Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 29, 2017 at 5:37 PM
    #3721
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Jcyr[QUOTED] likes this.
  2. Oct 30, 2017 at 2:34 AM
    #3722
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Those who have their turbo setup rolling you guys should post some videos smoking tires :rofl::rofl:
  3. Oct 30, 2017 at 6:55 AM
    #3723
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  4. Oct 30, 2017 at 7:06 AM
    #3724
    yota243
    E.J.
    north Alabama
    I don't plan on doing too much smoking on 33" MTs but I will keep what videos I can coming in
    Jstand, MadTaco461 and Jcyr[QUOTED] like this.
  5. Oct 30, 2017 at 7:20 AM
    #3725
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I can't smoke 33 mt either. Something going to break,lol
  6. Oct 30, 2017 at 7:23 AM
    #3726
    yota243
    E.J.
    north Alabama
    I feel like saving my MT's but I wouldn't mind getting some stock height 295's or something for the rears to take down to strip when I get everything ironed out and see how long it takes to get from a to b
    Jstand and MadTaco461[QUOTED] like this.
  7. Oct 30, 2017 at 7:31 AM
    #3727
    MadTaco461
    CA
    Kinda stock
    I'll stick to dirt. Throw some roost.
  8. Oct 30, 2017 at 8:29 AM
    #3728
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I did my 35's KM2's.....:burnrubber:
    Then one day my ring and pinion went :boom:
  9. Oct 30, 2017 at 9:53 AM
    #3729
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    will smoke my old set of 32s off when ready.
    theyre dried up and literally dont smoke at all tho...
  10. Oct 30, 2017 at 10:39 AM
    #3730
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Being that my junk runs 0w-20 in it currently- should I up to 5w-30 or similar once the turbo is installed? 0w-20 is pretty damn thin. I would think you'd want a little thicker oil now.
  11. Oct 30, 2017 at 10:42 AM
    #3731
    yota243
    E.J.
    north Alabama
    runnin 0w-40 mobile 1 full synthetic in mine
  12. Oct 30, 2017 at 10:56 AM
    #3732
    MadTaco461
    CA
    Kinda stock
    I've had the opportunity to blow apart a diff at a signal. Those clutch dumps always get me.
  13. Oct 30, 2017 at 11:10 AM
    #3733
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I think once the winter passes, I'll go to 0w-30/40. I run Amsoil Signature Series only (since I'm a dealer lol), and I'm trying to get the timing of my turbo install lined up with my next oil change interval.
    Jcyr and yota243[QUOTED] like this.
  14. Oct 30, 2017 at 11:11 AM
    #3734
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    #clutchkicklife
    MadTaco461 likes this.
  15. Oct 30, 2017 at 11:12 AM
    #3735
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'll want a 30 weight.
    dirtdigginjoe[QUOTED] likes this.
  16. Oct 30, 2017 at 2:01 PM
    #3736
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Question for everyone are your AFR is consistent meaning when you’re at Idol or cruising they stay around 14.7 but whenever you push the gas do they go down to the 12.0-13.0 range or do they go up and then down as your in the throttle ?
  17. Oct 30, 2017 at 2:07 PM
    #3737
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    It should be decently consistent until you hit open loop, at which point it should drop. If you have a piggyback, you can adjust the severity of the drop to lower your AFR on tip-in. I can't remember if you're running any EMS... Are you?
  18. Oct 30, 2017 at 2:28 PM
    #3738
    Jstand
    Irving,Tx
    Nope no control just stock but @boostedka ran the same setup as me with no issues like this. I don’t have any codes so I keep putting it out there in case someone has had this issue.
  19. Oct 30, 2017 at 3:28 PM
    #3739
    Jstand
    Irving,Tx
    @boostedka have ever had any issues with your o2 sensor locations
  20. Oct 30, 2017 at 4:58 PM
    #3740
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I haven’t. When I built my DP and exhaust, I measured roughly how far away they were from the cat and welded them in close to the same distance away
    Jstand[QUOTED] likes this.
