Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 26, 2017 at 4:13 PM
    #3641
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Well my plug was already at .028... Should i go down to .024 while i got em out?
  2. Oct 26, 2017 at 4:22 PM
    #3642
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Stock rev limiter and low boost, the valve train is just fine on 9 psi. The pistons and rods are the weak points on the 1GR. Butting rings from tight factory gaps shatters the ring lands. Raised rpm + boost will snap the sickly rods.
    Brice and JayRolla[QUOTED] like this.
  3. Oct 26, 2017 at 4:26 PM
    #3643
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only so much timing, until it spins in reverse.... :laugh: But seriously, on ~8.7 psi with my turbo kit, (which isn't as efficient as it could be) with journal bearing 6266, it made ~400whp and 450wtq. Conservative timing, on 93.
  4. Oct 26, 2017 at 4:30 PM
    #3644
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This is back to turbos efficiency.
    Boost pressure it irrelevant to power levels. Has to do with how well the turbo is working and more importantly how much VOLUME of air it is moving. Not how high of pressure.
    Brice, Jcyr and Clay_916[OP] like this.
  5. Oct 26, 2017 at 5:09 PM
    #3645
    yota243
    E.J.
    north Alabama
    Little beefier vbands...
    05Taco4x4, RedLantern, Brice and 3 others like this.
  6. Oct 26, 2017 at 5:58 PM
    #3646
    yota243
    E.J.
    north Alabama
  7. Oct 26, 2017 at 6:01 PM
    #3647
    yota243
    E.J.
    north Alabama
    Still a little rich but i nearly put it to the floor in the video and then i did shortly afterwards. My boost gauge is only showing like maybe 6 psi but its cheap so it could be off or that generic wg spring may not quite be 7.5lb or somewhere in between. At any rate, this thing is gonna be even more of a rocket when i pull a little more fuel past 3 psi
    MrCrowntown likes this.
  8. Oct 26, 2017 at 6:11 PM
    #3648
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Well technically it's air mass that "matters" ;). There are a handful of variables that will determine final power output independent of air pressure which I think is the point you're trying to make.
    JayRolla and yota243 like this.
  9. Oct 26, 2017 at 6:19 PM
    #3649
    yota243
    E.J.
    north Alabama
    When i get stuff fixed, its gonna go faster when i mash the pedal
  10. Oct 26, 2017 at 6:30 PM
    #3650
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Or you can be like me. Run a turbo past efficiency to make more power. The little turbo I run maxed pushes 38lb/min at 30psi falling to 24psi at 8k rpms. I then clamped wastegate shut, ported turbo to creep and it hits 36psi falling to 28psi at high rpm. She hits 42lb min on a 38lb rated turbo. Its just blowing hot air, major timing and still not a blip of knock. But made over 40lbtq more than when running lower boost.
    The awesome thing about my turbo is that I see over 20psi at 3500rpm. Stock turbo from an evolution 3 lancer from Japan. Hits like a rock when you got 400lb tq at mid rpms.
    Clay_916[OP] and Torspd like this.
  11. Oct 26, 2017 at 6:32 PM
    #3651
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Where’d you grab the beef ? Summit?
  12. Oct 26, 2017 at 6:45 PM
    #3652
    yota243
    E.J.
    north Alabama
    Cxracing.com (or whatever their website is) they were like $28 a piece with 1 flange (i didnt need any flange since i already had them welded in and just had crap clamps) i think the 2 flange kits were ~$35. It knocked like 400 rpm at least of my spool
    JayRolla and MadTaco461 like this.
  13. Oct 26, 2017 at 6:46 PM
    #3653
    Jcyr
    Jack
    North east
    Didn’t you previously hate in the cx flanges?? Or was that someone else
  14. Oct 26, 2017 at 6:48 PM
    #3654
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah see..if you had a turbo that ran at 42lb/min you'd make even more power..probably a lot more. But you'd completely change your power band and response.
    Thus the challenges of boosting.
  15. Oct 26, 2017 at 6:51 PM
    #3655
    yota243
    E.J.
    north Alabama
    Nah wasnt me. We did decide that the cx flanges are all female (or possibly supposed to have a bit of the exhaust pipe stick thru on one side to fix that issue )tho, and the ones i had had a male and female system
  16. Oct 26, 2017 at 6:58 PM
    #3656
    Jcyr
    Jack
    North east
    Within the next 3-5 years we will start seeing an electric spool that initially feeds the turbo under 2-3k rpm. Toyota I think even pulled a patent on something of the sort this year
  17. Oct 26, 2017 at 7:01 PM
    #3657
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah an electric assist turbo would be smart. Complex though. And expensive.
    Probably cheaper than twin charging though.
  18. Oct 26, 2017 at 7:05 PM
    #3658
    Jcyr
    Jack
    North east
    Yeah the two big advantages from the initial tests I could find are 1. You don’t have to deal with the restrictions of the smaller turbo when you reach the high rpm.
    2. You a single turbo system is dramatically easier/cheaper to keep cool when exposed to daily driving conditions.
  19. Oct 26, 2017 at 7:10 PM
    #3659
    yota243
    E.J.
    north Alabama
    Boring and HiFire like this.
  20. Oct 26, 2017 at 7:17 PM
    #3660
    Blackdawg
    Monte
    Wyoming/St. Louis
    interesting. But that is a full hybrid motor bolt on.
    Jack is talking about having a turbo with an electric motor attached to it. So it keeps the turbo spun up like an anti lag system.
    yota243[QUOTED] likes this.
