Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 20, 2017 at 12:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Mar 20, 2017 at 12:34 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I need to buy the one that the mapecu3 uses. Just been too lazy to call urd or maybe someone local. It's like a GM sensor, but maybe has a different curve. I can't write a temp curve in a piggyback. I bought mine used so I'm the only guy without the sensor. For the time being I can get a resistor in and make a summer map and winter map. The OEM ecu is pretty aggressive with temp changes on a blow thru maf.
  3. Mar 20, 2017 at 12:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ahh. Wonder if I still have a temp sensor from my Map-Ecu 2???
  4. Mar 20, 2017 at 12:41 PM
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Nope.
  5. Mar 20, 2017 at 12:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you weren't already aware, the e85 doesn't lubricate like normal petrol. So your pump's components will have a much reduced life.
    Lucario Runner and Blackdawg like this.
  6. Mar 20, 2017 at 12:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    11.8-12 is perfect. 9.6 is insanely rich.
    But yea, im sure you'll have to replace all that stuff if you run it consistently. Didn't have to change any of the tune?
  7. Mar 20, 2017 at 12:45 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Good to know! Is there anything else I would need like certain plugs or a different o2 sensor? I've read a few convincing post elsewhere about e85 being a lot less dangerous than common conception.
  8. Mar 20, 2017 at 12:45 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hmm you could always use the AUX gauge for the content analyzer? Just give up recording AFRs.
  9. Mar 20, 2017 at 12:46 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Of course.
  10. Mar 20, 2017 at 12:47 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    Stoich would be different for e85 I believe...That may affect target afrs if your stoich reference isn't correct
  11. Mar 20, 2017 at 12:47 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Don't mind me. Here for personal entertainment and knowledge rather than business. :popcorn:
  12. Mar 20, 2017 at 12:47 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Oh snap! The fic6 can't make adjustments based on the AUX though right?
  13. Mar 20, 2017 at 12:48 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I meant 9.6 compression ratio. My 91 afr's were 10.8-11.3.
    Torspd likes this.
  14. Mar 20, 2017 at 12:48 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    No but it can record through it, may be useful in determining the correct 91 to e85 ratio when making pulls if that's something you wanna do.
    Clay_916[QUOTED][OP] likes this.
  15. Mar 20, 2017 at 12:49 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct. On the AFR gauge, the safe zone is leaner than with petrol, while in boost or otherwise. There are charts available. Just have to look it up.
    Brice[QUOTED] likes this.
  16. Mar 20, 2017 at 12:49 PM
    #36
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    They are different for e85 but you can just use the gasoline values and tune exactly like you would for gas, slighty leaner.
  17. Mar 20, 2017 at 12:50 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Knowledge :spy:
    mjp2[QUOTED] likes this.
  18. Mar 20, 2017 at 12:51 PM
    #38
    Brice
    Brice Turbo Member
    Brice
    Texas
  19. Mar 20, 2017 at 12:51 PM
    #39
    mjp2
    NJ
    vvvvvVVVVRRRROOOOOMMMMMPSSSssssshhhhhhhh
    BassAckwards and MrCrowntown like this.
  20. Mar 20, 2017 at 12:52 PM
    #40
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    From what I've read, using the gasoline afr's for e85 12.5 is max rich torque and 12.0 is the safest you can be while sacrificing a few ponies.
