few videos where I actually take away knowledge at the end...and one of the few who knows where to place his cameras!
    MadTaco461[QUOTED] likes this.
  5. Oct 21, 2017 at 12:18 PM
    #3545
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Awesome video! Thanks for posting.
  6. Oct 21, 2017 at 1:18 PM
    #3546
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    MadTaco461 and Torspd[QUOTED] like this.
  7. Oct 21, 2017 at 2:56 PM
    #3547
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Only problem with that is that is at 60mph I’m at 3000 rpm and around here when you get on the freeway plan on going 70 and up
  8. Oct 21, 2017 at 3:08 PM
    #3548
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    so whats the problem? Your worried your tranny is operating as it should by leaving overdrive on?????
  9. Oct 21, 2017 at 5:09 PM
    #3549
    Jstand
    Irving,Tx
    It’s all fine I just need more boost :thumbsup:
  10. Oct 21, 2017 at 5:31 PM
    #3550
    JayRolla
    Colorado Springs
    If your towing it loaded going up mountain passes it's good to take her out overdrive because it keeps trans cooler.
    But yes normally just keep her in overdrive.
    Jstand[QUOTED] likes this.
  11. Oct 21, 2017 at 5:52 PM
    #3551
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    the torque converter still locks and unlocks outside of 5th. at least in the 2nd gens..
  12. Oct 21, 2017 at 5:54 PM
    #3552
    Blackdawg
    Monte
    Wyoming/St. Louis
    doesn't on ours. If you turn off OD..its off and your in 3rd no matter what.
  13. Oct 21, 2017 at 6:02 PM
    #3553
    Sacrifice
    KS
    DCSB OR 4X4 LT
    fair enough. thatd be a nice feature sometimes.
  14. Oct 21, 2017 at 6:59 PM
    #3554
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Same for you except you'll be in 4 not 3 and you can also shift your gears by hand. Very helpful feature when towing or off-road
  15. Oct 22, 2017 at 3:56 PM
    #3555
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    No turbo? That’s fine just take 300 Camry to a dirt track you can still drift 8AD2B7A4-9CCA-46B0-B891-DDADCE411A4A.jpg
    MadTaco461, Torspd and Brice like this.
  16. Oct 22, 2017 at 6:12 PM
    #3556
    Jstand
    Irving,Tx
    Is there an oil catch can set up that would work best with the 3rz or does it need to be custom made ?
    MadTaco461 and Jcyr like this.
  17. Oct 23, 2017 at 12:49 PM
    #3557
    Jcyr
    Jack
    North east
    I think @MadTaco461 has me he likes???
  18. Oct 23, 2017 at 12:52 PM
    #3558
    TireFire
    Olympic Peninsula
    Is an oil catch can legal in CA? I know it's easy to remove for smog if need be...
  19. Oct 23, 2017 at 1:57 PM
    #3559
    MadTaco461
    CA
    Kinda stock
    I don't have one. I vta. Bit messy and smelly. Most use a universal one. I think there is a thread on them to get mounting ideas. Try to avoid the super cheap ones.
    I wish they were legal in ca.
  20. Oct 24, 2017 at 9:20 AM
    #3560
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Kinda quiet in here. I was gonna post a video of compressed air super charging but there was an annoying beep thru most of it, plus when he said that a good chargingin system for the set up would run about 7 grand it kind of detoured me. Gotta run scuba (grade E i believe if my hazwoper memory serves correctly) air, but it was making crazy power on almost no boost because when the compressed air goes from 33000 psi to 100 psi the temps were like -150°f (this equated to like 8psi of boost at the manifold doibling the stock hp) but too rich for my blood
    Torspd, JayRolla, MadTaco461 and 2 others like this.
