Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 8, 2017 at 4:54 PM
    #4041
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I hear all of you right now- had to get a root canal/crown that I wasn't planning for, plus I'm fighting with a hesitation when I go WOT or close to it at lower RPM. I completely removed the AEM FIC for troubleshooting, but the issue still persists and I can't recall if it was there prior. Going to clean the MAF/TB this weekend while I'm away, and I'll check my coils, as they're 110k and original. Plugs are new as of 92k. Fuel pump/filter are original (or at least to me, as I bought it certified Pre-Owned with 65k on it). No CEL, no real indication via Torque, either.
    Edit/Side note: If I decide to change the pump, I'll go with the URD kit and the AEM E85 pump! :amen:
    Jstand, MrCrowntown and MadTaco461 like this.
  2. Nov 8, 2017 at 4:59 PM
    #4042
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Building all 3?! Or just one with 2 backups? Lol
  3. Nov 8, 2017 at 5:02 PM
    #4043
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Two are built
  4. Nov 8, 2017 at 5:27 PM
    #4044
    Jcyr
    Jack
    North east
    Damn all the moniesssss :) or are you building the whole thing yourself or sending it out for head work ect ect?
  5. Nov 8, 2017 at 5:53 PM
    #4045
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Maybe that's the stock 'lag' built into the drive by wire? I notice it holding back throttle response when banging through the gears. Does the FIC control DBW?
    Stabbing in the dark here.
    :rasta:
    dirtdigginjoe[QUOTED] likes this.
  6. Nov 8, 2017 at 6:00 PM
    #4046
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I've done both. Thru-and-thru to built by a machinist. It just depends on the specifics of the build.
  7. Nov 8, 2017 at 6:02 PM
    #4047
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I wouldn't call it lag, considering it feels like a misfire almost. It's like a hiccup in the low RPM, then it'll clear itself out after it does it once in each gear. If I roll into the throttle, it won't do it. The AEM only taps the TPS sensor, doesn't modify the signal in any way. I've been reading some threads about others with this issue, and it seems to end up being either a dirty MAF, bad fuel pump, or bad coil(s). The only other thing that's changed is I went to 93oct from my normal gas station (I always buy 87 though), then immediately disconnected the battery while I was doing the FIC install.
  8. Nov 8, 2017 at 6:02 PM
    #4048
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is a feature of the stock throttles operation.
  9. Nov 8, 2017 at 6:03 PM
    #4049
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Crap gas perhaps? Or refinement of tune? Possibly both?
  10. Nov 8, 2017 at 6:05 PM
    #4050
    Jcyr
    Jack
    North east
    Have you ever done a write up of the one you did yourself and the cost vs the machinest and cost like a side by side comparison on cost per performance added? Or is it thown somewhere is the million comments in your thread?
  11. Nov 8, 2017 at 6:25 PM
    #4051
    MrCrowntown
    Alyn
    Ky
    Maybe the open loop map needs some adjusting? Could be stutter from over fueling too fast when stabbing the throttle
  12. Nov 8, 2017 at 6:34 PM
    #4052
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    The AEM is not installed, truck is 100% back to stock for troubleshooting purposes right now. I'm almost leaning towards crap fuel, which I should be able to rule out by the weekend, as I'm going up to my vacation home 200mi each way, so I'll be able to full up and continue testing everything. Torque logs don't show anything irregular, all my fuel and ignition trims are all perfect.
    MrCrowntown likes this.
  13. Nov 8, 2017 at 6:41 PM
    #4053
    Jcyr
    Jack
    North east
    Where is that vacation spot sounds close to me
  14. Nov 8, 2017 at 7:08 PM
    #4054
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Near Roscoe, NY... Know where the Roscoe Diner is? Lol everyone knows where it is! It's Delaware County, on your way out towards Binghamton.
    Jcyr[QUOTED] likes this.
  15. Nov 8, 2017 at 7:08 PM
    #4055
    Jcyr
    Jack
    North east
    Closer to my neck of the wood than usual nice!
  16. Nov 8, 2017 at 7:17 PM
    #4056
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    THIS SOUNDS SO FAMILIAR !! o_O
  17. Nov 8, 2017 at 7:31 PM
    #4057
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    2 million.
    MrCrowntown and yota243 like this.
  18. Nov 8, 2017 at 8:15 PM
    #4058
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    doesnt sound like a fuel pump issue. the time i had a pump issue it was more like a low rpm redline, the engine wouldnt rev up past a point anymore when full throttle. it would though half throttle
  19. Nov 8, 2017 at 8:40 PM
    #4059
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Are you guys BOV to environment or recirculating?
  20. Nov 8, 2017 at 9:58 PM
    #4060
    05Taco4x4
    2TR-FE Enthusiast
    Also, does anyone know the oil pressure at the 2TR-FE oil filter housing pre and post filter?
