Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 8, 2017 at 9:38 AM
    #4021
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    350s are fun cars but yes heavy. i enjoyed mine when i owned it but it was never really a car i felt like thrashing on
    yota243[QUOTED] likes this.
  2. Nov 8, 2017 at 9:38 AM
    #4022
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I think the 300zx was a way cooler car.
  3. Nov 8, 2017 at 9:39 AM
    #4023
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I might be depending on what the actual cost may be. I have an extra intake manifold in my garage that I bought a while back that I thought about doing this with once I had some extra $$$ to do so.
  4. Nov 8, 2017 at 9:57 AM
    #4024
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Cool if we can get one of two more we should be able to keep the price close to what you were originally quoted
  5. Nov 8, 2017 at 9:57 AM
    #4025
    Jcyr
    Jack
    North east
  6. Nov 8, 2017 at 10:03 AM
    #4026
    boostedka
    James
    NM
    Cool. I may have to wait to after the holidays to see what kind of damage that does first
    Jcyr[QUOTED] likes this.
  7. Nov 8, 2017 at 10:06 AM
    #4027
    Jcyr
    Jack
    North east
    Im n
    Im not in a huge rush either most my money is going to a home purchase atm, i May experiment with making my own manifold also.
  8. Nov 8, 2017 at 10:45 AM
    #4028
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I think I'm about as far as i can go for awhile.
  9. Nov 8, 2017 at 11:23 AM
    #4029
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Let me be like @Torspd and buy an AC/DC Tig welder. Then I can make an efr mani and front facing intake. I have these annoying 10in coilovers in the way of everything. Nothing can stick out wider than the frame. Chopping up a stock mount is what I would do too. Keeps price down.
    MrCrowntown and Torspd like this.
  10. Nov 8, 2017 at 12:25 PM
    #4030
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The possibilities rush into the brain, once you start TIG welding. If only the skill rushed in as quickly.
    Jstand likes this.
  11. Nov 8, 2017 at 12:34 PM
    #4031
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I highly recommend an AHP 200x, really enjoying mine and cost of entry is low
    MadTaco461[QUOTED] likes this.
  12. Nov 8, 2017 at 12:36 PM
    #4032
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    On that note, www.cyberweld.com is having sales for welders with helmets. Something like $900 off.
    MadTaco461 likes this.
  13. Nov 8, 2017 at 12:50 PM
    #4033
    MadTaco461
    CA
    Kinda stock
    I need to sign off of tw. Dreaming too much lately.
    MrCrowntown, dirtdigginjoe and Jcyr like this.
  14. Nov 8, 2017 at 12:54 PM
    #4034
    Jcyr
    Jack
    North east
    Tor is there any biasing that needs to happen when doing a front facing intake or can you pretty much add as muh flow with all equal length/design tubes as you can fit and the engine will pull to each cylinder equally from there?
  15. Nov 8, 2017 at 12:55 PM
    #4035
    Jcyr
    Jack
    North east
    Spending too much monopoly money?
  16. Nov 8, 2017 at 12:56 PM
    #4036
    MadTaco461
    CA
    Kinda stock
    That thing has some good reviews on Amazon. Looks perfect for a hobbyist learning how to tig.
    05Taco4x4[QUOTED] likes this.
  17. Nov 8, 2017 at 1:13 PM
    #4037
    MadTaco461
    CA
    Kinda stock
    My mazdaspeed has a front facing intake and someone flow tested it. They balance out well just fine until you get up to the really high air flows. Then you start getting some cylinder imbalance. That is why you have that large plenum. Lot of oem motors have the throttle body off to the side. If you make a plenum a bit larger than stock and keep the runner the same diameter you should make some pretty big power and still have good cylinder balance. Too big you get poor bottom end throttle response.
    I costs in my head is getting expensive quick. At least no trigger pulling yet.
    Torspd and Jcyr[QUOTED] like this.
  18. Nov 8, 2017 at 4:47 PM
    #4038
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My stroker engine needs more in and out.
    MrCrowntown likes this.
  19. Nov 8, 2017 at 4:48 PM
    #4039
    Jcyr
    Jack
    North east
    Do you still have multiple blocks or just building the stroker?
  20. Nov 8, 2017 at 4:53 PM
    #4040
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
