Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 12, 2017 at 2:29 PM
    #361
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Agreed! That was some hardcore google work :laugh:
  2. Apr 12, 2017 at 2:31 PM
    #362
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Apr 12, 2017 at 2:38 PM
    #363
    Skeou
    Skeou Well-Known Member
    Austin
    Florence, Alabama
    2019 Tacoma MGM TRD Sport
    25% tint, AVS in-channel wind visors, Bed-Mat, Spidertrax spacers all around, 4Runner TRD Pro wheels
    Hey everybody, I'm relatively new to turbos and would love to get a rear mount setup on my 2.7 3rd gen running low boost just for some extra power to play with. What modifications would need to be made for it to work reliably? Would I have to improve my fuel system?
  4. Apr 12, 2017 at 2:39 PM
    #364
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  5. Apr 12, 2017 at 2:40 PM
    #365
    Blackdawg
    Monte
    Wyoming/St. Louis
    first off...do you offroad a lot? Why a remote system and not in the engine bay?
    j0shu4 likes this.
  6. Apr 12, 2017 at 2:43 PM
    #366
    Skeou
    Austin
    Florence, Alabama
    Mainly for cost purposes so I can bypass a turbo manifold all together. They're expensive plus the 2.7 has air injection and it throws codes once that's gone. As far as offroading, I go where I can lol mainly just on light trails and shallow mud
  7. Apr 12, 2017 at 2:43 PM
    #367
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Injectors probably, rising rate fpr if you wanna be budget minded and a bigger pump, but i don't know much about the 2.7
  8. Apr 12, 2017 at 2:49 PM
    #368
    Skeou
    Austin
    Florence, Alabama
    I figured I'd need injectors and a fuel pump. But at low boost they wouldn't have to be too big right?
  9. Apr 12, 2017 at 2:54 PM
    #369
    Brice
    Brice Turbo Member
    Brice
    Texas
    About 5psi and the stock system would probably be fine(from what I understand about stock toyota fuel systems), your issue would be closed loop enrichment.
    boostedka likes this.
  10. Apr 12, 2017 at 2:59 PM
    #370
    Skeou
    Austin
    Florence, Alabama
    Enlighten me on what that is pls
  11. Apr 12, 2017 at 2:59 PM
    #371
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Apr 12, 2017 at 3:03 PM
    #372
    Skeou
    Austin
    Florence, Alabama
  13. Apr 12, 2017 at 3:08 PM
    #373
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah missed your were a 3rd gen.
  14. Apr 12, 2017 at 3:36 PM
    #374
    Brice
    Brice Turbo Member
    Brice
    Texas
    Oh a 3rd gen? I dunno about injectors then apparently direct injection injectors are hard to get in bigger sizes...
    Closed loop is normal driving, ECU will fight arm and leg to keep AFR's at 14.7:1
    Open loop varies from vehicle to vehicle but is usually around 13:1-12:1.
    You'll wanna be in the 12's for 5 psi to prevent pre detonation a cracked piston. Although just 5psi wouldn't hurt anything really you'd want AFR's in the 12's to make decent power. Your issue will be making the AFR's richer for boost while still in closed loop
  15. Apr 12, 2017 at 3:40 PM
    #375
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nice try. :p
    MadTaco461[QUOTED] likes this.
  16. Apr 12, 2017 at 3:40 PM
    #376
    Skeou
    Austin
    Florence, Alabama
    Maybe an ECU upgrade would work?
  17. Apr 12, 2017 at 3:42 PM
    #377
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Follow what @MrCrowntown is doing, in his build thread. He's working with LC Engineering to make a front turbo manifold.
    I've been through the rear mount mess. Trust me. The cost savings didn't cover the problems.
    MrCrowntown, Brice, boostedka and 2 others like this.
  18. Apr 12, 2017 at 4:14 PM
    #378
    MadTaco461
    CA
    Kinda stock
    What kind of issue where you having with the rear mount? I wasn't on here when you were running that setup.
  19. Apr 12, 2017 at 4:24 PM
    #379
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I had a whole build thread about it, on XRU. Condensed it down to the first couple pages on here.
    Always sucking up water, snorkel placement issues, filter getting so clogged with dirt that it had to be replaced rather than washed, wastegate always getting water in it screwing with the boost pressure, nearly all of 1st gear turbo lag, boost reference issues, oil pump for the drain issues.....just a couple minor things.
    MadTaco461, boostedka and j0shu4 like this.
  20. Apr 12, 2017 at 4:27 PM
    #380
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    @GioGuitarDude had a rear for a while. Switched to bay mount....some of the same issues. Oil return and feed issues too.....
    What a pita really. Not worth it at all......
