Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 7, 2017 at 4:58 PM
    #4001
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That's gonna give you horrible mpg... How big is it and does it just bolt on?
    What about the V6 TB?
  2. Nov 7, 2017 at 5:02 PM
    #4002
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Lmao, I'm putting a 76mm turbo on the truck. I no longer give a hoot about mileage hahaha
    The reason I'm going with the 2uz throttle body, is that it matches the size of the inducer on the compressor. So at full tilt, there should be no restrictions except when the air is squeezed down the runners into the chamber.
    And it will require a custom flange
    Torspd and TireFire[QUOTED] like this.
  3. Nov 7, 2017 at 5:14 PM
    #4003
    TireFire
    Olympic Peninsula
    Sweet
  4. Nov 7, 2017 at 5:30 PM
    #4004
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Yeah eventually I’m gonna do the paradise intake and 70mm throttle body but that’s 1200$ better spent elsewhere right now
    MrCrowntown[QUOTED] likes this.
  5. Nov 8, 2017 at 6:22 AM
    #4005
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Wow!! my truck runs so much better in the cold :)
  6. Nov 8, 2017 at 6:23 AM
    #4006
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Better D.A. FTW!
    Also practiced some aluminum welding last night. I think I can do this.
    MrCrowntown, MadTaco461 and Jstand like this.
  7. Nov 8, 2017 at 6:24 AM
    #4007
    Jstand
    Irving,Tx
    You can do it !!:thumbsup:
  8. Nov 8, 2017 at 6:32 AM
    #4008
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Might be a sign your IC isn't up to par. Were you among the few experimenting with e85? If not you could consider methanol injection. It basically makes the engine run like it's winter in the summer.
  9. Nov 8, 2017 at 6:34 AM
    #4009
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My intercooler is barely on par. Basically a Mishimoto intercooler. Heat soaks in no time, and has no internal diverters.
  10. Nov 8, 2017 at 6:37 AM
    #4010
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    is that some kinda joke since you has a super short ram set-up rn, or are you referring to the time when you were boosted (maybe a little shot out there but meh)
  11. Nov 8, 2017 at 6:43 AM
    #4011
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    PM speedfreak. He makes them for the 3rz. You just have to send him an upper section for him to use
    Jcyr[QUOTED] likes this.
  12. Nov 8, 2017 at 7:39 AM
    #4012
    yota243
    E.J.
    north Alabama
    happy to know that (spoiler alert) my truck should make a good bit more power than a 350z with a 100 shot (and I think those 350z are really heavy for the size they are if memory serves me correctly)
    https://www.youtube.com/watch?v=IDfP6FYbPz8&t=657s
  13. Nov 8, 2017 at 7:47 AM
    #4013
    Jcyr
    Jack
    North east
    Any idea how much
  14. Nov 8, 2017 at 7:55 AM
    #4014
    boostedka
    James
    NM
  15. Nov 8, 2017 at 8:11 AM
    #4015
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  16. Nov 8, 2017 at 8:27 AM
    #4016
    Jstand
    Irving,Tx
    I did go with the smaller IC 5" instead of 7" and yes I've been mixing E85 in.
  17. Nov 8, 2017 at 8:31 AM
    #4017
    Jcyr
    Jack
    North east
  18. Nov 8, 2017 at 8:35 AM
    #4018
    yota243
    E.J.
    north Alabama
  19. Nov 8, 2017 at 8:43 AM
    #4019
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Still on, but when I was boosted. The short ram was to free up restriction, since N/A.
    yota243[QUOTED] likes this.
  20. Nov 8, 2017 at 8:44 AM
    #4020
    Jcyr
    Jack
    North east
