Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 4, 2017 at 1:36 AM
    #3901
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bolt it up already! What are you waiting for?
  2. Nov 4, 2017 at 4:35 AM
    #3902
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I did run a vacuum line from s/c to fpr. I disconnected the harness to the 5th injector and the truck ran the same. I think I'm getting somewhere now. I ordered a cable to check my FTC controller to see if it has a map or the correct map on it. By the way, 6 psi should be no problem on the stock 3rz right? (internals)
    Torspd[QUOTED] likes this.
  3. Nov 4, 2017 at 4:36 AM
    #3903
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    I replaced the fuel filter about 30k miles ago with an OEM Toyota filter.
  4. Nov 4, 2017 at 5:37 AM
    #3904
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Im definitely going to check again to make sure
  5. Nov 4, 2017 at 6:53 AM
    #3905
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  6. Nov 4, 2017 at 6:59 AM
    #3906
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Heres hoping i knocked another hundy of my spool
    MadTaco461 likes this.
  7. Nov 4, 2017 at 7:07 AM
    #3907
    yota243
    E.J.
    north Alabama
  8. Nov 4, 2017 at 7:46 AM
    #3908
    MadTaco461
    CA
    Kinda stock
    yota243[QUOTED] likes this.
  9. Nov 4, 2017 at 7:59 AM
    #3909
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Yea I had a leak on my vband one time post turbo on my downpipe. It messed up my wideband readings. Datalog showed it was good at WOT on the front and rear o2 sensors but wideband showed it running lean.
  10. Nov 4, 2017 at 8:17 AM
    #3910
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    You may just need to pull out a little timing from the map that’s is loaded on the FTC in the areas that you’re getting pinging
  11. Nov 4, 2017 at 8:29 AM
    #3911
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Nov 4, 2017 at 8:33 AM
    #3912
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There has to be an innuendo with the length of the new "balloon" compared to the previous, and Chinese parts need extra love...
  13. Nov 4, 2017 at 8:35 AM
    #3913
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You are one of the rare ones who has WRAF sensors pre-turbine, as well.
  14. Nov 4, 2017 at 8:37 AM
    #3914
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So did lucky charms rain upon thee, and you found that extra hundy? Or was it more????
  15. Nov 4, 2017 at 8:37 AM
    #3915
    yota243
    E.J.
    north Alabama
    Fwiw a condom is way easier to put on a wastegate than a ballon is, in case anyone else wants to attempt it
  16. Nov 4, 2017 at 8:39 AM
    #3916
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LOL
    yota243 likes this.
  17. Nov 4, 2017 at 8:39 AM
    #3917
    yota243
    E.J.
    north Alabama
    I dunno yet. Im headed to a visitation right now and just had a little extra time before i had to get ready. I was gonna clock my maf too but the nuts on the clamps are somewhere between a 3/8 and a 7/16 and i didnt have a wrench at my house... But i will soon find out sir
  18. Nov 4, 2017 at 8:40 AM
    #3918
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    11mm no worky?
  19. Nov 4, 2017 at 8:42 AM
    #3919
    yota243
    E.J.
    north Alabama
    It will but i didnt have one in my garage. Ill head to the tractor shed or my buddy's shop tomorrow night (foot ball is on today, ROLL TIDE!)
  20. Nov 4, 2017 at 9:40 AM
    #3920
    MadTaco461
    CA
    Kinda stock
    You come for wastegate massage? I treat you right.
    Torspd[QUOTED] and yota243 like this.
